Cranks but won't start - Page 2 - Diesel Forum - TheDieselStop.com
Old 02-26-2013, 04:14 PM   #16 (permalink)
tinman13kup's Avatar
$3900!!!???? Holy cow! You can purchase a new set of 8 for around $1200. They are not THAT difficult to put in, as long as you don't mind getting dirty for a day.
If it is diesel rated oil, I would find it hard to believe it destroyed all 8 injectors at the same time.
Tom
99.5 PS CC 4x4 SRW ZF-6
- AKA "The Big White Truck"
tinman13kup is offline   Reply With Quote
Old 02-26-2013, 07:07 PM   #17 (permalink)
rammertide07's Avatar
Send a message via MSN to rammertide07
Re: Cranks but won't start
I agree with tinman, even if it wasn't diesel rated oil. They each have their own wear. While ideally they are close, they are not the same. And the issue would have been noticeable before ALL 8 went out.
Sent from my DROID RAZR using AutoGuide App
2001 F350 7.3 4x4 CC SRW/ Aeroforce Interceptor/ BD Thruster II/ Bellowed Up-Pipes/ 4" turbo back straight exhaust / CCV Mod /DIY 6637/ TS chip reburned with PHP tunes (Stock, 40 Tow WITH Whsiper tune, 80 Daily Driver, 100 Race, 140 Extreme, 140 smoke show)//Recon smoked cab lights/MM Hubs/Hood/HPx/FRx/GPR switch-Indicator
First vehicle (still driving): 96 F250 XLT 2x4- All factory (injectors & turbo) except straight exhaust. 570k miles
7.3 Information Zip.File 29.66MB
rammertide07 is online now   Reply With Quote
Old 02-26-2013, 07:28 PM   #18 (permalink)
diesel dave 99's Avatar
Im thinking the thiner oil did not stay in the reavior and it drained out causing the issue.
diesel dave 99 is offline   Reply With Quote
Old 02-26-2013, 07:58 PM   #19 (permalink)
+1, I was going to say check the oil. Maybe the place that changed it messed something up and the new oil drain out.
The 5w-40 the op is talking about is the rotella synthetic, appears some missed that. There is nothing wrong with the oil used.
The thing that gets me is that the truck was perfectly fine before the oil change. To me, this means that the oil level might be too low to allow the truck to start. I would at least check the oil level. I would also check the hpop reservoir to see if anything is in there like DDave has mentioned. I doubt that something major has just went out.
Ford is on crack for what they want. However Ford retail on new injectors is $2-3xx plus they go by the book on labor. They are also on crack for thinking all injectors have failed.
I'm still betting its something simple and possibly silly enough thats being overlooked.
I will be watching to see what the cause is.
03 F350 7.3L Auto CC LB Dually 410's (LS Rear)
PHP/Beans tuned/250/100 FF inj's, BTS Tranny, Strictly Diesel complete fuel system with RR & FB delete, Pius LASB from Irate, Swamps HVHF IDM.
Autometer Nexus Guages, 4"MBRP, DieselSite Coolant filtration system/billet housing/HP X-Over line. Baldwin PA2818(6637) RR Boots/CBillet Plenums, ('06) 26 row Tranny & PS Cooler, LarryB's Genuine Denso Starter
INFRNL is offline   Reply With Quote
