CHEAP FIX for 7.3l dipstick oil leak - Diesel Forum - TheDieselStop.com
post #1 of 1 (permalink) Old 07-01-2009, 05:25 PM Thread Starter
Wink CHEAP FIX for 7.3l dipstick oil leak
Oil leak at dipstick tube flange fixed -with pics! - Ford Truck Enthusiasts Forums
Hey guys,
I recently started leaking massive amounts of oil from the flange that holds the dipstick tube to the pan. As you may be aware, the flange is inserted from the inside along with the oring to seal it. I think it might be possible to replace that oring, but I went with the tried and true International repair kit.
Intl # 1846146C91 consists of:
Gasket
Oring (small one for the dipstick tube where it slides in the flange)
RTC
Loctite Flange Sealer
Instruction Sheet
Here's the gasket dimensionally if you need to make one in a pinch. 2 1/2" OD, 1 5/8" ID, and 0.031" thick.
netpro is offline
