Check Engine Light and No Power 1999 7.3 Power Stroke - Diesel Forum - TheDieselStop.com
post #1 of 5 (permalink) Old 11-25-2007, 05:54 PM Thread Starter
1999 7.3 Power Stroke, auto trans, 4x4. Check Engine Light comes on and engine runs rough with no power. I though I had purchased some bad fuel but condition still exist after 4 tanks of fuel. Condition comes and goes without any frequency. Condition will clear if I let engine run for 10 to 20 minutes and it seems to help if I start and stop engine several times. Has anyone had this issue or know cause. I have changed fuel filter, drained gallons of fuel and added additives to fuel. Appreciate suggestions. Thanks
jojoracer is offline
post #2 of 5 (permalink) Old 11-25-2007, 06:09 PM
Re: Check Engine Light and No Power 1999 7.3 Power Stroke
If there is a check engine light then that means there is a at least one code set. Find a place that can scan for those codes, not Autozone. Once you know those codes you should be able figure out the issue.
2000 F-250 Ex-Cab Shorty - 4x4 - 7.3l - Auto - CAT ELC - 203* - Dieselsite Coolant Filter - AIH Delete - ITP HPX - Bilsteins - Walker BTM - Ford Severe AIS - CCV Canister - SCMT 1700 - Harpooned Tank w/ ITP Pre-Pump Kit - 321k
Check out my
tjsulli790 is offline
post #3 of 5 (permalink) Old 11-25-2007, 06:16 PM Thread Starter
I took it to Auto Zone and they showed no codes. Do you know if the code will show up if the condition is not present when they check. The condition usually happens when I am in the middle of no where. Thanks, I will have this checked at some place else.
post #4 of 5 (permalink) Old 11-25-2007, 06:21 PM
Yea, once you have had the problem a code is set. Autozone does not have the proper scanner for our trucks.
Check out my
post #5 of 5 (permalink) Old 11-25-2007, 06:27 PM Thread Starter
Thanks. Appreciate it.
