Which coolant? - Page 2 - Diesel Forum - TheDieselStop.com
Old 05-25-2006, 06:27 AM   #16 (permalink)
NCHornet's Avatar
Re: Which coolant?
Just went from Gold to Red last night. I sure am glad this stuff is good for 300K (800K with extender) because it is a long, long process.
NCH
2000 Ford F350 4X4 Auto,Crew Cab Lariat, Western Hauler Package, Long bed,
Isspro EV Guages on A-Pillar, Coolant change from Green to Gold to Red,
SCT XCalibrator2 with DP's 60 tow,80 econo,120 Race
Fumoto Valve, Marinco Mod, Homemade CCV MOD,Fuel Neck Mod, KMC Wheels at all 4's
Monroe Reflex Shoxs, SS/Kevlar Brake Lines,
FTVB from Greg Evans,Ford AIS Intake
Coolant filter,Walker BTM, Attwood Gooseneck ball flush mount,6.0 cooler, 2002 headlights & corners
Zoodad Mod,Cyro'd Powerslots and Hawks LTS Pads. 2005 front grill
Turbo Lifesaver, Infinity Refrence x4, powered by Infinity Reference amp, sounds awesome!!
Towing a 2005 HORNET 30BHSS 8500 LBS,
Stopping it with a Prodigy P3 Controller
Friends Don't Let Friends Drive Trucks With Generic Tunes!!
White Stroker
NCHornet is offline
Old 05-25-2006, 07:56 AM   #17 (permalink)
Re: Which coolant?
I know I've seen you all speak about which coolant to use but can't seem to find it. I have a 2000 EX 7.3 - ??????????
Houndog
Houndog, please listen to Gooch, he has the credentials(found in past posts). After reading ALL the coolant posts I have switched to an ELC, just makes sense. And trust me I have also researched the internet too.
Now you have a choice, as does everyone, again mine was Cat ELC.
Paul B
Re-read the post above mine(from Gooch) good info. Re-read my post above. I originally had the green, now red( not that color makes any difference). I too struggled with the choice. And I'm sure if you PM Gooch he will in all likely hood give you some starting points to read some of the dialogue on coolants.
Paul B
2001 Excursion Limited PSD,2wd,Auto. Toreador Red,10/2000,4.5 Racor,unTAGed,203*,DP-Tuner,AIS Filter,Riley Coolant Filter,6.0 cooler,Cat ELC,Son/Tri,Underdash Lunar Gauges,Hadley Air Horn,On Board Air,Fumoto,2006 31' Flagstaff TT 6.5K,Prodigy
2000 Honda CRV EX
PIC'S
pabrannan is offline
Old 05-25-2006, 10:32 PM   #18 (permalink)
Re: Which coolant?
OK so I have a 1994 7.3 Direct Injection Turbo the previous owner put in a new Radiator ... the coolant looks to be ORANGE and i got some on my hands feels real acidic what kind of coolant is this. He also gave me some extra coolant in a metal gas can I got the vibe that it couldnt be put in a plastic container or it would melt!!
(I might be crazy)...
What am i dealing with here
DebDies is offline
Old 05-26-2006, 01:43 AM   #19 (permalink)
Re: Which coolant?
I just changed my coolant tonight. Roger that on the long process. You fill and drain, fill and drain - forever to flush everything out. I used the gold coolant this time, next change WILL be to the ELC coolant.
As an aside, I hate showing up after the coolant party has already started. I would like to request an enhancement to this forum so that whenever a coolant discussion starts, I get a text message to my cell phone. I need advance notice so I can make the popcorn and open a beer before the fun starts.
2003 7.3 Excursion, Sylvania Silverstars, Fumoto Valve, Schaeffer 9000 oil, Ford AIS, Rancho RS9000X shocks - replaced with Bilsteins, Rancho steering stabilizer, Hellwig rear sway bar, Goodyear Wrangler Silent Armor tires, Mobil 1 *Mercon* ATF in transmission/transfer case, CCV mod - returned back to stock, more to come!
walt501 is offline
Old 05-26-2006, 09:50 AM   #20 (permalink)
Re: Which coolant?
Must be Dexcool. Get it out. Even if it isn't anything harmful, I'd still be changing out all the fluids (oil, trans, etc) just so I KNOW what's in the truck.
Imagine how much more "FUN" things would've gotten if Larry and Smokey had shown up!! [img]/ubbthreads/images/graemlins/wink.gif[/img] [img]/ubbthreads/images/graemlins/eek.gif[/img]
http://community.webshots.com/user/roadfrog
Cheers,
Chris
FOR SALE! 2002 F350 CC 4x4 SB Lariat Blue & Silver, General AT2 295/75/16's on 16x8 Panther Rims, KYB Monomax Shocks, Euro Style Tail Lights, billet fuel door, Putco chrome handles, Autometer Z Gauges & Pillar Pod, Billet Grill, Bullbar, JVC KD-AR870 head unit, Sirius, MEI Reference Series 600 Watt amp with 6.5" Alpine DD Drive F17C components front, 6.5" Jensen components in rear, Better Built truck box, auxiliary backup lamps, acetoned badges, blacked out lower weld seams, Dodge auto-dimming rearview mirror, Avital alarm system, heater by-pass mod, in-tank, harpoon and pre-pump mods, 5" SS exhaust tip.
2002 Acura el (only available in Canada)
2002 Fleetwood Wilderness 31G
1988 Campion Allante, 19.5' w/ Merc 5.7 litre
Roadfrog is offline
Old 05-26-2006, 12:57 PM   #21 (permalink)
Banned
Re: Which coolant?
The orange could be anything, Dexcool, Ford's specialty Orange, or even Chrysler's orange G-05. I'd flush.
International doesn't recommend ELC coolants in pre-2/2/99 engines (SN 940614). So in that '94 I'd use a conventional with SCA. A fully forumlated conventional (already precharged with SCA) would be my recommendation (Prestone Heavy Duty purple, Peak Fleet Charge, Fleetguard ES Compleat, etc.)
To speed up the flushing process, install one of those flushing "T's", pull the block drains and lower radiator hose. You'll get more of the "gunk" out, plus speed things up. You can finger tighten the plugs between flushes. It will be faster and more thorough in the long-run. [img]/ubbthreads/images/graemlins/smile.gif[/img]
Gooch is offline
Old 05-26-2006, 04:39 PM   #22 (permalink)
NCHornet's Avatar
Re: Which coolant?
Gooch,
No need to do that since I'm now good for a looooooooooong time!!!!
Thanks Man
I for one appreciate your knowledge and willingness to share it. I wish I never would have got sucked up in the gold hype!!!
Take Care
NCH
White Stroker
NCHornet is offline
Old 06-12-2006, 07:24 PM   #23 (permalink)
Re: Which coolant?
Gooch , For curiosity sake, what would the early 99 & before engines differ to render different coolant? My psd is a 99 but forget what door said for manf date.(I'll have to check, I thought it was an early)I was already to get the ELC untill I read above.
1999 E350 7.3psd , XLT , 15 pass/ext , purchased 6/6/05 w/255k on odo, 8/05 added BTM/straight pipe,5/06 BTS,1"shimmed front coil springs,Michelin XPS 235/85 16 R.,FredGroeske2"rear wheel spacers,1-1/2" rear sway bar,AIC,3 A-pillar guages, Tekonsha envoy,coolant filter,4 pos dp-tuner,In-tank mod & harpooned,dahl-100 prepumpfilter,Scan-guage,Bilstein shocks.
bork is offline
Old 06-12-2006, 07:55 PM   #24 (permalink)
Re: Which coolant?
early 99's have a cat and no air intake heater also diff air box.
01 f250 platinum,
itp fuel system,hx oil line,tn bb turbo,
swamps 200cc inj,gen 3, airaid intake.suncaost converter,shift kit magtech pan
mattrac is offline
Old 06-12-2006, 08:36 PM   #25 (permalink)
Banned
Re: Which coolant?
By bork:
According to International, who made your engine, ELC's can be incompatible with certain metallic and non-metallic materials in those earlier engines under some operating conditions.
Beginning 2/2/99 (SN 940614) International made changes to some internal material components to insure their compatibility with ELC. This includes seals, gaskets, injector cup material, sensors, and front cover.
There are lots of folks with older PSD's running ELC's without problems. But you'd be on your own there. I know of no issues with the 2/2/99-up builds. Keep in mind that the Gold coolant is an OAT-containing ELC as well.
Gooch is offline
Old 06-15-2006, 12:29 AM   #26 (permalink)
Re: Which coolant?
By bork:
The S/N # is in the vin or on the engine? or where?
bork is offline
Old 06-15-2006, 01:49 AM   #27 (permalink)
Banned
Re: Which coolant?
The engine serial number will be printed on a sticker on the driver's side valve cover, or it (along with the truck's VIN) will be stamped on the engine block on a little machined pad rear of the oil filter (also a great place to see if your engine VIN matches your truck's VIN). [img]/ubbthreads/images/graemlins/smile.gif[/img]
Gooch is offline
