Go Back   Diesel Forum - The Diesel Stop.com > 1999-2007 Super Duties > 7.3L Power Stroke Engine and Drivetrain
7.3L Power Stroke Engine and Drivetrain Discussion of the 7.3L Power Stroke diesel engine and drivetrain in the 1999-Up Super Duty trucks and Excursions. No gas engine discussion allowed except on transmissions and drivetrain that pertain to all models. Please confine discussion of topics in this forum to those items that are specific to the 7.3L Power Stroke engine.
Old 05-14-2008, 02:47 PM   #1 (permalink)
Supporting Member
detroitfd's Avatar
Steering problem - parts question
Hey guys-
I just replaced the end link bushings and sway bar bushings, which took care of the clunk that was there. I also replaced all 4 shocks and the steering dampener. My problem is that the steering is still not acting right.
During normal driving, when correcting during straight travel, the steering wheel takes longer than normal to react, and when it does, it oversteers a bit. I'm assuming the problem is my steering box (it's at FOMOCO now for a diagnosis).
Just wondering what's involved with replacing it. I saw the gear assembly on powerstrokeshop.com for $275 for $325 (Type I vs Type II).
Just wondering how hard the install is for a "backyard mechanic" in case they try to nail me with labor.
EDIT 5/15 : It's not the box, it's the right front ujoint locked up. This is causing the problem w steering. It also has a worn inner tie rod and drag link. See later post. Thanks
Thanks!
Jerry
My PSD X
2000 Excursion 7.3L PSD 4X4
DP-Tuner F5 : no start, stock, 40T, 80T, 80E - AutoMeter A pillar w/ 3 Phantom gauges - DIY Tymar intake w/ serviceable S&B filter - Zoodad mod - B&M HD Trans rebuild w/ TransGo Shift kit & Amsoil Fluid- BD Triple Disc Billet Torque Converter - Exhaust : 4" Turbo Back (w/ 4" down pipe) Stainless Steel Magnaflow - ATS housing and 4" intake sleeve - Turbo Master Wastegate Controller - Dieselsite HX Oil Crossover - Morse Ceramic brake pads - Monroe Reflex Shocks - Energy Suspension Bushings - IC foil wrap delete - Fumoto Oil Valve - 08' Aluminum Rear Differential Cover - White Night reverse light system - Garmin StreetPilot c340 GPS - 6.o tranny cooler - Dieselsite Coolant Filter - Amsoil Single Bypass Oil Filter w/ Rotella 5W40 synthetic oil - APC white gauge face - Dual in-dash DVD w/ Infinity Reference speakers & Blaupunkt 200A powered sub
TOWING:
2004 Dutchmen 31BH travel trailer
Last edited by detroitfd : 05-15-2008 at 02:49 PM. Reason: Wrong problem inquired about
detroitfd is offline
Old 05-14-2008, 07:03 PM   #2 (permalink)
Toptech's Avatar
Really it's pretty straight forward, just nuts & bolts. Although you will need a pitman arm puller. Be shore to clean the bolt threads and apply a little blue thread locker when going back together.
2002 F250 crew cab
Toptech is offline
Old 05-14-2008, 09:53 PM   #3 (permalink)
My Photos: (20)
Have you tried tightening up the steering with the adjustment screw on the steering box?
2001 F-250SD XLT 7.3 Auto 4X4,EXT-Cab,
Short Box,Black. Build date of 06/01
FORD AIS Severe Duty Intake with fender sleeve,
Triple A-Pod ISSPRO; Boost, Pyro, Trans gauges. Magnaflow 4" Exhaust
DP-Tuner 4Position chip; Stock,50hp tow
80hp econo, 120HP race.
SS HPOP Crossover
Dieselsite coolant filter
Fleetrite ELC Coolant
AIH Delete
Train horns from Hornblasters
Mobil1 ATF (old stuff)
Line-X Liner
((XM))).
http://photos.thedieselstop.com/show...0/ppuser/48942
DHDiesel73 is offline
Old 05-15-2008, 02:46 PM   #4 (permalink)
Supporting Member
detroitfd's Avatar
Yea, I did tighten the screw. Turns out I was wrong about the steering.
It's the right front U joint (per Ford AND a local shop) that's frozen. (FOMOCO wanted $500 for 1 ujoint - local shop wants $250 - ROFL) Also have worn drag link and inner tie rod.
What's the best brand to use? I see drastic differences in pricing for the rod and link. The local shop said I can wait on the tie rod and link, but the ujoint was causing the steering problem. So they're doing the ujoint now and I'd like to price the other stuff.
Best place to buy these? Thanks!
Jerry
My PSD X
TOWING:
Old 07-23-2008, 06:40 AM   #5 (permalink)
Jerry,
Im wondering if you ever got your steering fixed. The problem you described is the exact problem I am having - constantly having to correct steering while driving straight down a highway.
I have had 3 of 4 ball joints replaced (the 4th is ok verified by 2 sources), the pitman arm joint, new tires (Revos), adjusted and readjusted the steering box and had the steering column colapse joint welded to remove any possible loss of movement from being transferred from the steering wheel to the wheels.
During the front end alignment, a specialist increased the caster to 4.5 degrees and it all helps, but doesnt eliminate the problem.
About the only thing left is the steering box and rag joint.
Ideas on cost and complexity on DIY? Time? Special tools?
Thanks,
Bruce
Bruce & Carolyn Wittmeier
bruce.wittmeier@cox.net
2001 Ford F250 PSD, Ext cab, Shortbed, Island Blue/Silver, 4X4 Off-road, SOF Auto, Alum Wheels, Chrome Step, Line-X bedliner, Reese 16K slider, Jordan Ultima 2020, AirLift Airbags, Sunnybrook
Are you over weight?
wittmeba is offline
