check engine light comes on somtimes after full throttle then goes away? - Diesel Forum - TheDieselStop.com
post #1 of 8 (permalink) Old 09-18-2006, 09:53 PM Thread Starter
my check engine light goes on some times upon startup and/or after full throttle. Once i let off the gas the light comes on and the truck will not respond to the gas pedale, it will stay at a clean idle for like 10 seconds or so and not do anything if i give it gas, kind of like a fail safe mode or something. i removed my airfilter thinking it was getting clogged but that didnt stop it. I also plugged in a code reader and it doesnt show any codes present. There is also no chip or tune in the truck, it is a bone stock 2002 7.3 psd. Any ideas?? Thanks a bunch!
midnight36 is offline
post #2 of 8 (permalink) Old 09-18-2006, 10:01 PM
My Photos: (22)
Re: check engine light comes on somtimes after full throttle then goes away?
Most likely your TPS. Replace your throttle pedal assembly once you verify the TPS code.
Hammer
Check out what I recently bought:
I still have the:
2001 F250 Lariat CC/SB 4x4 7.3 auto
TERMINATOR HPOS...Ceramic coated Garrett GTP-38R with BBHA & GDS outlet...DP-tuner Big Oil Program...ITPdiesel Fueling and overboost regulator...6.0 CAC...AFE Stage-II PG7... Magnaflow 3.5dp/4exh...5R110 TC, BTS VB, John Wood pump mods, & V10 cooler...Schaeffer's 9000 5w-40...Oilguard bypass...and other stuff
On the shelf collecting Dust: <font color="green"> Stainless Grill Overlay </font>
<font color="red">
</font>
Get Your Tuning Here:
and your Fuel kits here:
TheHammer69 is offline
post #3 of 8 (permalink) Old 09-18-2006, 10:38 PM Thread Starter
where is the throttle position sensor located? also is there an idle validation microswitch? if so where is that?, I heard If you sprayed contact cleaner on these it can maybe fix them?
post #4 of 8 (permalink) Old 09-18-2006, 10:50 PM
klhansen's Avatar
My Photos: (180)
They are both on the pedal assembly. Peek under the inst panel and you'll see where the wires hook to the pedal assy. The plug with 3 wires is the TPS and the one with two wires is the IVS.
Contact cleaner might be worth a try, but don't expect too much from it. A replacement pedal assy is about $100.
), AIS,
regulated return,
klhansen is offline
post #5 of 8 (permalink) Old 09-18-2006, 11:10 PM
Banned
There was a recall on 02 for pedal assembly.Check it out at our dealer.Save you come change.
kainers is offline
post #6 of 8 (permalink) Old 09-18-2006, 11:36 PM
klhansen's Avatar
My Photos: (180)
IIRC, that was for the adjustable pedal setup, and I believe it has expired (not a recall but a warranty extension thing for dead pedal complaint).
But then again, maybe they'll take care of it. [img]/ubbthreads/images/graemlins/laugh.gif[/img]
), AIS,
regulated return,
klhansen is offline
post #7 of 8 (permalink) Old 09-18-2006, 11:56 PM
Banned
Yeh that was quite a few years ago
kainers is offline
post #8 of 8 (permalink) Old 09-19-2006, 11:21 AM
JimTJr's Avatar
My Photos: (20)
The MAIN thing is if you have a SES light the truck is trying to TELL You where to look for the problem!!! Get the codes pulled and go from there, Unless you have money to throw away!
Jim T.*48* SLAPS Co-Founder, 30.8 yrs RETIRED UAW 6/01/06, Now an ART (Specialists Flight Chief) with the USAFR 414th MXS Seymour Johnson AFB.
New truck, 2011 F-350 SRW LB CC. White Platinum Lariat! 4x4
JimTJr is offline
