So the transmission started going yesterday on my truck. Did a fluid and filter swap today to check things out and the old fluid was burnt and had a lot of metal in it.
Found a low mileage 4R100 out of a 2002 F250 for a really good price that will come with a warranty. Not sure yet if it's a 2wd or 4wd unit.
Couple of questions...
Is there a difference between the 2wd and 4wd 4R100's? (aside from the 4wd having a deeper pan and different filter)
Would a 2002 model 4R100 work in my 2000 model truck?
Thanks in advance.
__________________ Robert '00 Ford F250 4x4 PSD '89 Pontiac Turbo Trans Am
"Nitrous is like a hot girl with a STD. You know you wanna hit it, but you're scared of the results!!"
A 4R100 from a '99-'03 will work in your truck. I doubt the 2wd version will work but I suppose if you wanted to swap out the tail housing around you might be able to get it to work. You need to make sure it is a 4R100 out of a 7.3 diesel though.
Ken
