Code Reader In California - Diesel Forum - TheDieselStop.com
Old 11-04-2009, 01:12 PM   #1 (permalink)
As I stated in my post yesterday, my service engine soon light came on. I have been unemployed since Feb, so I don't have money to go to the dealer or buy a programmer. Does anyone know if part supply house's pull codes for free, or is anyone close to Hollister, that can pull my code? Thanks!!!
GWJ1 is offline
Old 11-04-2009, 01:51 PM   #2 (permalink)
aekrogh's Avatar
Most Transmission shops, such as AAMCO and the like will pull your codes for free, also Midas muffler and brake shops will do it for free. I would just call around, most of your local mom and pop places will help you out if you are nice and respectful.
Late 99 SD PS CC SB 4x4 Lariat. 7.3l TS 6xchip Stock-140hp , Banks 6gun, Full Banks Gauges, 4"SS turbo back exhaust, UMP Intake w/ Donaldson Filter, Auburn posi F&R 3.73, ATS Trans W/ 5Star converter and CoPilot, 18k trans cooler, Dynatrac FreeSpin front hub kit, ITP oil X over, ITP boost regulator, Aero Fuel Tanks Replacement 55 Gallon tank, New timing cover,oil pan,oil cooler, water pump,turbo petastel, reman HPOP, new fuel filter housing, slotted brakes all 4 corners W/ Ceramic pads, Adjustable trac-bar, Front 1.5" level kit only. 226,000 miles 10/1/09 Best mpg 27.3..Norm city 15 mpg hwy 20+
Early 99 CC LB 2WD Manual 6....Stock 228k (11/09) and running strong, only repairs Clutch, water pump, alternator. K&N FIPK since 36k and loving it!
2006 CC LB 4WD Lariat 6.0l 5R110 Stock 178k (12/09) "Dad's" 3 injectors and GP harness(12/09) Dynatrac Ball Joints, New ERG and 2 injectors (6/10)
aekrogh is offline
Old 11-04-2009, 03:03 PM   #3 (permalink)
Thanks for you response!!
GWJ1 is offline
Old 11-04-2009, 08:02 PM   #4 (permalink)
If you have trouble finding somewhere in Hollister, I'm in San Jose and have a Scan Gauge II that should read your codes - at least if they are engine codes, not sure it reads trans or abs codes...
gabeyd is offline
Old 11-04-2009, 10:25 PM   #5 (permalink)
gabeyd...thanks for the reply! If I can't find anyone I will take you up on that offer. Thanks!!
GWJ1 is offline
Old 11-04-2009, 11:39 PM   #6 (permalink)
jgarden's Avatar
I am in so cal with a code reader
TDS member #49 - 1999.5 (Built 4/26/99) White F350, CC, SRW, LWB, Lariat, AIC, 4R100 (4th transmission before 85k - gotta love this tranny), 6.0 trans cooler, manual shift 4wd, 3 inch leveling kit, KING reservoir shocks, 285-75-16 Bridgestone REVOs, Performance Friction Pads all around, Powerslot Cryo'd rotors in front, CD player, Infinity REF 6800CS speakers (front and rear), Garmin 2610 GPS (hardwired), 40/20/40 leather seats, heated turn signal- TT mirrors, Titan V hitch, weatherguard box, DP Tuner 4 Position chip (love it), AIS intake, Diesel Site CAC Boots, 4" Magnaflow exhaust, Diesel Innovations Up Pipe, gutted EBPV, Non EBPV Turbo Pedestal, X-Monitor. NO STEERING WHEN BRAKES ARE APPLIED!
Jack
jgarden is offline
Old 11-04-2009, 11:42 PM   #7 (permalink)
Autozone will read it , but not delete it.
2000 Ford SD; PSD; Crew Cab; SB; Lariet; Air Lift suspension; K&N; Dynomax exhaust; ATS 88mm BB turbo; A-pillar three gage pod with Auto Meter pyro, boost and tranny temp gages; Prodigy brake controller; Rancho 9000 shocks; DP Tuner; 4R100 by Trans-Craft.
Willcamp2001 is offline
Old 11-05-2009, 12:53 AM   #8 (permalink)
There is an Auto Zone just up the street from me, I will give them a try!
GWJ1 is offline
