Clutch master cylinder pushrod clip fix? - Diesel Forum - TheDieselStop.com
post #1 of 9 (permalink) Old 04-16-2007, 08:49 PM Thread Starter
Has anyone came up with a solution to the crappy clip that ford uses on the clutch master cylinder pushrod? I tried searching and came up with nothing. I need a fix i have a ton of slop in the clutch pedal. Help me out thanks
cincinnatijeepr is offline
post #2 of 9 (permalink) Old 04-17-2007, 09:18 PM Thread Starter
Re: Clutch master cylinder pushrod clip fix?
need to fix this problem in a bad way
post #3 of 9 (permalink) Old 04-18-2007, 11:20 PM
My Photos: (5)
Go to the nearest car quest and buy a new master cylinder. That's the only way I found.
2003 Excursion 4x4 Limited, 6.0 PSD
2014 F-350CC Lariat, DRW.
diesel_doctor is offline
post #4 of 9 (permalink) Old 04-18-2007, 11:56 PM
Banned
Wait for toyota to release their Diesel, then trade your Ford. The Toyota wont have these kind of design problems.....betcha.
Alabamatoy is offline
post #5 of 9 (permalink) Old 04-19-2007, 03:33 AM
Try removing the Spring on the clutch pedal and drive without it, or Take some wire and tie the clutch pedal back under the dash to limit the return SPIKE481
2002 F/350 Super Cab XLT Lariat trim 6spd SRW 4x4 3.73 posi 7.3 LUBERFINER 272-C AUXSILERAY OIL FILTER, MBRP 4"409 stainless steel exhaust AIS,
Spike481 is offline
post #6 of 9 (permalink) Old 04-19-2007, 05:00 PM
Dieselmaster's Avatar
My Photos: (18)
Is this what your talking about??
Click here
New Truck - 2002 Shadow Grey F250 CC SB - K&N FIPK - 4" Turbo out exhaust - Saving up for a lift and new tires.
Old Truck - 1999 F350 CC LB SRW 4x4 Lariat PSD - <font color="red"> Fire Red </font> ... 37" Goodyear MTR tires... APP Forged One Piece Wheels 17x9.5 ... DI 4-way Chip... ProComp Stage II 6.5" Dual Shock Lift... 4" Turbo out Exhaust... Trango Shift Kit....Armaliner Spray in Bedliner... Heater Core Bypass Mod.... ProComp big air intake system. DIS A-Piller Gauge POD - Autometer-Carbon Fiber gauge's - Pyrometer - Trans Temp - Boost...Gutted EBPV... Hutch Pre-tank & in Tank mods... Black Lab hair all over the back seat.
Dieselmaster is offline
post #7 of 9 (permalink) Old 04-19-2007, 06:42 PM Thread Starter
yea that looks like a good fix. It says to 98 trucks but my 99 has the same clutch rod clip problem. thanks
post #8 of 9 (permalink) Old 04-20-2007, 06:22 PM
Click here
I'm sorry I' having problems with the other end, the clip into the master cylinder, SPIKE481
Spike481 is offline
post #9 of 9 (permalink) Old 04-21-2007, 12:19 AM
hers the best solution. if you go &amp; buy a reman. clutch slave cyl. take it off &amp; if you have a vice then put it in the vise &amp; hold the rod outward while taking a very small screwdriver &amp; release the 3 small clips inside the piston bore &amp; it will pull apart. that if the hole in the rod where it attaches to the pedal isn't worn bad. you know you can get the whole kit w/ everything attached except the rod where you don't have to bother w/ bleeding it.its not that bad releasing the rod, just have to fight it a little. tilt the rod sideways while releasing them one at a time while you roll it around till it releases.
certified ford dealer 7.3L,6.0L & 6.4L diesel tech & foreman
dvtech is offline
