Coolant Advice - Diesel Forum - TheDieselStop.com
post #1 of 16 (permalink) Old 11-05-2012, 11:19 AM Thread Starter
htrotte's Avatar
Coolant Advice
I know this has probably been covered extensivly but I am not very good at searches. I would like to change out the coolant in my 2002 7.3. Is there a good premix with SCA's already added that I can use?
2002 F250 XLT Crewcab, 7.3 Powerstroke, Auto, 181,000 as of 4/1/14
1989 F250 SuperCab 7.3 IDI, was C6, swapped to ZF5 3/20/09, 3.55 axle, 256,000 as of 4/1/14
htrotte is offline
post #2 of 16 (permalink) Old 11-05-2012, 12:47 PM
01f25073's Avatar
Totally flush your system and replace the coolant with a red coolant that is for diesels. Read the label on what you buy to know exactly which type you bought and the maintenance of that coolant. Research the coolant before you buy, because heavy duty elc coolants never need sca added to them and last a very long time.
2001 F-250 4X4 CC SB 7.3 4R100 3.73, BFGoodrich All-Terrain TA/KO, Motorcraft filters, Mile Marker manual hub locks w/ESOF (No hub "floating"), AIH delete, Rust-Oleum bed coating, Silverstar Ultra headlamps w/ clear headlight assemblies, 5,000K LED interior lamps; Moog greaseable u-joints, ball-joints, front hub assemblies; retractable bed hitch, original black CPS (BEST "mod" I have), Energy Suspension bushings, Red Heavy Duty ELC, Edge Evolution 15001 (for gauges), Walker BTM, Donaldson AIS
01f25073 is offline
post #3 of 16 (permalink) Old 11-05-2012, 12:59 PM
RT
RT's Avatar
Fleetcharge is a pre-charged coolant, but like 01f25073 says, I would use an ELC - which is usually a wonderful Aggie maroon color, except my roll tide friend says its Crimson - but what does he know...
Anyway, I found this link was a good read - scroll down to Gooch's post:
Coolant & SCA Additives!!
RT is offline
post #4 of 16 (permalink) Old 11-08-2012, 12:26 AM
Look for any coolant with a Cat-EC1 specification. I use a brand called Final Charge.
2001 F250 Lariat, crewcab, 2wd, 3.73ls, auto, 4" exhaust, BTS transmission and torque converter
LEMKE is offline
post #5 of 16 (permalink) Old 11-08-2012, 09:25 AM
After Saturday the winner gets to name that color for a year
2002 F250 7.3L PSD, bought new now at 202K miles, 4R100 Auto, Crew Cab, Short Bed, ITP Regulated Fuel Return system, ITP head to head SS oil cross over, Hutch in tank mod
Harpoon de tank vent, DIESELSITE Dahl 100 Pre-Pump Fuel Filter, DIESELSITE Return Fuel Line Cooler, DIESELSITE Engine Coolant Filter, DIESELSITE Auxilliary Transmission Cooler, DIESELSITE Gage Package, Pyro, Trans & Boost, Extreme Diesel AD injectors, Ford AIS Air Filter System, BTM straight through muffler, Moog Ball Joints, Rancho Shocks, Rotella ELC Coolant ,Stock Engine Program
Modified for I-Pod Connection
We b playing Scotland The Brave to Jimmy Hendrix
Oneof6 is offline
post #6 of 16 (permalink) Old 11-08-2012, 09:54 AM
RT
RT's Avatar
I'll bring the chips!
RT is offline
post #7 of 16 (permalink) Old 11-10-2012, 06:18 PM
RT
RT's Avatar
I just went out and checked - my coolant is definitely AGGIE MAROON!
Aggies WIN 29-24 - the Tide has rolled out...
RT is offline
post #8 of 16 (permalink) Old 11-10-2012, 08:35 PM
Mine turned MAROON today, it was a totally unexpected transition from Crimson to MAROON. One thing about a tide, it always rolls back in.
Oneof6 is offline
post #9 of 16 (permalink) Old 11-10-2012, 08:58 PM
RT
RT's Avatar
You're a good sport! The tide almost rolled back in after the first quarter. We can't seem to keep the momentum up much longer than that...
RT is offline
post #10 of 16 (permalink) Old 11-11-2012, 11:20 AM
A&M is having a decent season since they no longer have to deal with the tougher teams of the Big 12.
444-4D is offline
post #11 of 16 (permalink) Old 11-12-2012, 10:32 PM
tattoocharlie's Avatar
My Photos: (5)
i got a red elc from the local international dealer.....good for 150k after intial flush then 300k after second flush.
2002 f250 lariat 7.3 220k(motor has 190k)
original 4r100 tranny....220k and counting
knock on wood....
red elc good for 150k
4r100 1-2 2-3 3-4sonnax accumulator valves,.427 sonnax line pressure mod valve
4.125"yes thats 4 1/8" diy tymar intake(size matters...lol)
AIH delete,ccv delete,zoodad mod,
4" exhaust no muff
built my own leafs for 4.0 of lift!!!!!!
18" xd bronze revolvers with 325 nittos to wrap them
isspro pyro and boost guages on pillar mount....
tattoocharlie is offline
post #12 of 16 (permalink) Old 11-20-2012, 02:01 PM
My Photos: (24)
I've been using CAT EL-1 for 10 years in my 2001 F-250. I buy it at the local CAT dealer. Flush and refill the system several times with plain tap water, then drain completely and refill with straight distilled water (less than $1. a gallon at WalMart). Run the engine up to temperature between each refill cycle to be sure the thermostat opens. Better yet, take it for a short ride. Buy the concentrate, not the pre-diluted, and mix with 50% distilled water.
2001 F-250 (pcm PMT2) ISS Pro EV tranny, boost, pyro gauges. TS Performance flip chip. Banks MONSTER exhaust, Maghytec rear diff cover, ITP H/X kit, Whelan 52" Strobe Bar, Fisher 8.5' Snow Plow, 3 Weatherguard tool boxes. HUTCH fuel tank mods, REMANFACTURED Ford transmission.
CPSS is offline
post #13 of 16 (permalink) Old 11-20-2012, 03:55 PM
ReefBlue's Avatar
Caterpillar. Good for 300k, add a pint of stuff, good for another 300k.
Nationwide dealers, so you can always get support for it. What more would there need to be?
1999.5 F250 creeping up on 400k.
Check your wiring harness: Chaffed wiring at driver's valve cover.
Keep everyone (and yourself) updated:7.3 mileage and repair thread
If you insist on throwing parts at your truck to fix the problem, go big--don't forget the driver's side frame rail.
If your ICP connector has oil in it, change it. Don't argue, just change it. Don't check other things first, just change it.
ReefBlue is offline
post #14 of 16 (permalink) Old 01-04-2013, 10:45 PM
RT
RT's Avatar
It would appear having Crimson as your school color is bad for one's health!
Cotton Bowl final score
Texas A&M 41
OU 13
RT is offline
post #15 of 16 (permalink) Old 01-06-2013, 12:53 PM
RT
RT's Avatar
OK - Sorry about this guys, but I couldn't help myself:
New OU Helmet:
RT is offline
