Differential tag decoding - Diesel Forum - TheDieselStop.com
post #1 of 6 (permalink) Old 04-01-2010, 12:09 AM Thread Starter
Can anyone tell me how to decode my differential tag.
Top row: S 409 F
Bottom Row: 3L73 10 5 9J22
2000 F250 XLT, 7.3L, 6 speed manual, 2 wheel drive, extended cab, short bed
. The truck is for pulling our 24' Cougar 5th wheel and taking my sweetie and our 2 Italian Greyhounds on vacation.
pcatanza is offline
post #2 of 6 (permalink) Old 04-01-2010, 12:26 AM
chuckster57's Avatar
Here you go:
I had to update my bookmark so it took me a few minutes longer
Ford Rear Axle Assembly Identification - Page 13 - FORDification.com
Train Horns:
PM please not visitor message
chuckster57 is offline
post #3 of 6 (permalink) Old 04-01-2010, 12:29 AM
The only interesting parts of that are:
3L73 = 3.73 gear ratio with the factory "un"limited slip differential. Same as mine.
The rest is gobbly gook build numbers.
Good link, Chuckster.
2000 F250SD SCLB Lariat 4x4
450 cubes, fully studded, modified.
4R100 built by me with Suncoast/Transgo/Sonnax/Ford parts.
325/65/18 BFG A/Ts on Ultra rims, custom 4" lift with rear shackle flip(no blocks), Rancho 9000Xs, Homemade bypass fuel system, bypass oil filter, Racor CCV filter, 3.5/4/5 custom exhaust, 8 yr old DI 4 pos chip, and some other stuff.
22 year US Navy vet (retired)
ASE Master Auto Tech
stangrcr1 is offline
post #4 of 6 (permalink) Old 04-01-2010, 08:48 AM
SmokeyWren's Avatar
My Photos: (45)
Top row: S 409 F
Look at your truck. If it is a Ford '99-'03 SuperDuty pickup with single rear wheels (SRW) and a 7.3L diesel engine, then it has a Ford "Sterling" 10.5" rear axle. The "Sterling" means it was manufactured in the Ford axle plant in the little town of Sterling, Michigan.
The only numbers on the axle tag that mean anything to most of us is the "3L73 10 5" at the beginning of the second line. That tells you that you have a 3.73 axle ratio with limited slip and a 10.5" ring gear. If that code were "3 73 10 5", then you would have a 3.73 axle ratio without limited slip, and it would have the 10.5" ring gear.
On most of those axle tags, the first character is covered by a bolt head and/or gunky grease and dirt. So unless you remove the tag and clean it up, you might think it begins with L73 or just 73.
SmokeyWren is offline
post #5 of 6 (permalink) Old 04-01-2010, 10:08 AM Thread Starter
As usual, everyone is willing to share their vast knowledge.
I really appreciate all of the assistance.
Looks like I have a 3.73 axle ratio with limited slip and a 10.5" ring gear
We are pulling our 5th wheel to the beach in Aptos California tomorrow.
This is the first trip with this truck, so we will see how it pulls Pacheco Pass.
pcatanza is offline
post #6 of 6 (permalink) Old 04-01-2010, 02:25 PM
I predict you will have a pleasant experience on the pass. These trucks pull mountain passes with aplomb. I have 3.73 gears on my MY2000 and regularly pull Colorado passes heavily loaded towing with much joy.
Former Ford sensor engineer, 1991-1999
2000 F-350 CC Lariat PSD 4x4, AIS, AIC, BTM, Isspro EV2 gages, manual TC lockup, manual EBPV control, GPR LED monitor, DP-Tuner F6 with Drive-Thru, 60tow, Decel, 60econo, 80econo, 168k miles
1975 FJ-40 Land Cruiser, 350TBI, Muncie 465 trans, ARBs, York on-board air, 4-link rear suspension, Blazer tilt column, Mazda sport buckets, full roll cage, towed on 18' Big Tex trailer
1975 Denver Broncos Special Edition Ford Bronco
Victor is offline
