Coolant leak - Diesel Forum - TheDieselStop.com
post #1 of 15 (permalink) Old 05-04-2006, 05:22 PM Thread Starter
Coolant leak
I have coolant leaking from somewhere, but I can't see where.
From under the truck I can see it coming around the balancer, but can't see exactly where, and can't get my hands in there to feel.
The seal around the water pump that I can see all looks good.
Should I assume that the seal is bad, and pull the water pump, or is there something else that you pros' recommend?
Thanks for your help and patience with a newbie.
Just checked the fluid on the ground again, and it's clear. Isn't the coolant supposed to be a reddish color?
2005 F350 4x4 crew cab short bed srw. Lariat package. MBRP 4" turbo back exhaust.
dits145 is offline
post #2 of 15 (permalink) Old 05-04-2006, 05:32 PM
Re: Coolant leak
If its clear, does it have an odor to it? If it doesn't have an odor, it could be coming from the air conditioner. If it has the antifreeze odor, then it is probably leaking from the weep hole on the water pump. Although, it could be traveling down from the lower radiator hose where it connects to the radiator. If you have the Extended life coolant, then yes, it should be a pale red. The standard coolant (non-elc) is green, but can turn to a rust color over time.
Y2K F250 CC PSD Auto, Short-bed Lariat, Woodland Green/Gold, ordered 07/10/99, born 09/12/99, delivered 10/08/99, BAK RollX bed cover, Bed mat, Zoodad mod, Viper Remote Start Alarm, Fumoto valve, undercoated, 149k somewhat trouble-free miles (so far) [never back to dealer for anything] , Edge Evolution (60 HP setting), Pioneer DVD/CD/iPod/XM satellite
Repairs: CPS, Water Separator Valve assembly, rear axle bearings, VSS, batteries, brakes, alternator, serpentine belt (x2) and tension pullies, all 4 power lock actuators, water pump, air conditioning lines and compressor, battery cables
2016 Subaru Outback (Wife's commuter car)
short_stuff is offline
post #3 of 15 (permalink) Old 05-04-2006, 05:54 PM Thread Starter
Re: Coolant leak
OK, I checked it with a napkin, and it is coolant.
A little more info.
This morning there was a small puddle. Drving around today, I checked every time I stopped somewhere, and there wasn't any leaks. When I came home and parked it, it was leaking, and is still leaking. It's not leaking real bad, but it is a steady drip.
dits145 is offline
post #4 of 15 (permalink) Old 05-04-2006, 05:58 PM
Re: Coolant leak
Unless you can see it running down the lower radiator hose, it is probably leaking at the water pump weep hole. One other place it could leak would be at the thermostat housing, but it is most likely the water pump. How many miles on your truck?
post #5 of 15 (permalink) Old 05-04-2006, 06:05 PM Thread Starter
Re: Coolant leak
Truck has 104,000 miles on it.
The leak is somewhere above the harmonic balancer, and leaking down the block. The lower hose doesn't have anything on it.
If it's leaking from the weep hole, does that mean it needs replaced?
dits145 is offline
post #6 of 15 (permalink) Old 05-04-2006, 06:20 PM
Re: Coolant leak
Yep, it means the clock is ticking. It will only get worse.
post #7 of 15 (permalink) Old 05-04-2006, 06:24 PM Thread Starter
Re: Coolant leak
Not exactly what I wanted to hear, but thanks for the help and fast responses.
I really appreciate it!
dits145 is offline
post #8 of 15 (permalink) Old 05-04-2006, 06:31 PM
Re: Coolant leak
sounds about the right amount of mileage for the pump to go bad i got about 110k out of each of mine i have put on my 96 but one area to check to make sure is the thermostat housing since those are very prove to leak as well and will travel the same route your coolant is taking as well, a lot cheaper to fix that than it is to do the pump........and if you do have to replace the pump i would recommend getting a 203deg t-stat and billet housing from dieselsite......
96 f-350 2wd dually powerstroke roach coach 365k BTS tranny,4.10, XLT,alcoa alloys,tymar intake,western diesel downpipe, a/c bypass mod,coolant filter behind front bumper, beans stage 1's,dp tuner 60hp pcm, hx hardline crossover from ITP......
01 f-350 dually powerstroke lariat supercab 61k 4.10 4x4 ESOF, leather, heated seats all the toys i dont need, 4r100,garret ball bearing turbo,tymar intake, ccv redirected out under the truck,magnaflow 4inch tuner exhaust, a/c bypass mod,zoodad mod,autometer cobalt pyro boost and tranny,dp tuner 4program chip,ITP complete regulated return fuel kit,ITP hx crossover hard line,203 t-stat and dieselsite billet t-stat neck, coolant filter,dieselsite high pressure intercooler boots
2009 F-450 dually 6.4 auto 4.30 2wd XLT power pedals,aux cab heater, dual alternators,bostonian catering body,stock everything for now......things to change soon
chris bottom is offline
post #9 of 15 (permalink) Old 05-04-2006, 06:34 PM
Re: Coolant leak
If you're much of a diy'er, you can do the water pump yourself. There's some good info on this site with detailed instructions. I would buy a new water pump, though. I've gotten burnt by remanufactured pumps on other vehicles, so I'll pay the extra money to have a better chance that I won't have water pump problems in the future. While you're at it, it would be a good time to change out the thermostat housing and thermostat, and change your hoses. Replace the upper hose with the hose for a dual alternator set-up. It routes it around the serpentine belt, instead of through it.
I haven't done mine yet, but I'm watching real close so that I can do it BEFORE I'm on a long road trip.
Good luck. [img]/ubbthreads/images/graemlins/smokin.gif[/img]
post #10 of 15 (permalink) Old 05-04-2006, 07:53 PM
Pappy19's Avatar
My Photos: (6)
Re: Coolant leak
Get a new water pump and new ambulance hose from our sponser, www.powerstrokeshop.com and a 203 'stat and aluminum tube from www.dieselsite.com (Bob Riley); you're good to go.
2002 F-350 SRW Lariat,4X4, PSD with too many goodies to list. 182k and a very strong 7.3. SOLD
2008 F-250, SC Lariat, 4X4,Shortbed, Pueblo Gold/black, V-10, 4.10, auto, Delivered on 9/7/07, great looking rig. South Texas bumpers front/rear, Air Raid Intake System, Diablosport Predator, Magnaflow, Husky's, JJ's, Ford alarm/remote start, Marathon seat covers, Sirius, PIAA, Access cover, Weatherguard tool box, Rhino liner, Michelins, Duraflap mud flaps, Escort 9500i, MagHytec rear dif cover.
2007 Lincoln LT (wifer's grocery getter),Superchip,Magnaflow duels, K&N dropin, Leer Browning Special
1996 Ford Bronco EB; almost stock
2007 Kubota 900 RTV diesel with goodies.
Pappy19 is offline
post #11 of 15 (permalink) Old 05-04-2006, 08:02 PM
klhansen's Avatar
My Photos: (180)
Re: Coolant leak
Not to steal a recommendation from powerstrokeshop.com, but Bob Riley can fix you up with the whole package. He has new water pumps for a good price as well as the hose, 203 t'stat, and housing. I got my stuff from Bob when my WP went bad.
), AIS,
regulated return,
klhansen is offline
post #12 of 15 (permalink) Old 05-05-2006, 04:39 AM
Re: Coolant leak
water pump replacement walkthrough:
http://www.thedieselstop.com/content...%20Replacement
Ryan Arthur
2000 F350 7.3 CC LB DRW 4x4 4R100 4.10 Lariat
ISSPRO gauges, DIY Tymar, straight piped, ITP boost regulator and tee, ATS ported housing, Banks Big Head, CCV Mod, DP-Tuner flip chip, BTS valve body |||
taillights/running boards/mirrors/rear, side lights wired as turn signals, upgraded headlight harness w/ Xtravisions,
no more dingers, newer cupholder, fumoto, C-Betrs, locking fuel cap, mud flaps, wannabe air horn, Line-X, behind-seat storage shelf, intercooler foil wrap removed, SS HPX
ryaneverk2 is offline
post #13 of 15 (permalink) Old 05-05-2006, 02:31 PM
Re: Coolant leak
My truck has 134K on it and has had that same exact drip for about 2 mos now. I have bought all the above supplies and am readying for a free weekend to do the work. Since the leak is small I keep topping of the fluid once a week hoping the bearing doesn't freeze up. All the instructions on this site makes the job a slam dunk.
Late '99, F-250 7.3L, PSD, Super Duty, AT, 4X4, Crew Cab, 235 Mich tires, MBRP 4" Exhaust, 4-setting DP-Tuner (set for +80hp Econ mode), K&N Filter and Intake Tube, 203 thermostat, coolant filter, A-Pillar Isspro gauge set (pyro pre-turbo, trans temp, boost), Turbo Master Wastegate Controller, 6.0L tranny cooler, BTS valve body, rebuilt trans at 196K mi, bilstein shocks, Chevron Delo 400 10-40w, Zoodad mod, late model cup holder.
No time left for Drinking.
jdkluge is offline
post #14 of 15 (permalink) Old 05-06-2006, 11:03 AM
Re: Coolant leak
A little more info.
check where the lower water pump kneck bolts to the pump. i had a steady drip on my truck when it was parked cold. as soon as it heated up the o-ring would expand and the leak would stop.
its around 7 bucks for the o-ring and 2 10mm bolts to take the kneck off.
1999.5 (5/99) F-350 SC, LB, ZF-6, 4X4: ATS Compressor Housing, BBH, K&N FIPK & Drycharger, DP Tunes 60T, Isspro Pyro & Boost, 4" MBRP & Delete Pipe, AD's (for now) ITP HPX, OBA & Reg Return, AIH Delete, Oil Guard, Couple Dongles
Oil Pan @ 133,000
PSN rocks my world
ITowBoats is offline
post #15 of 15 (permalink) Old 05-06-2006, 09:30 PM Thread Starter
Re: Coolant leak
Thanks to all who replied.
Unfortunately I couldn't wait to order the parts, so I had to get what I could from Oreillys'.
I decided to replace the cps while I had everything apart. Got it all put back together without problems.
Again thank you all.
dits145 is offline
