Codes po470 and po478 - Diesel Forum - TheDieselStop.com
post #1 of 6 (permalink) Old 02-14-2006, 02:04 PM Thread Starter
Does codes po470 and po478 cause the PCM to go into a default type mode.
1999 F250 PSD, CC, 4x4, Edge programmer
RAC400 is offline
post #2 of 6 (permalink) Old 02-14-2006, 04:43 PM
klhansen's Avatar
My Photos: (180)
Re: Codes po470 and po478
P0470 & P0478 shouldn't put the PCM in default mode. They don't light the SES light AFAIK. What kind of symptoms are you seeing?
P0470 - EBP - Exhaust back pressure sensor circuit malfunction
Causes: Biased sensor, open signal return
P0478 - EPR - Exhaust pressure control valve high input
Causes: Plugged sensor line, stuck butterfly, restricted exhaust
), AIS,
regulated return,
klhansen is offline
post #3 of 6 (permalink) Old 02-14-2006, 04:56 PM Thread Starter
Lack of power symptons. I replaced the sensor tube. After clearing the codes, They came back. There appears to be no restriction with exhaust and butterfly. Also, I have an earily 99 PSD, if it makes any difference with PCM
RAC400 is offline
post #4 of 6 (permalink) Old 02-14-2006, 05:05 PM
klhansen's Avatar
My Photos: (180)
Plugged CAT?
), AIS,
regulated return,
klhansen is offline
post #5 of 6 (permalink) Old 02-15-2006, 09:26 AM Thread Starter
That was what I thought it was originaly, plugged cat. But since have removed it and still have low power symptons and codes.
RAC400 is offline
post #6 of 6 (permalink) Old 03-05-2006, 10:30 PM Thread Starter
Update - I replaced the ebp sensor and no more codes and power is back. Apparantly the high or low reading of the ebps does something to the pcm that puts it in some sort of default mode.
RAC400 is offline
