Chevron Delo400 15W40 vs Shell Rotella-T 15W40 - Diesel Forum - TheDieselStop.com
post #1 of 20 (permalink) Old 07-25-2005, 03:33 PM Thread Starter
According to the ChevronTexaco website Delo400 has a better additive pachage than Rotella-T.Delo400 has more sulfated ash and more detergents than Rotella-T.I'm trying to find which of the two will deliver better performance.I think Rotella-T is a bigger seller than Delo400.I believe more truckers use Rotella-T more.Thanks Joe [img]/ubbthreads/images/graemlins/smokin.gif[/img]
2000/Superduty-350/Drw/Lariet/4x4/Auto/Trailer tow pkg/Camper pkg/Offroad pkg/Leather/Capt chairs/4:10 rear ratio/Gibson exhaust tip /Weather tech wind deflectors/Dark Toredor red/ESOF/Bed rug/Rancho steering stabalizer/Husky floor mats/ /Edelbrock-Performer IAS Shocks/Putco Front bed protector/Putco hitch cover/Willmore Stainless Steel Kickplates/Autometer tranny temp guage/Wheelskins steering cover/Racor-460/R30 Pre pump Fuel Filter/Bully-Bed tiedowns/Amsoil Synthetic ATF/Ford AIS Powercore Air filter/Phoenix DOT simulators/PML Transmission pan/PML Dana 80 Rear differential cover/ORU Dana 60 front differential cover/Extang Classic Platinum tonneau cover/EPC-Filterminder/Zerex Coolant/Bores bumper guides/Bores logo trim/Interstate MegaTron Plus #65 batteries/Chevron Delo400 15W40/Fleetguard filters/Rhino Hitchstep/Undercoated
JOE TURBO DIESEL is offline
post #2 of 20 (permalink) Old 07-25-2005, 04:14 PM
drdenny1's Avatar
Re: Chevron Delo400 15W40 vs Shell Rotella-T 15W40
I know a lot of folks here use the Rotella. I tried it and did not care for it. My truck seems to run a touch quieter and much smoother with the Delo. I always used Delo on my other PSD and it liked it too. [img]/ubbthreads/images/graemlins/shrug.gif[/img]
Denis
, GTP38R, PHP Hydra, 4"DPPI Turbo back, J/S IDM, aFe Magnum, Boost Bleed off, APCM(AIC), ISSPRO TTM, Dual alt's., Racor 4500 CCV, A-Pillar Autolites Trans/EGT/Boost, Warn Premium Hubs 4" Lift W/315's, ARG SuperPump and Gear, DDM HID's 55W/10K HI-LO's
drdenny1 is offline
post #3 of 20 (permalink) Old 07-25-2005, 04:21 PM
I'd always used Rotella T until one day when I found that Walmart was out of it. I picked up some Delo, which happened to be cheaper, and have used that for the last two oil changes. Truck seems to run just fine on both oils. I'd just pick one and go with it. Delo is about $1/gal cheaper here, which decides it for me.
Early 99 Ford F250 PSD CC SB 4x4, 4" Procomp lift, Goodyear Wrangler Silent-Armor 285/75-16s on stock alloy wheels, Centramatic 300-308 balancers, Superchips Gold +70hp/+150ftlb, MBRP 4" Turbo-back exhaust, KCM S.S. HPX Line, Autometer pillar pyro, Trans, Boost, Sonnax & Tricumulator, Aeromotive Bypass regulated return, Aeromotive A1000 fuel pump, tank sump, Earl's 85 micron SS pre-pump filtration, -10 AN suction/-8 AN feed fuel delivery, harpooned, K&N cone filter, AirRaid intake, 1C3Z-7902-CARM torque converter, Magnefine tranny filter, Felpro 8194 uppipe gaskets, Ready-Aire 74809 heater core bypass, custom headache rack w/ dual whips, XM radio & 400W sound system.
95 Nissan Pathfinder 4x4, modified for desert overland travel & too much for a sig line
72 Datsun 510, 39,000 mi chassis, 200hp/2100lb v6 powered street scorcher
datz510 is offline
post #4 of 20 (permalink) Old 07-25-2005, 04:30 PM
I just changed the oil in my truck it made my truck alot quieter.
1997 F-250 PSD, 130k, 4x4, Outlaw E4ODX, Standard Cab, reg bed, 3.55 LS rear, Swamps 225/146 injectors, Autometer Guages Pyro/Boost/Tranny, 3" downpipe, 3.5" adjusted exhaust, ts 6 pos chip, Tonys fun programs, Tru-Cool H7B, 285/75, factory alum rims, Western V-Plow, 6.0 intercooler installed not plumbed
I wish my lawn was Emo, cause then it would cut itself
Some people are blinded--because they have all the answers
Racerxpower.com for your upgraded E4OD/4R100 needs
BlindViper is offline
post #5 of 20 (permalink) Old 07-25-2005, 05:47 PM
drdenny1's Avatar
What oil did you use? [img]/ubbthreads/images/graemlins/shrug.gif[/img]
drdenny1 is offline
post #6 of 20 (permalink) Old 07-25-2005, 06:40 PM
i just swiched from rotella to delo and i have to say my engine does seem quieter. [img]/ubbthreads/images/graemlins/shrug.gif[/img]. i do not know why or how. maybe i am dreaming.
99 f250 (5/98)ais, pre pump/in tank, zoodad, walker BTM. dp-tuner chip.
eddyzima is offline
post #7 of 20 (permalink) Old 07-25-2005, 06:52 PM
Why would the same weight oil cause a veh to run quieter ???
If it was a heavier weight I could understand but why ???
Maybe someone that "keeps" everything or knows a lot will answer...
I would hope so .....
'99 F-250 HD diesel EC 4x4 George West, TX
Kwik filter, ELC, Ranch Hand bumper guard, Warn hubs, SS HPX, 6.0 tranny cooler, Bilsten shocks
RobertJohn is offline
post #8 of 20 (permalink) Old 07-25-2005, 07:04 PM Thread Starter
Right now I use Shell Rotella-T 15W40.I'm thinking about switching to Delo400 on my next oil change.The truck has 105,400 miles on her and I'm changing the oil every 3000 miles.Joe [img]/ubbthreads/images/graemlins/smokin.gif[/img]
post #9 of 20 (permalink) Old 07-25-2005, 07:08 PM
i do not know why it would be quieter with the same weight oil. but i do know i swiched from 5w30 castrol to 5w30 mobil 1 in my wifes tahoe and it ticked at idle when worm. i swiched back and it was gone. both with the same ac delco filter. [img]/ubbthreads/images/graemlins/shrug.gif[/img]
eddyzima is offline
post #10 of 20 (permalink) Old 07-25-2005, 08:45 PM
POS
They're both good, but I like Delo because it's a good oil and it's about a buck/gallon cheaper...
<font color="red"> WIX filters at </font><font color="blue">
</font>
POS is offline
post #11 of 20 (permalink) Old 07-25-2005, 10:03 PM
I have used both subject oils, each about half the total 84000 miles on the truck. Can not detect any difference in sound or performance.
Lake Norman at Denver NC 1999 250 PSD (built Sept 98) Lariat XLE7 CC Auto LWB 4WD ESOF ABS 3.73LS X-Caliber cap BFG 285E AT/KOs Jayco-TT 31BHS
David C is offline
post #12 of 20 (permalink) Old 07-25-2005, 10:48 PM
mallardman007's Avatar
I use Delo400....Dad has used it on his 89' IDI for 16 years, no probs. Plus Costco sells Delo by the case for right at $6/gal. [img]/ubbthreads/images/graemlins/smokin.gif[/img]
NEW: 1989 7.3 IDI ZF5, ECLB, 4x4 Bone Stock.... not for long
SOLD: Huntin' Machine! Early 99' F250 PSD Ext. Cab Longbed 4X4. Six- Shooter, Personalized Plates MLRDMAN. Autometer Sport Comp Pyro and Boost, DIY Tymar, Zoodad Mod, 4" MBRP T409 with muffler delete, and Aeroturbine 4040. Sounds Sweet!! 6 position chip, 285 Firestone Destination MT's on XLT wheels. Power Inverter, Backup Lights, Custom Headache Rack with more lights, Amsoil everywhere but the Engine.
2004 Honda 400 Rancher AT
mallardman007 is offline
post #13 of 20 (permalink) Old 07-26-2005, 11:33 AM
I have noticed this about changing the oil on my early 99. It did not matter what oil I used as long as it was 15W-40 but it always is quiter after an oil change. I change my oil at 5K as recommended and the environment in Florida is mostly low speed highway driving at around 55-60 mph.
I thought this was a placebo effect and I was imaging the quieter dB levels after an oil change but everyone here seems to agree that is the case.
This is not true for any of the other vehicles I own just this one.
Is it possible that with standard filtering systems that we pick up enough soot trash at greater then 5 microns to 15 microns that this helps to transmit noise?
I would really like to hear from the guys using the added filtration oil systems that filter this crap out to hear what they say about noise level after an oil change.
I used to have a dBA meter and if I can find it I plan to do a side by side comparison of this.
Anyway after an oil change the dB level is noticable and I now feel that I was not imaging things.
By the way the oils I used were Rotella Synthetic and Dino at the same weights.
purvi is offline
post #14 of 20 (permalink) Old 07-26-2005, 03:00 PM
I've always used Delo. The maintenance shop that we use for our fire apparatus swears by it.
2000 F-350 SRW,CC,LB,4x4,Auto trans., A-pillar gauges boost, tranny, pre-turbo pyro., Edge Evolution, back up lights, 5000# air lift air springs, Tru-cool max tranny cooler with elec. fan, 4" turbo back exhaust, "DIY" tymar, BFG AT's, Monroe reflex shocks, Wicked Wheel, CCV mod, Sonnax/Tri-cumulator. T/C lock up switch, 1000W inverter. Tows 2005 31' Cardinal TT 12,000+ lbs.
firetruckin is offline
post #15 of 20 (permalink) Old 07-26-2005, 03:11 PM
Its not the dirt in the oil that is causing the noise but air. The oils anti-foaming additives are used up over the life of the oil. The fresh oil does not foam as badly or to put it another way, releases the air bubbles faster than the old oil did. The lower air content results in a quieter running engine as the air effects injection timing due to its compressability.
2002 F-250 Larriat
jcthorne is offline
