Crank sensor recall - Diesel Forum - TheDieselStop.com
post #1 of 5 (permalink) Old 12-06-2007, 10:05 PM Thread Starter
mksmipalla's Avatar
Crank sensor recall
I don't know if this has been posted yet, but Ford has recall 99-03 7.3L crank shaft sensors. The old black sensor will be replaced with the new grey one. Sorry if this has been posted already.
2003 7.3 psd. 4" stainless exhaust,afe stage 2 intake,banks big head wastegate,zoodad mod,ccv mod,diablo programer,air intake heater delete,4.10 gear,cooling sys filter,hx crossover line, gauges,203* thermostate,brv.
mksmipalla is offline
post #2 of 5 (permalink) Old 12-06-2007, 10:42 PM
rmr
Re: Crank sensor recall
Does this include F250 + F350? The article I read did not mention these models, but it did mention E series vans, F450 , F550& Excursions.
http://www.msnbc.msn.com/id/22130914/?GT1=10645#
1986 F250,Regular cab,XL,4X4,6.9, 4 speed,
rmr is offline
post #3 of 5 (permalink) Old 12-06-2007, 11:08 PM Thread Starter
mksmipalla's Avatar
Yes. it includes F-series
post #4 of 5 (permalink) Old 12-07-2007, 12:48 AM
TO: All U.S. Ford and Lincoln Mercury Dealers
SUBJECT: Safety Recall 07S57:
Certain 1997 - 2003 F-Super Duty, Excursion, and E-Series Vehicles
Equipped with 7.3L Diesel Engines
Camshaft Position (CMP) Sensor Inspection / Replacement
AFFECTED VEHICLES
Vehicle Line Model Years Assembly Plant Production Dates
Econoline 1997-2003 Lorain Assembly Plant 4/3/1996 - 9/16/2003
Excursion 2000-2003 Kentucky Truck Plant 3/25/1999 - 11/1/2002
F650/750 Series 2000-2003 Cuautitlan Assembly Plant 1/20/1999 - 10/31/2002
F-Series 1997 Kentucky Truck Plant 6/18/1996 - 12/17/1997
F-Series 1997 Cuautitlan Assembly Plant 6/11/1996 - 12/10/1997
F-Series 1999-2003 Kentucky Truck Plant 9/3/1997 - 11/4/2002
F-Series 1999-2003 Cuautitlan Assembly Plant 10/2/1998 - 7/21/2003
Affected vehicles are identified in OASIS. In addition, for a list of vehicles assigned to your dealership, visit https://web.fsavinlists.dealerconnection.com . This information will be available on December 04, 2007.
REASON FOR THIS SAFETY RECALL
In some of the affected vehicles, the Camshaft Position (CMP) Sensor may fail due to circuit degradation. If the CMP Sensor should fail, the engine may stall. In the event of an engine stall, a crash could result without warning. A new CMP Sensor with improved reliability is now available.
SERVICE ACTION
Dealers are to inspect the CMP Sensor to verify which design level sensor is installed in the affected vehicles, and replace all prior level sensors. This service must be performed on affected vehicles at no charge to the vehicle owner.
OWNER NOTIFICATION MAILING SCHEDULE
Parts to repair this condition are currently not available in sufficient quantities to service all of the affected vehicles. Therefore, to ensure that an ample supply of parts is available, owners of affected vehicles will be notified in separate phase mailings over several months. Phase mailing will begin the week of December 17, 2007; prioritized by age of vehicle. Dealers should repair any affected vehicles that arrive at their dealerships, whether or not the customer has received a letter.
2005 F250 6.0 Automatic 4 wheel drive crew cab
LongLifer is offline
post #5 of 5 (permalink) Old 12-07-2007, 01:25 AM
It's the CPS. Ford is finally forced to do something about it. I wonder if they'll refund the money we have all spent on them over the years. Funny how I called the local ford Dealer today after I saw the press release on this and they said it will never be recalled.
2000 Ford F-250 SD; 7.3 PSD; Crew Cab; SB, SRW; Lariat; Air Lift suspension; Dynomax exhaust; ATS 88mm BB turbo; A-pillar three gauge pod with Auto Meter Pyro, Boost and tranny temp gages; Prodigy brake controller; Rancho XL9000 shocks; DP Tuner; 4R100 by Trans-Craft; B&M transmission pan, Mag-Hytec Differential cover; 160amp alternator
Willcamp2001 is offline
