The slip yoke can be a trouble spot but usually only with driveline noise. It can actually be lubricated by taking it apart and using a teflon lubricant.
Before I spent a bunch of money on a driveline I would try rotating the tires and seeing if the vibration goes away or changes. I have seen a couple guys that have had a tire go bad (internally) that causes vibration. Obviously your mechanics have a better idea of the vibration feel as the hopefully have driven the truck. Drivelines can also be balanced, find yourself a driveline specialty shop and have them work it over. The price is usually pretty affordable.
Ken
Powerstroke Acronyms
TSB Information
