Cranks a long time before starting - Diesel Forum - TheDieselStop.com
Old 01-28-2008, 10:50 AM   #1 (permalink)
My 1999 PSD seems to crank a long time before firing up. I am talking 4-5 seconds. Is that abnormal ? If so what do I do about it. I have had 1 other PSD (1997) and Cummins in the past and they always fired right up.
Thoughts ?
1999 F350 4x4 DRW Crew Cab LB 6sp manual - stock
perryt is offline   Reply With Quote
Old 01-28-2008, 01:39 PM   #2 (permalink)
What no comments yet ??
Old 01-28-2008, 01:50 PM   #3 (permalink)
klhansen's Avatar
My Photos: (175)
4-5 sec seems just a little long. Mine usually fires after 4-5 compression cycles (guessing 2-3 sec), but sometimes takes longer when it's real cold.
You might have a slight leak in your HP oil system that's delaying the pressure buildup to 500 psi before the injectors are activated. Or it might be a GP issue, which is easy to check. Go up to the FAQ subforum and take a look at the Hard/No Start thread.
If you have a scan tool that will monitor engine parameters, you can check the HP oil pressure by monitoring ICP while cranking.
Hard or no-start? Check Here
Old 01-28-2008, 02:40 PM   #4 (permalink)
chuck_norris is offline   Reply With Quote
Old 01-28-2008, 05:54 PM   #5 (permalink)
scrapin's Avatar
Fill your sig. in.. Where are you from, cold weather????? Being in a cold environment will affect it and the type of oil you are running in the cold weather. Try switching to a lighter oil if still experiencing hard starts
2008 F250 XLT 6.4 40k miles 4x4, , 3/04' 6.0 F350XL PSD 4x4 dually dump, moog ball joints, 9' min. mt.2 fisher plow----- 2001 F250 5.4 liter gasser 4x4
scrapin is offline   Reply With Quote
Old 01-28-2008, 06:10 PM   #6 (permalink)
Sorry about the Sig. I am in Kenmore, WA just north of Seattle. The starting issue happens regardless of weather though.
Old 01-28-2008, 06:55 PM   #7 (permalink)
johndeerebones's Avatar
Thoughts ?
My dad has a 2000 xl extended cab that has had a long crank since he had it, had 120k when he bought it, never dove into it, but I suspect HPOP oil system problems with it also. He had a no start hot problem. Obvious ipr ring problem, took it out and sure enough had a burnt out o ring, put a new ipr in it because he wan't to just replace the valve while he was there, starts fine hot, but still cranks long.
Only two possibilities if you ask me, low compression, or hpop build slow. I want to replace his hpop but he doesn't want to spend the jingle right now. He DOESN"T have low compression though, it starts fine no matter what the weather, just cranks long. Especially since I put the db electrical starter on, my 97 has always fired on about the second time around, can hardly turn loose of the key before it fires......
Sold, back when the snow was on... (Jan 2010!)
1997 PSD 3/4 ton 4x4 SC LWB SRW; 5 spd; 3:55; K&N open element/homemade intake; gutted EBPV piston, plugged hole; 3 in. downpipe; SCMT 1705; shimmed to 70 psi; 120,000; TTB DiPricol 0-60 white face boost gauge, DiPricol 0-1600 white face pyrometer, SOLD in between gauges for now; A-Pillar mount for now. DIY 160cc Injectors.DIY IDM mod. ValAir O-FE w/3400# plate; Front and rear tank filler neck mods
My Pics
Truck Pics -Updated-
johndeerebones is offline   Reply With Quote
Similar Threads
Long cranks LeRoy 99 & up 7.3L Power Stroke Engine and Drivetrain 1 08-19-2008 09:55 PM
cranks a little too long andrew974x4 Power Strokes 1994-1997 General 3 09-05-2006 12:36 PM
cranks over fast, but not starting rkfguard 99 & up 7.3L Power Stroke Engine and Drivetrain 56 02-10-2006 02:01 AM
Long cranking time before starting? DBlack1 99 & up 7.3L Power Stroke Engine and Drivetrain 3 01-15-2006 06:12 AM
Cranks long before starting johndeerebones Power Strokes 1994-1997 General 5 05-31-2005 08:56 PM
