Differential maintenance - Diesel Forum - TheDieselStop.com
Old 05-23-2006, 11:31 PM   #1 (permalink)
I recently purchased my first diesel, a '99 and am trying to make sure all maintenance issues are up to date. It's got 152000 miles on it. What do you recomend for differential gear oil?
'99 F250 Super Duty. 4 door extended cab. 4X2 with automatic transmission. 184918 miles. Tows 23' 5th wheel on steep mountain roads and 22' boat to salt water ramps from Long Beach CA to Ensenada MX.
9milecanyon is offline
Old 05-24-2006, 06:25 AM   #2 (permalink)
NCHornet's Avatar
Re: Differential maintenance
You need to fill out your sig and tell us what you have first.
NCH
2000 Ford F350 4X4 Auto,Crew Cab Lariat, Western Hauler Package, Long bed,
Isspro EV Guages on A-Pillar, Coolant change from Green to Gold to Red,
SCT XCalibrator2 with DP's 60 tow,80 econo,120 Race
Fumoto Valve, Marinco Mod, Homemade CCV MOD,Fuel Neck Mod, KMC Wheels at all 4's
Monroe Reflex Shoxs, SS/Kevlar Brake Lines,
FTVB from Greg Evans,Ford AIS Intake
Coolant filter,Walker BTM, Attwood Gooseneck ball flush mount,6.0 cooler, 2002 headlights & corners
Zoodad Mod,Cyro'd Powerslots and Hawks LTS Pads. 2005 front grill
Turbo Lifesaver, Infinity Refrence x4, powered by Infinity Reference amp, sounds awesome!!
Towing a 2005 HORNET 30BHSS 8500 LBS,
Stopping it with a Prodigy P3 Controller
Friends Don't Let Friends Drive Trucks With Generic Tunes!!
White Stroker
NCHornet is offline
Old 05-24-2006, 08:05 AM   #3 (permalink)
SmokeyWren's Avatar
My Photos: (44)
Ford now says you should use synthetic 75w140 gear lube in the rear axle of any '99-up SuperDuty pickup. It doesn't matter which brand, as long as it's synthetic and is 75w140. Motorcraft brand is good stuff. So is Mobil 1, Redline, AMSOIL, and several other brands.
When your pickup was new, Ford was requiring 75w140 synthetic in the rear axle of pickups with single rear wheels (SRW), but synthetic 75w90 in the pickups with dual rear wheels (DRW). But recently Ford decided that 75w140 synthetic was best for the rear diff in all SuperDuty pickups.
If your pickup is a 4x4, then it requires a different axle lube in the front diff - 75w90 synthetic or straight 90w synthetic. The key is synthetic. Don't buy the cheap stuff that is not synthetic.
If you don't have a handy source for synthetic gear lube, then I recommend you order what you need from Bob Riley at click here. Note that AMSOIL makes both the 75w140 for the rear end and the 75w90 for the front end.
SmokeyWren is offline
