cruise control - Diesel Forum - TheDieselStop.com
Old 01-02-2013, 09:05 AM   #1 (permalink)
Americandiesel9's Avatar
cruise control
My cruise control is not working the recall has already been done . I think the clutch safey switch is the problem cause the guy i got the truck from broke it off the rod the switch still works but you have to use your hand does any one know what wires on the plug controls the cruise? Also i have noticed the master cylinder is leaking in the cab? Possible cause?
SOLD BUT NOT FORGOTTEN 97 f350 cc lb 4x4 5 speed 260000 mostly stock 6in lift 37" Goodyear mud tires, k&n air filter, straight exhaust with 3" dp
2005 chevy 3500 duramax crewcab dually 4x4 270000 (sold)
1999 dodge 2500 club cab 24vcummins 4x4 auto 569000(sold)
2000 f250 7.3 4x4 6 speed single cab pretty much stock no muffler no cat with Diablo tuner 350000
Americandiesel9 is offline   Reply With Quote
Old 01-02-2013, 12:05 PM   #2 (permalink)
tattoocharlie's Avatar
My Photos: (5)
if the master cyl is leaking fluid in the cab its usually from the piston...leaks out the back and down the pushrod into the cab.....time for a new one
2002 f250 lariat 7.3 220k(motor has 190k)
original 4r100 tranny....220k and counting
knock on wood....
red elc good for 150k
4r100 1-2 2-3 3-4sonnax accumulator valves,.427 sonnax line pressure mod valve
4.125"yes thats 4 1/8" diy tymar intake(size matters...lol)
AIH delete,ccv delete,zoodad mod,
4" exhaust no muff
built my own leafs for 4.0 of lift!!!!!!
18" xd bronze revolvers with 325 nittos to wrap them
isspro pyro and boost guages on pillar mount....
tattoocharlie is offline   Reply With Quote
Old 01-02-2013, 12:40 PM   #3 (permalink)
I figured going to get one today but what about the cruise?
Old 01-02-2013, 01:02 PM   #4 (permalink)
dwright5460's Avatar
put it in neutral. can you start the truck without pushing down on the peddle? the reason I ask is both cluch safety swith and brake light swithch can keep it from working. Dave
early 99 F350 dually. Stock engine, PHP HYDRA CHIP, HPX crossover line, FPX fuel line w/gold spring 4" straight pipe muffler delete.
dwright5460 is offline   Reply With Quote
Old 01-02-2013, 02:35 PM   #5 (permalink)
My Photos: (19)
Putting a 6speed in neutral won't make a bit of difference for starting. There is no provision within the ZF to determine anything but reverse. If your clutch switch is off the pedal then that's what needs the attention. Unfortunately I don't know what wires do what. I do know that the switch itself is fairly simple. You may just take it apart and see what works.
DP-Tuner 80T, Stage I single shots, GTP38R turbo, Ceramic coated IH up-pipes, coolant filter, 6637, DIY exhaust brake, openair CCV, propane, SBC DD all ceramic clutch, ISSPRO EV boost/pyro/HPOP pres./rear end temp, 4" lift, traction bars, 255/70R22.5 tires, York air compressor, 16 flashy lights, 12 strobes, 12 switches on console, 9 switches on the dash, 7 two-way radios, 5 air horns, laptop, siren, 105 gal. in-bed fuel tank, Kennesaw Mountain front bumper
'86 H-D Sportster - 16" apes, custom paint, custom pipes to fishtails, single fire ignition, leather saddle bags on custom brackets, bagger fender, solo seat, home made luggage rack, all LED rear lights
BTBBT is online now   Reply With Quote
Old 01-02-2013, 03:34 PM   #6 (permalink)
You can move the switch my hand and it wont start slide it the other way and it will start. The reason i ask what wires is because i have heard the part of the switch can fail but the part that controls the starting will work fine
Old 01-02-2013, 05:03 PM   #7 (permalink)
my whole point was to make shure the truck thinks that the clutch is out for the cruise control to work
Old 01-02-2013, 06:48 PM   #8 (permalink)
klhansen's Avatar
My Photos: (175)
There are two separate switch circuits in the CPPS. One for starting closes when the pedal is pushed nearly to the floor, and the one for cruise disengagement closes (or opens) near the top of pedal travel. There are 6 terminals on the switch but only 4 of them are used. Unfortunately I don't remember which pair is which. They should be directly across from each other for each switch, however.
Hard or no-start? Check Here
Old 01-02-2013, 08:52 PM   #9 (permalink)
Thanks for the info guys
Old 01-03-2013, 12:58 AM   #10 (permalink)
klhansen's Avatar
My Photos: (175)
More info - The safety switch is the pair of terminals in the middle (numbered 1 and 2). Wire colors are white/pink on the hot side and dark blue/orange on the switched side. Cruise disengage switch is on pins 3 and 4, with red/yellow to the hot side and tan/lt blue on the switched side. Cruise switch is closed with the clutch engaged and open with the pedal down. The other 2 pins (5 and 6) are unused.
