cold start - Diesel Forum - TheDieselStop.com
Old 01-11-2010, 02:27 PM   #1 (permalink)
cold start
My 02 7.3 starts great above 35 degrees, or when plugged in, but if not plugged in it fires and quits several times and then finally will start if you just touch accelerator, then it lobes badly, for about 30 seconds, did not do this when it had 60,000 miles,now it has 148,000 have been told it could be injectors, injector orings and/or glow plugs, sound awful expensive just to start replacing parts, any ideas?
greenmowerman@hotmail.com is offline
Old 01-11-2010, 02:55 PM   #2 (permalink)
Todes's Avatar
The first place to start is normally is with the glow plugs and GPR. Search the forums for Cold start and look for what others have done. From what I've seen its 8 times out of 10 the glow plugs or GPR.
Here is a good link Hard/No Start? Check here first.
7.3L Stroken 4 life!!!
2002 F-250 4x4 7.3L Powerstroke 205K(7/2011)
AIS Intake system, BFG KM 2 Mud Terrains new @ 184680mi (1/28/10), Cab Clearance Lights self install 4/17/10, Foil delete and new IC boots 4/24/10
Todes is offline
Old 01-11-2010, 02:58 PM   #3 (permalink)
tbpower's Avatar
test your glow plug system first: Hard/No Start? Check here first.
I had the same problem as you and my cure was to switch to rotella 5/40 syn. oil. You can get it in one gallon jugs at walmart.
2000 7.3 powerstroke. PHP 6 position chip (stock,high idle,60tow,80dd,100hp,no start) . 6637 riffraff filter kit . AIH delete. Oil crossover. 6.0 tranny cooler. In tank mods. Wicked Wheel. EBPV delete. Walker 21470 muffler. Riffraff FRX
tbpower is offline
