Go Back   Diesel Forum - The Diesel Stop.com > 1999-2007 Super Duties > 7.3L Power Stroke Engine and Drivetrain
7.3L Power Stroke Engine and Drivetrain Discussion of the 7.3L Power Stroke diesel engine and drivetrain in the 1999-Up Super Duty trucks and Excursions. No gas engine discussion allowed except on transmissions and drivetrain that pertain to all models. Please confine discussion of topics in this forum to those items that are specific to the 7.3L Power Stroke engine.
Old 01-06-2009, 07:49 PM   #16 (permalink)
Originally Posted by Westin View Post
Looking at the hole its maybe the size of a tip of a pen. Any problem with doing a very small tack weld on it to just seal it without buying a new piece?
I would have already done it by now ...
Make sure you evac & recharge the system...
Rick.....
97 F 350 ...Lucky 13
"Most stuff's just stuck & needs hittin with a hammer"....
Supporter/End user of ShiftSolutions THE CURE E4/4R Trans Control. Helping Cancer patients and families
fordtransmissioncure.com
Special thanks to RacerX
Most people come here for the facts ...not a hug ...
action4478 is offline
Old 01-06-2009, 11:18 PM   #17 (permalink)
tattoocharlie's Avatar
My Photos: (5)
hey although itll cost a few bucks you get a quick welding lesson!!!!!just kidding i think weve all done stuff like that before,all you can do is laugh.well after its fixed and paid for.good luck
2002 f250 lariat 7.3 150k(motor has 100k)
4.125"yes thats 4 1/8" diy tymar intake(size matters...lol)
AIH delete,ccv delete,zoodad mod
4" exhaust no kitty or muff
4r100 1-2 2-3 3-4sonnax accumulator valves,.427 sonnax line pressure mod valve
fab fours bumper(winch ready)
built my own leafs for 4.0 of lift!!!!!!
18" xd bronze revolvers with 325 nittos to wrap them
isspro pyro and boost guages on pillar mount....
SMOKE EM IF YA GOTTEM!!!!!!!!!!!!!!!!
tattoocharlie is offline
Old 01-06-2009, 11:26 PM   #18 (permalink)
Bill1013's Avatar
Can I weld it ?
Sure you can. Seal it as quick as you can to keep moisture out. Don't weld it on the truck . Block the openings any way you can while it's off. Get a can of 134A and charge it partially until spring then dump that charge out, or have it pro-charged in the spring. Pull the plug on the A/C compressor, it will want to run when the defrosters are on .
My .04 cents worth,adjusted for inflation.
99.5 F350 XLT Lariat 4X4 AT 4.10 DW CC LB Centurion conversion Garret Turbo, Radio SD &Tape, 100 Gal.Transfer Flow W/Trimax Control Aux. fuel tank. ScanGaugeII, Boost, EGT, Trans. Temp. Oil Temp. Build date 03/99
92 F350 7.3 IDI CC LB dually Banks turbo US Gear O/U
1990 F350 XLT Lariat 7.3L IDI E4OD Dually 280K+ 2WD
Reman Promar Long Block 11/07
http://community.webshots.com/user/oldbull8?
Formally OLDBULL
Have AutoEnginuity W/Ford enhanced. Lima OH area.
My mind works lightening fast.
One flash and it's gone.
Bill1013 is offline
