Does anybody have the Turbo Pedestal R&R instructions handy? - Diesel Forum - TheDieselStop.com
Old 12-22-2007, 12:50 AM   #1 (permalink)
It's been a couple years since I saw it, but there once was a detailed set of step-by-step instructions on how to remove & replace the turbo pedestal. I don't remember if it was active content or an external link.
The dealership has done a dye test for me on my truck (it has 88k miles) and my oil leak is coming from the turbo pedestal. I am going to replace it myself on the 26th.
It looks rather straightforward, and I remember that I should soak my clamps and bolts with penetrant overnight beforehand. I would just like to avoid that nearly-inevitable stupid mistake, if at all possible. [img]/forums/images/%%GRAEMLIN_URL%%/shocked.gif[/img] [img]/forums/images/%%GRAEMLIN_URL%%/crazy.gif[/img] [img]/forums/images/%%GRAEMLIN_URL%%/blush.gif[/img] [img]/forums/images/%%GRAEMLIN_URL%%/smirk.gif[/img] [img]/forums/images/%%GRAEMLIN_URL%%/wink.gif[/img] [img]/forums/images/%%GRAEMLIN_URL%%/grin.gif[/img]
"Nothing in life is so exhilarating as to be shot at without result." - Sir Winston Churchill
May your road stay clear & dry, may your fuel never gel, and may you never be outsmarted by your idiot lights.
2002 F-250 XLT SC LB 4x4 7.3PSD 6-Sp 3.73 L-S, Snugtop Snuglid Tonneau, 235/85 MC HTRs, <span style="color: red">DPTuner F5</span> AFE Stg II, Turbo LifeSaver, MAP BRV, Autometer Cobalts, Magnaflow 4", WW, TAG, AIH del, CCV, AirDog, In-tank, Harpoon, HPX, ITP fuel sys, LL8 del, 203*, Oilguard & SP Diesel bypass filtration, ART rotors, PFC pads, Heater Core Ctl Valve, Bilsteins, Velvet Ride Shackles, South Bend Clutch, <span style="color: green">21.27 mpg</span>
2004 <span style="color: red">E</span>-350
XLT Wagon 6.0PSD 3.55 L-S TDM EZ-Entry 11 pass., AIC, custom MBRP 4" w/dual Aeroturbines, Airdog, harpoon, Overhead Cobalts
Pictures . . . Parts Links
DarthSurplus is offline
Old 12-22-2007, 01:34 AM   #2 (permalink)
Cool_Canuck's Avatar
My Photos: (12)
Re: Does anybody have the Turbo Pedestal R&R instructions handy?
http://www.thedieselstop.com/content...0%26%20Rebuild
2011 f250 XLT 4X4 Crew Cab.
SOLD - 2001 F250 XLT 7.3L SC/SB 4x4 (ESOF) - Tranny Upgrades; SCMT 1705; AIS Intake w/trimmed Snorkel; ZooDad; Turbo back 4" Exhaust; Issopro Pillar Mount Gauges; TC lockup LED; Auto Magic Heater Bypass; 2W Low Switch.
Cool_Canuck is offline
Old 12-22-2007, 10:03 AM   #3 (permalink)
aklim's Avatar
Did they determine whether it is the EBPV or the turbo pedestal O-rings. They determined it was my O-rings and after an unsuccessful fix, they used their scanner to test the EBPV and what do you think they found?
01 Excursion 7.3L Powerstroke. Gauges with AIH Delete, AIS, CCV Mod, 4' MBRP, BTS Trans, 6.0L Trans Cooler and Intercooler, DP-Tuner F5 chip, ITP In Tank Mod and Boost Annihilator, Diesel Innovation's Regulated Fuel kit, BTS Big Oil system, GTP38R Turbo with 1.15 A/R housing and BPD Stage II AC injectors. Bilstein Shocks with U code front and A code Rear.
aklim is offline
Old 12-22-2007, 10:37 AM   #4 (permalink)
God Bless you, my frozen North American brother!
Thanks, and Merry Christmas.
Old 12-28-2007, 12:24 PM   #5 (permalink)
New turbo pedestal is in! Took it for a drive and no leaks! Yeehaw!
Getting the rear v-band clamp off the up-pipes and turbine inlet was a chore. I put anti-sieze on it when it went back in, which was also a chore due to all the things that must be aligned simultaneously. There's an alignment pin on the collector that fits into a small hole in the turbine inlet.
The instructions say to remove the EBPV device before removing the turbo. It turns out this isn't necessary, but I only discovered this inconvenient fact because I rounded off the rearmost EBPV 8mm 12pt. Once the turbo was out, a few sharp whacks with a hammer freed the stuck bolt, and I was able to replace it with a good one, slathered with anti-sieze.
I used the opportunity of having everything out of the way to splice into the EBPV control wire for my future plans to control it with a 3-position switch (open, closed, and auto). I started this comprehensive wiring project in April, and now it looks like I won't get to finish it until next April.
I used the opportunity of wanting the downpipe out of the way to install a Magnaflow 4" system with 3.5" downpipe. My EGTs were noticeably lower on my test drive. One trick that served me well, since I didn't remove the driver's side intercooler tube, and the passenger side was proving difficult to re-install, was to warm the boots in a pot of near-boiling water for 5 or 10 minutes. Everything snapped right together with the boots warm. I'm not sure if I would have thought of it if it hadn't been 35 degrees F outside.
