I have a buddy with an early 99 f550 psd diesel all stock with a 5 speed tranny i pulled the inspection plate off for the clucth in bottom of bell housing and found some strips of metal roughly 1/8 to 1/4 thick and approx a foot long what would these be from in the bellhousing had no symptoms just looking to see if rear seal was leaking. Do these have the dual mass flywheel and is coming apart? but theres no vibration or rattle that i could tell. thanks in advance
2002 F-350 4wd psd. hx 48 turbo, single shot injectors, dual stage nitrous, 4 inch duals, 3 pos custom tuned dp chip,ccv mod, aih delete mod,itp regulated return, oil crossover line, sp diesel 10 level kit, afe stage 2 cold air kit, and many other mods and inventions made to engine. monstorbox tranny,triple disc tq, ladder bars, 4 inch susp lift, dick cepek tires on american racing rims and beadlocks, Ford AIC, Auto Enguinity.Billet Badges, custom badges.F-444 Gettin' Stroked
White 2-180 3208 cat
Massey Ferguson 35 3 cyl perkins
Massey Ferguson 6180 6 cyl perkins
Massey Ferguson 255 4 cyl perkins
Massey Ferguson 65 4 cyl perkins
Agco LT-75 4 cyl Cummins
Case 1845C Skid Steer 4 cyl cummins
Case 580 construction King Backhoe 4 cyl case
1986 F-250 6.9 IDI 4x4 265,000 miles *sold*
1994 4wd f-250 ext cab psd
good luck with clutch/tranny questions here. seems that all but a very few have automatics.
Early 99 (couldn't wait to get my butt in the seat of the new SD) Crew Cab 4X4, 6 speed, AIC, 5" lift, 38X14.50 Nitto Mud Grapplers (awesome mud tire, noisy though), Bushwhacker cutout flares, 4" straight exhaust w/6" tip, open element filter, cowl induction hood, custom grill, stereo upgrade, and most importantly - new style cup holder. 'Pane. H2O soon to come. Kill Record: 1 Honda Accord
Sold the SCMT and replaced it with a DP Tuner, and aint looking back!
Get this back to the top; the situation doesn't sound promising. Could be the pilot bearing??? You need to pop that thing back a few inches and take a peek if you can.
02' F250 CC 4x4 SWB 6-Spd 3.73, 85k
Tuff Country 5" Suspension Lift, 315 x 75 x 16 Buckshot Mudders, X-Treme Alloy 10" Wheels. Wicked Wheel, MBRP 5" Exhaust, AFE Stage 2 Intake, Coolant Filter. Legacy Custom Seat Covers front and rear (Best mod yet!).
There is a large steel spacer plate that mounts between the engine block and the bellhousing. It is approx. 3/16" thick and has narrow sections. If the bellhousing bolts become loose, it might be possible for the spacer plate to fracture and the pieces fall into the bellhousing. Replacement requires sliding the tranny back about 10".
most e99 don't have dmass flywheels but if you have 130xxx miles get ready for a clutch springs come out of the disk and first you think its master slave problem but everyone I have talked to have changed them out for no real reason (not bad after all) but I do like the LUK replacement.
