Cracked Timing Cover -- Help!! - Diesel Forum - TheDieselStop.com
post #1 of 7 (permalink) Old 03-01-2008, 04:26 PM Thread Starter
I just had a major oil leak from a crack in my timing cover right below the surface where the oil reservoir mounts on top. By the way, this is in a early 99' F-250 4x4. My question is two part: How hard is it to replace the timing cover (do i really need to pull the engine), and I also contemplated cleaning the crack really well and just applying JB Weld, i know this isn't probably recomended, but it was just a thought. Any suggestions and instructions would be helpful. FYI, i'm a pretty adventurous mechanic, just got finished pulling and replacing heads in chasis on the same truck, so i'll take on a challenge. Thanks for your help.
georgiadiesel is offline
post #2 of 7 (permalink) Old 03-01-2008, 09:16 PM
losfinch's Avatar
I don't think that you need to pull the motor...you will need to remove just about everything forward of the heads though. JB weld might be worth a try..I know i would do it in a pinch. How much is it actually leaking? I sure wouldn't want to spring a leak out in the middle of nowhere with a failed JB Weld job.
Early 99 F350 4X4 CC 7.3 Auto. A.R.E. Topper, bed carpet/bench inserts, Rhino grill guard, AIS w/sleeve, Fuel filler mod, GOS headlight harness, 02-04 Headlights, Rancho HD stabilizer, 06 Telescoping/heated mirrors with C-Btr Mirrors, Hella FF1000, Htr Bypass valve, front receiver hitch, Quadzilla XZT gauges, ITP Pre-pump/In-tank mods, Pioneer P5000UB w/XM radio, 4 Infinity Kappa 682.7cf, Fumoto valve, FIAMM Highway blaster horns, SS HPX, IDM mod, DP F5 (Stock,Drive-thru,60T,80E,120,80E-Mountain,1200), Walker BTM, RR, Dieselsite BRV, BTS Tranny, 26 row tranny cooler, Bilstein shocks, Amsoil bypass oil filter, Stancor HD Glow Plug Relay, billet thermostat housing, front & rear parking cameras, Aux reverse lights, Heated Seats.
Security: CrimeGuard Alarm with remote notification, DIY jimmi-jammers, door cylinder locks and linkage removed, padlocked rear bench seat hinge, PCM, DIY "pitstop" switch.
losfinch is offline
post #3 of 7 (permalink) Old 03-01-2008, 09:30 PM Thread Starter
it looks like i need to remove the oil pan, is this true?? If so, how hard is it to re-seal the oil pan in chasis? Is that a gasket or a silicone seal?
post #4 of 7 (permalink) Old 03-02-2008, 12:59 AM
Banned
The oil pump pick up is attached to the front cover... so, yes, the pan has to come off. Oil pan gasket is a bead of silicone.
I've heard of guys resealing the oil pan in chassis.... not my cup of tea.... I think it would be difficult to avoid applying too much or not getting a good seal.
GrampyJim is offline
post #5 of 7 (permalink) Old 03-02-2008, 01:19 AM
You have to pull the engine, no other way is possible.
David Lott
No purpose no happiness, know purpose know happiness
Worlds fastest 7.3 Power Stroke!!! 11.12@128.98 race truck 5805lbs
POWERSTROKE RACER is offline
post #6 of 7 (permalink) Old 03-02-2008, 10:57 PM Thread Starter
I'm really leaning toward the JB Weld job, but pulling the motor just to get the oil pan off and resealed, just to get the timing cover replaced would be a heck of a project. If i'm not mistaken, the oil inside the timing cover is under low pressure, if i really took my time cleaning the small crack on the timing cover, do you think it would hold with JB Weld?? Or am i just asking to be stranded in the middle of nowhere cause all my oil blew out. If that did happen, i'm pretty sure i wouldn't toast the engine, but merely the injectors would quit firing, right? please let me know what you think, i really can't decide how to repair this.
post #7 of 7 (permalink) Old 03-03-2008, 12:00 AM
Banned
At the risk of sounding bad.... there are several ways to "fix" this concern, only one of them is right... depends on your comfort level...
At the very least, you might want to pull the low pressure oil pump and inspect the housing in the front cover (the front cover is the "back" of the oil pump). If this is deeply scored, you may want to change the front cover (at your convenience) to avoid oil pressure or no start issues in the future.
