Go Back   Diesel Forum - The Diesel Stop.com > 1999-2007 Super Duties > 7.3L Power Stroke Engine and Drivetrain
7.3L Power Stroke Engine and Drivetrain Discussion of the 7.3L Power Stroke diesel engine and drivetrain in the 1999-Up Super Duty trucks and Excursions. No gas engine discussion allowed except on transmissions and drivetrain that pertain to all models. Please confine discussion of topics in this forum to those items that are specific to the 7.3L Power Stroke engine.
Old 11-06-2009, 02:25 PM   #1 (permalink)
Charge light came on
Hello Diesel Guru’s
The other day I started my rig, the one listed in my signature, and the charge light stayed on after start-up. I was already out and needed to drive it home so off I went. I turned off any additional electrical components (ie, stereo, heater blowers, etc.) and started off. Once the engine RPM’s came up to about 1500-1800 the light went off and stayed off until I came to my first stop sign/light, then it came back on. It went off again as soon as the RPM’s came up. This continued until I got home. Once there, the light stayed off even at an idle. So with that in mind, I have two relatively new batteries, both less then a year old. Do you think alternator? Or after reading on here, I’m also think diodes. What is your input??
Thanks in advance
Jim
2003 EXCURSION EDDIE B, 7.3 PS, 4" Magnaflow Turbo Back exhaust with International up-pipes. BD-Power X Monitor, AFE Stage 2 and Edge Evolution. 6.0L Trans Cooler. JVC DVD head unit with 6 Boston Pro series speakers, Rockford Fosgate 12" sub and amps. Oh ya, AC power for the Blender.
scrmn6guns is offline
Old 11-06-2009, 03:52 PM   #2 (permalink)
woodnthings8's Avatar
More than likely the alternator is going. More than likely the brushes are worn to the point that the wire connecting them is holding them off the armature. When the engine rev's the alternator makes more power and that is enough to turn off the light. You can get a new unit or if you can find brushes they can be changed if you have a little electrical experience.
2002 F-350 CCLB 4X4, HD4R100 , 4" Diamond Eye exhaust, Powerslot rotors, DP Tuner-F6, Autoenginuity, KCM S.S. HPX Line, S&B Filters intake, Autometer gauge pod, Inovations canopy,Banks Big Head wastegate actuator, 6.0L Trans Cooler, Zoo-dad, Dieselsite Coolant Filter, DVD and always looking to do more....
woodnthings8 is online now
Old 11-06-2009, 04:55 PM   #3 (permalink)
Thx... I have an alternator shop by me that I've used in the past, I'll give them a call and see what they say....
Old 11-06-2009, 06:15 PM   #4 (permalink)
Sounds like what happened when my alternator was going out. I went to a Schucks auto place and they came out to my truck and tested the alternator while the truck was running. Bought an alternator there, put it in, and no more problems.
Scott
Early 99, 4WD
Skydiver is offline
