I have a 2000 F350 and I just changed my ATF using the FAQ procedures and all went well. I'm a little confused, however, about the correct way to check the level. If I go out in the morning and check it cold, the hatches in the "Cold" area of the dipstick are filled but no higher. I figured that's good. Well, when the tranny is at op temp with the engine idling and in Park, the fluid is nowhere to be found on the stick. When I turn off the truck, I can hear fluid running into the pan and when I check again, I once again have fluid on the stick.
Do I have enough fluid in the system? What's the correct procedure for checking the level?
Thanks in advance,
-Brian
BLUEMAXCO
2000 F-350 Lariat, 7.3L PSD, Crew Cab, LWB, SRW, 4 SPD Auto, Leather Capts. Chairs, Trailer Tow Pkg, TT Mirrors, Camper package, All stock but hopeful.
The fluid needs to be checked with the engine running and after you have slowly cycled throught the gears.
It can be checked cold, but engine must be idling.
Obviously the hot check is the most accurate of where you need to be.
It sounds like you are checking cold without the engine runnin, this, alot of the fluid has drained back to the pan, and so you are showing good - but as soon as you start the trick, the fluid gets pumped into all the channels and coolers and filter, and it will show lower then the "off" measurement.
Drive about 30 miles, stop, cycle through the gears slowly, put in park - engine still running, remove, clean, and replace dipstick - remove again and take reading.
__________________ 99.5 F-250 CC LB 4x4 7.3 Red New Pics 1/5/10
Trail Boss Replacement Bumpers, Tool Box, Headache Rack, Full Length Running Boards, Bilstien Shocks, BFG AT/KO 285/75x16E, 2003 Cup Holder, Marinco Heater Plug, Weather Tech Rain Vents / Hood Guard, B&W GN Hitch, X-Springs, Rear 4" F350 Blocks, Hellwig front and rear sway bars, Timbrens, Duraflaps
