diesel leaking into radiator - Diesel Forum - TheDieselStop.com
post #1 of 6 (permalink) Old 01-04-2007, 12:20 AM Thread Starter
Here is something very strange,there is a fuel leak somewhere but my mechanic cannot find where it is comming from,but there is a very strong smell of diesel fuel in my antifreeze resevoire,has anyone come across this before, any reponse would be grateful.Thanks
fedexjohn is offline
post #2 of 6 (permalink) Old 01-04-2007, 12:31 AM
My Photos: (5)
Re: diesel leaking into radiator
There are very limited possibilities:
1) cracked head allowing the internal fuel passage to communicate with the cooling system
2) leaking injector cup (loose, corroded, some combination of the two) allowing the fuel system to communicate with the cooling system.
#2 is the most likely.
AutoJim
Former Cooling Guy
'99.5 F350 Lariat CC SRW 4x2, 7.3L 4R100
'99 Mustang Cobra, SCCA Solo2 E Street Prepared
'97 Dodge Neon, SCCA ITA/STU/EP Club Racing
Now I do subsea ROV tooling.
AutoJim is offline
post #3 of 6 (permalink) Old 01-04-2007, 01:17 AM
Green coolant? have you been using your additive?
Walkers rule
TreeingWalker is offline
post #4 of 6 (permalink) Old 01-04-2007, 05:54 AM
CPUNeck's Avatar
My Photos: (13)
Hmmmm... not sure of the age of your truck, but if you haven't kept the SCA levels up, you may be experiencing the results of upper cylinder wall cavitation. [img]/ubbthreads/images/graemlins/phoney.gif[/img] [img]/ubbthreads/images/graemlins/vomit.gif[/img]
Early 99' Upgraded to 99.5' F250 XLT SWB PSD, 4x4, GPT38, EBPV Delete, Perf Friction 2-pcs rotors, 4" turbo back exh, Ford AIS, 6leaker OEM cooler, Htr Core by pass valve, Synthetic every fluid (Mobil), Detroit LOCKER, BTS, Lunar Autometer gauges, DP-F6C, 235k mi
CPUNeck is offline
post #5 of 6 (permalink) Old 01-04-2007, 07:50 AM
JimTJr's Avatar
My Photos: (20)
While this is a distinct possiblity, I have never HEARD of one doing this. (I KNOW it is possible, but I go with the above poster as the Injector cup being the MUCH more distinct possiblity) And lets hope it's so, a new injector cup, is much less costly than a block or sleeved cylinder,,,
Anyone know how many miles or how long it takes for the cavitation to eat thru a cylinder wall?
Jim T.*48* SLAPS Co-Founder, 30.8 yrs RETIRED UAW 6/01/06, Now an ART (Specialists Flight Chief) with the USAFR 414th MXS Seymour Johnson AFB.
New truck, 2011 F-350 SRW LB CC. White Platinum Lariat! 4x4
JimTJr is offline
post #6 of 6 (permalink) Old 01-04-2007, 01:07 PM
My Photos: (5)
The cavitation levels our trucks see are so low (really!) that it's EXCEPTIONALLY unlikely that you'd erode the bore boss in the block enough to get perforation in the lifetime of the truck.
Furthermore, any combustion gases going into the cooling system wouldn't produce a raw diesel trace, and would in fact push coolant out of the cooling system as the combustion pressures are a LOT higher than cooling system pressures.
AutoJim
Former Cooling Guy
AutoJim is offline
