Coolant in oil and fuel in coolant - Diesel Forum - TheDieselStop.com
Old 11-22-2008, 10:55 AM   #1 (permalink)
On vacation & I need help! - Coolant in oil and fuel in coolant
My last four reports from Blackstone have shown steady increases in potassium and sodium. They are not sure if this is from coolant or my SVO conversion. I have been losing coolant at an increasing rate.
My coolant has been clean and has not had any oil or fuel in it until yesterday.
There is 1/2" of diesel floating on top in the degas bottle. I've read that injector cups are likely the problem.
Questions
Are these two issues related?
Head gasket?
Cracked head?
The engine has 220,000 miles. It has had an easy life with little towing until now. I'm currently on vaction pulling a 10,000 pound trailer for the first time.
More questions
What kind of damage would be caused by driving 100 miles back home?
-I know diesel eats the rubber hoses, but what else?
How much worse would it be to pull the trailer with these issues?
Thank you.
Early 99 (3/98) F-250 CC SB 4WD XLT , AIS, ISSPRO pyro, boost, and trans gauges, coolant filter
av8orr is offline
Old 11-22-2008, 05:24 PM   #2 (permalink)
klhansen's Avatar
My Photos: (169)
You should get it checked out and fixed. What will happen if an injector cup is cracked is that the coolant will eventually fill with fuel and puke out of the cap. While that's just a mess, and shouldn't cause catastrophic damage, there's also the possibility that coolant will get into the fuel rail inside the heads and get sent thru the injectors. They don't like water or coolant at all and will be damaged (maybe not right away).
Coolant in oil is most likely caused by leaks at the oil cooler, although more serious problems, like head gaskets or cracks could cause that too.
Good luck with it.
Hard or no-start? Check Here
klhansen is offline
Old 11-22-2008, 08:08 PM   #3 (permalink)
Thanks for the reply.
How does coolant get into the fuel rails?
av8orr is offline
Old 01-06-2009, 09:44 PM   #4 (permalink)
When the engine is running the fuel system has more pressure than coolant- fuel transferred into coolant system. When its shutdown the coolant system has more pressure than fuel system - coolant transferred into fuel system. They can exchange fluids via crack in injector cups common to both systems.
Two ideas when combined together will always make a third better idea!
I don't have to be wrong for you to be right.
Kent
@235K miles @ 071127
>202K miles @ 070828
2001 F350 7.3 PSD SD CC DRW Lariat, 4R100 (replaced at 41k w/rebuilt by dealer), 3.73, FX4 ESOF, Long Box - 3rd CPS. CPS in Glove Box MOD. K&N Filter. 6.0 OTA Cooler. Green to Red Coolant. Water filter. 203º T-stat. Fumoto Valve. Monroe Gasmatic Shocks.
techkdb is offline
