Clutch Pedal Sticking Down! - Diesel Forum - TheDieselStop.com
Old 09-19-2007, 10:29 PM   #1 (permalink)
Hi, My brother has my old truck. A 2002 aprox.125,000 4x4 Super Cab with 6sp. tranny. Today, he said the clutch pedal stuck down on him 4 times, and he would have to pull it back up with his toe. Each time it stuck down, the clutch was disengauged. The cluch seemed to work correct in relation to pedal position. Just the pedal sticking in the down position.
Could there be something in the master cylinder hanging, keeping the pedal from coming back up? The mechanicals of the pedal seem to move freely with no binding.
Thanks,
Brian
2004 Crew Cab FX4 Torqueshift. All Stock except EGR cooler is FIXED, Straight Piped, and a Coolant Filter, 146,000 miles
BrianAnderson is offline
Old 09-19-2007, 10:40 PM   #2 (permalink)
F350_6's Avatar
Re: Clutch Pedal Sticking Down!
It's most likely a master or slave cylinder issue. The spring on the clutch pedal will keep it in the down or up position if there is no resistance from the hydraulic assembly. This is of course assuming you are not dealing with a bent fork or something.
First thing is to check the reservoir and make sure it's not a low fluid issue. If there were no other symptoms or noises with the pedal problem then I would recommend replacing the master/slave assembly. You can buy a pre-bled unit from Ford for around $150 plus another $7 for the metal rod and clip that attaches to the pedal.
If you want instructions on how to change it let me know. It takes about 30 - 45 minutes the first time.
Chris
2002 F350 6-speed 444 CID. XLT, Heated Seat, 393,000 & counting.
“Good judgment comes from experience, and a lot of that comes from bad judgment.” Will Rogers
F350_6 is offline
Old 09-20-2007, 01:17 PM   #3 (permalink)
jjfertig's Avatar
I second the master/slave cylinder. Mine did the exact same thing while I was pulling a trailor from TX to PA. I had the dealer replace it for around 250-300. Can't quite remember exactly how much.
2000 F350 XLT PSD, 4x4, 6 speed manual, 110,000 miles, Luk clutch, upgraded clutch fork, Ranchhand Front-End Replacement, 05 Grille, Clear corner lights, Bushwacker Pocket-Style Flares, 08 bed/tailgate/lights, ztech spray-in bedliner, BFG 285/75/R16E, KC foglights, running boards, XM Radio, Viper alarm, Leer 100XL.
1987 F-350 crew cab, 6.9, 5 speed, 4x4, stock
Proudly serving in the USN
Freedom isn't free: but don't worry, the US military is picking up the tab
http://img.photobucket.com/albums/v4...g/DSC01181.jpg
http://img.photobucket.com/albums/v4...g/DSC01183.jpg
jjfertig is offline
Old 09-20-2007, 02:24 PM   #4 (permalink)
Ditto the above posts. Mine went south a few months back. It's a pretty easy DIY swap. If I remember right, the new master/slave assembly ran about $150.
2001 Cab and Chassis F350 SuperCab DRW 4x4. 7.3L. 6spd & manual xfer. snow plow pkg.
DirtFarmer is offline
Old 09-20-2007, 08:07 PM   #5 (permalink)
PStroked444's Avatar
YEP shoot for the hydrolics. You can change that out your self easyly. Good luck [img]/forums/images/%%GRAEMLIN_URL%%/cool.gif[/img]
99.5PSD, F250, 4x4, wht. CC, SB, Line-X, 200K+ , 6spd,LUK Ceramic Clutch, Warn Premium hubs, DP Tuner F5 stock/high idle/40T/60T/80E/100hp, Casserly STG1 sticks, DIY TYMAR, No EBPV, 08 Diff Cover, 4"MBRP S/S, Banks wheel*traded for stock wheel*, ATS Housing, HXLine, Zoodad Mod, CCV Mod, AIH removed, Shimmed fuel, Isspro Boost Guage & Pyro Guage, 2" Level Kit, Firestone Air Support Springs, BFG AT k/o, CB Galaxy DX949, DUAL Antennas, Lead Foot came stock
1998-F150 4x4, LB, K&N, No Kitty, 24LB inj, CB...Wifes ride.
94 Mustang GT, Red, Black Saleen rims, T-5, intake, exhaust, cam, 24LB squirts, tuned, last of the 302...
PStroked444 is offline
Old 09-23-2007, 02:57 AM   #6 (permalink)
I put the new hydraulic system on. Was not a bad job. I had more trouble getting the clutch switch off than anything else. Time will tell if that was the problem.
Also $140.00 after tax from Ford, that is pre-bled system with New pushrod and clip that attaches to pedal.
Thanks,
Brian
