I have a problem with the the cracking of the transmission bell housing on my Powerstroke. Truck runs fine. It is on both sides starting at the bottom and going up the sides it is near the large end of the bell
Im trying to figure out what is causing this. The only mods i have made to this truck is the fuel tank pickup kit and the high pressure oil rail cross over hose. The transfer case failed a couple years ago and recently the rear driveline came off the back of the transfer case due to use of wrong bolts by a mechanic when the transfer case was replaced.
I do not race this truck or go tearing thru the woods with it. I occasionally pull a small 2 horse trailer with it. Its a 1999 F350 4X4 Powerstroke extended cab short box SRW. Did the transfer case and the driveline problems cause this? or is something more sinister going on even though the truck drives just fine.
Re: Cracking 4R100 bellhousing on 99 F350 Powerstroke
I would not rule out the Possibility of the drive line causing this, if the shaft was out of ballance this would cuase a lot of Vibration, which I would suspect you would feel, I Would take it to a shop tha can weld aluminum cast and get it reapaired promply, then keep a close Eye on it for continued growth.
This is not far from home...
Robert
Have Late 99 (4/17) XL psd 4X SC Dually, 4" t-409 turbo back exhaust, South Bend Dual Disk clutch Tunes By Bean, 533 hybrids Autometer A pillar setup Warn trans4mer/16.5 ti winch..37' Montana 5th wheel GCVW ..heavy and a B-@ss Boat
My Homies... http://nwforddiesel.com/
Was the truck ever hit in the front? I have seen transmission crack when the front axle gets pushed back slightly from a impact making the transfer case act as a lever snapping the transmission. All that energy gets transfered through the front drive shaft. Maybe some heavy off roading could cause this too.
FMT
[img]/ubbthreads/images/graemlins/shrug.gif[/img]
__________________ Excursion Pics
2000 Excursion Limited 4x4 Dark Satin Green Arizona Beige 7.3 DIT, AXDO, 3.73 LS, DP Tuner F5, TERMINATOR II w R-IPR, Adjustable Boost Regulator, Turbomaster, EBPV Delete, Air Dog, ITP Regulated Fuel Return, Fuel Cooler, Tags 1&2, Harpooned Tank, Magnaflow XL Exhaust w Aeroturbine 4040L, Sonnax/Tricumulator, 8 Autometer Sport Comp 4 Gauge A Pillar 4 Gauge Overhead, Ford APCM, Crimestopper Remote Starter With Remote Fast Idle, Ford AIS w Zoodad, W Code Front Modified B Code Rear springs, Rancho RS9000X, Rancho 5406 Stabilizer, Hellwig Rear Sway Bar, BFG Rugged Trail TA, V10 Trans Cooler w Dual Electric Pusher Fans, Coolant Filter, IAH Delete, (((XM))) Line Of Fire Light, Ford Cab Lights, 05 Headlights w GOS Conversion Harness, Jimmi Jammers, 03 Lighted Painted Tow Mirrors w C-BETR, PSD Badges, Pullrite Hitch, Prodigy Brake Controller, Born 01/29/00
Happened to my 99 when the drive line came apart at the t-case [img]/ubbthreads/images/graemlins/eek.gif[/img]. Going about 70 on I-5 in Washington [img]/ubbthreads/images/graemlins/phoney.gif[/img]! In the fast lane, bet I pissed some people off that night trying to get to the sholder [img]/ubbthreads/images/graemlins/mad.gif[/img]! Cost me a new trans, starter, and flywheel. I would see the guy who did the t-case [img]/ubbthreads/images/graemlins/wink.gif[/img]!
