cost to replace turbo - Diesel Forum - TheDieselStop.com
post #1 of 11 (permalink) Old 03-17-2011, 03:05 PM Thread Starter
Hey all, 2 Quick questions I'm in CT and have an 02:
1. excluding the cost of the turbo, what should be the approximate cost to swap out a direct replacement turbo?
2. How do I know if the turbo really needs to be replace and I'm not just getting jerked around?
Ravenscliff is offline
post #2 of 11 (permalink) Old 03-17-2011, 03:28 PM
schlepprock379's Avatar
What issues/symptoms are you having?
99.5 F-250 Super Duty w/7.3 Powerstroke
4X4 Short Bed/Crew Cab
Magnaflow 4" Turbo back SS Exhaust/5" Tip
DP-Tuner>No-Start,Stock,High Idle,60HP Tow,Decel,80HP Econo,120HP Race,Lope Idle
ATS Housing
HPX Crossover
AIH Delete
Autometer Ultralite Series Gauges(Boost,Pyro,Trans)
Bellowed Uppipes
Rancho RS 5000"s
DIY Tymar/6637
Custom/Spicer Driveline
B.T.S. Valve body
AIH Delete
OverBoost Annihilator
6.0 Trans.cooler
Under construction!
schlepprock379 is offline
post #3 of 11 (permalink) Old 03-17-2011, 04:47 PM Thread Starter
I've been having an issue of the EGT going up and my boost going to 0. I've had a couple fellas on here say that it could be a leak in the cold air pipes or boots, but the gut at he shop thinks it is the turbo. It isn't making any noise, and as long as I'm not pulling a load on jumping on the fuel pedal it will increase in speed. I took it to the shop and they said turbo, I need my truck for use on the farm, but I don't want to get rammed either. If it is the turbo then okay, but if it is something else like the boots or pipe I don't want to pay to have a turbo put on.
post #4 of 11 (permalink) Old 03-17-2011, 04:59 PM
lariat 7.3's Avatar
Send a message via AIM to lariat 7.3
pull your intake pipe and check the shaft for play there should be a tad bit of play in it. if it building boost then drops to zero i think you have a leak somewhere that just lets go at a certain amount of boost. if your turbo was toast it'd be pretty obvious, either smoke out the exhaust or itd be making some noise
2000 f 250 4x4. ccsb
just hit 218,000
38R with Turbo Master
238/80% hybrids
Riff Raff FRx
5 inch miter cut stack
remote start.
Autometer C2 series gauges.
5.5 inch lift with blocks and shackle drops
DIESELSITE HEAVYDUTY BOOTS ALL AROUND.
ITP in tank kit-awesome! frame mounted pre-filter
20 in diamo rims-33in toyo A/T
DP-TUNER F6- no start,stock,60 tow codes, 80E codes, 120 race codes
DIY TYMAR with donaldson filter.
AIH cut off
hood insulation removed
always bright overhead display
05 style headlights with 14k HID'S
08 leather front seats
bypass oil system
running on WMO!
DIESEL SITE coolant filtration
Denso HT gear reduction starter. Soo fast!!!
Wish List..... BTS....Stage 3 hybrids.... Push rods and Spings!!
lariat 7.3 is offline
post #5 of 11 (permalink) Old 03-17-2011, 05:15 PM
You can replace the turbo yourself in a few hours. Not a bad job. I R&R mine 2x. Once when I replaced the turbo, second when I replaced my up-pipes and rebuilt my pedestal. Really not a bad job at all.
2002 F-250 XLT PSD 4x4 CC LB.
285/75/16 BFG Allterrains.
GTP38R BB Turbo.
AIS intake.
ISSPRO EV Gauges: Pyro, Boost, Trans temp.
4" MBRP turbo back.
DP Tuner: 1,200HI, 80E, 120R, 80tow, 60tow.
Overboost Annihilator.
ISSPRO Turbo Temp Monitor.
IH Bellowed up-pipes.
BTS 4R100. -10/11/2010
diablo53 is offline
post #6 of 11 (permalink) Old 03-17-2011, 05:40 PM Thread Starter
Thanks for the info, I was hoping someone could tell me how many hours the book say that it should take. I don't think it is the turbo either. It does rebuild boost and it isn't making any noise or blowing smoke. Due to just having ankle surgery I will not be able to get under the hood to do any work on it for at least 6 weeks, and I'm not sure that I feel confident enough to change it out myself. I took the truck to a local shop that does work on Diesel trucks, I would have taken to the dealer, but if it is the turbo, I don't think they will put on anything but a ford reman. If it is the turbo I'd like to put the Garrett BB on it. Maybe the best thing to do is take it from where it is and drop it off at the dealership to get a second opinion?
post #7 of 11 (permalink) Old 03-17-2011, 05:58 PM
My Photos: (19)
If you can build boost, at any point, your turbo isn't bad. I would maybe look at the wastegate, make sure that the actuator isn't letting the exhaust through when it shouldn't be. Pull the vacuum line to it and wire it shut.
Also, have them pull the intake to the turbo and show you that the shaft has play and that the compressor wheel is contacting the housing. Chances are, it's not.
Then have them put a set of dieselsite boots (all 6) on the CAC tubes and intakes.
DP-Tuner 80T, 160cc single shots, GTP38R turbo, Ceramic coated IH up-pipes, coolant filter, 6637, DIY exhaust brake, openair CCV, propane, SBC DD all ceramic clutch, ISSPRO EV boost/pyro/HPOP pres./rear end temp, 4" lift, traction bars, 255/70R22.5 tires, York air compressor, 16 flashy lights, 12 strobes, 12 switches on console, 9 switches on the dash, 7 two-way radios, 5 air horns, laptop, siren, 105 gal. in-bed fuel tank, Kennesaw Mountain front bumper
'86 H-D Sportster - 16" apes, custom paint, custom pipes to fishtails, single fire ignition, leather saddle bags on custom brackets, bagger fender, solo seat, home made luggage rack, all LED rear lights
BTBBT is offline
post #8 of 11 (permalink) Old 03-17-2011, 07:03 PM Thread Starter
Thanks BTBBT, Are the dieselsite boots speical boots? and where do I get them?
post #9 of 11 (permalink) Old 03-17-2011, 08:09 PM
RT
RT's Avatar
Turbo - remove and replace - 2.4 hours
The dieselsite boots don't ooze oil vapor like the stock ones do - it will make for a less greasy engine - you get them at http://www.dieselsite.com/index.asp?...S&Category=627
HA HA HA HA - that was a good one. Now seriously, though...
RT is offline
post #10 of 11 (permalink) Old 03-17-2011, 08:54 PM Thread Starter
thanks RT
post #11 of 11 (permalink) Old 03-18-2011, 09:25 AM
SmokeyWren's Avatar
My Photos: (45)
Yeah, it sounds like you have a bad leak around at least one of the boots in the intercooler tubes. Remove the boots, clean them up squeeky clean, clean the metal tubes at the contact points squeeky clean too. Then put it all back together and tighten the band clamps very tight. That should fix it. You don't need different boots (rubber tubes and new clamps) unless you insist on a squeeky clean engine compartment with no oil mist that attracts dust and turns it into greasy gunk.
But if you want the squeeky clean engine compartment without that oil mist gunk coating the intercooler tubes, then spend the big bucks with Bob Riley's www.dieselsite.com or other vendor that sells the better intercooler boots and clamps.
SmokeyWren is offline
