drive shaft stuck HELP - Diesel Forum - TheDieselStop.com
Old 08-08-2005, 11:51 AM   #1 (permalink)
weitekampt's Avatar
I am trying to lube the splines and I can't get the drive shaft out of the yolk. I removed th 4 8mm bolts and it looks like the u-joints are rusted in. Is this normal?? I have never dropped a drive shaft so I am wingin' it. Do you have to drop the real u-joint or can you drop it from the front u-joint. I don't have the star socket or the right one for the rear I don't think. That is why I am trying to drop the front. Spray with penetrating lube and then put a pry bar on it or what???/
HELP!
*2002 Crew Cab SB 4X4, XLT Lariat, BTS Trans, 6.0 cooler, DP Tuner F-6 Stock, 60T, 80T 80E, AutoMeter gauges, AIH delete, AIS, Zoodad, HX Crossover, 203 stat, Coolant filter kit, Rotella ELC, 15W40 CenPeCo, Terra Grappler 285/70/17, Monroe Reflex shocks, intercooler wrap removed, Roll-n-Lock, Recon cab lights, 212,000, DrawTite brake controller, AIC module, Straight Pipe,
weitekampt is offline
Old 08-08-2005, 12:18 PM   #2 (permalink)
Re: drive shaft stuck HELP
I would pry, carefully. What you don't want to happen is for the cups to come off the ends of the u-joint.
I undid the front u-joint too when I lubed my splines. No problem, and probably easier to get the splines back together again.
Red
redneckmba is offline
Old 08-08-2005, 01:14 PM   #3 (permalink)
weitekampt's Avatar
WEll, I had to punt on this deal. I have been needing to do this for a long time (50K) but it just never got worse. I guess I learned to live with it unintentionally. But anyway, I can't get the dang thing loose or pulled out of the yolk. Can't get the bolts out of the back bracket either. Squirted with PB Blaster. Will let soak for a few days and maybe try again. I think I am screwed and will have to take it somewhere.
Any other ideas that may help?? [img]/ubbthreads/images/graemlins/shrug.gif[/img]
Old 08-08-2005, 02:07 PM   #4 (permalink)
If your vehicle is sitting on its wheels, make sure your emergency brake is on and the wheels are blocked so your vehicle doesn't roll away after you remove your driveshaft. You've probably already done this, but when you mentioned you've never dropped a driveshaft before, I thought I'd throw this out just incase. One of our friends neighbors removed their driveshaft and the vehicle started to roll with him underneath. Fortunately he had large tires which gave him enough clearance so he was able to roll away and miss the pumpkin as the vehicle rolled over him, but his vehicle rolled down his driveway; into and across an intermittently busy street; up a curb and into a block wall [img]/ubbthreads/images/graemlins/eek.gif[/img]
01 Excursion 4X4 PSD
02 F350 4X4 PSD
qadsan is offline
Old 08-08-2005, 03:15 PM   #5 (permalink)
The_Kid's Avatar
My Photos: (13)
I just lubed the rear spline Saturday. I had to use a 2 ft. breaker bar to get the bolts loose. Also, you only have to remove the rear clamp on the boot to get to the spline. I used a small pair of needle nose pliers to straighten the crimp and unlatch it, instead of cutting the clamp. When reinstalling the original clamp I used a small pair of end cutting wire nippers to crip it again.
This was the first time I lubed mine and there was still plenty of grease left. I'm at 60K so your fine at 50K.
Main ride: 02-250 XLT SC PSD 4x4 6spd Dk Shadow Gray 3.73LS Long bed AIC Dakota Digital EGT gauge
Truck Pics: http://photos.thedieselstop.com/show.../18846/cat/500
The_Kid is offline
Old 08-08-2005, 03:33 PM   #6 (permalink)
weitekampt's Avatar
Do you remember what size socket you used? I think a 13 is what fit tight on mine. Is there a special socket? Really don't want to screw something up.
I am actually at almost 90k! Should I just throw new greasable u-joints in there at the same time. Can any knuckle head do that job? I am feeling pretty stupid right now seems as though I can't get the dang drive shaft off! [img]/ubbthreads/images/graemlins/confused.gif[/img]
Old 08-08-2005, 05:28 PM   #7 (permalink)
fordmastertech's Avatar
[/ QUOTE ] 12 mm 12 point.
FMT
Excursion Pics
2000 Excursion Limited 4x4 Dark Satin Green Arizona Beige 7.3 DIT, AXDO, 3.73 LS, DP Tuner F5, TERMINATOR II w R-IPR, Adjustable Boost Regulator, Turbomaster, EBPV Delete, Air Dog, ITP Regulated Fuel Return, Fuel Cooler, Tags 1&2, Harpooned Tank, Magnaflow XL Exhaust w Aeroturbine 4040L, Sonnax/Tricumulator, 8 Autometer Sport Comp 4 Gauge A Pillar 4 Gauge Overhead, Ford APCM, Crimestopper Remote Starter With Remote Fast Idle, Ford AIS w Zoodad, W Code Front Modified B Code Rear springs, Rancho RS9000X, Rancho 5406 Stabilizer, Hellwig Rear Sway Bar, BFG Rugged Trail TA, V10 Trans Cooler w Dual Electric Pusher Fans, Coolant Filter, IAH Delete, (((XM))) Line Of Fire Light, Ford Cab Lights, 05 Headlights w GOS Conversion Harness, Jimmi Jammers, 03 Lighted Painted Tow Mirrors w C-BETR, PSD Badges, Pullrite Hitch, Prodigy Brake Controller, Born 01/29/00
fordmastertech is offline
Old 08-08-2005, 09:23 PM   #8 (permalink)
weitekampt's Avatar
Thanks! I'll go get one.
Old 08-08-2005, 10:09 PM   #9 (permalink)
Ran440's Avatar
Check out my post titled "Motorcraft spline grease beats synthetic" before you grease the splines.
Randy
1999 ( Build date 10/98 ) 1-Owner F-250 XLT PSD, XLE8 ( started out as XLE4 ), Auto Trans w/sonnax valve tricumulator springs, 4x4, manual hubs, manual shift transfer, 3.73 gears, Tymar intake, open air CCV, A-pillar 3 gauge W/Auto Meter pyro, boost, trans and axle temp in Mag-Hytec covers, Banks 4" monster exhaust, DI 4 Position Flip Chip stock-75-100-110, early 99 turbo conversion W/ ATS BB Turbo, gutted EBPV, Smitybuilt bumper guard, Lund bug deflector, Lund SS cold air grill guard, Wet Okole seat covers w/Powerstroke logo, custom made floor mats ( way better than any store bought mats )
http://community.webshots.com/user/ran440
Buy American, Keep Your Job.
Ran440 is offline
