Codes thrown- a few quick questions?
My truck started acting funny, check engine light, od light flashing, went to limp mode. I went home pulled the codes, p0123, p0221 & p0470. The first two are tps code which I am sure why it was acting funny. Do I need to change the pedal assenbly or is there something else I can do? As far as the exhaust backpressure code, new sensor, clean tube or because I gutted/unplugged the ebpv?
Post Extras:
Curt
1997 F350 cc/lb, 4x4, E4OD, 4.10, Pyro/Trans Temp/Boost Gauges. Torn apart- installing h2e, sd intercooler, bronco tank, bosch 044 fuel pump, dahl 150, regulated return, big oil, b codes.
