driveline roar in a dually.... - Diesel Forum - TheDieselStop.com
post #1 of 20 (permalink) Old 03-24-2006, 05:58 PM Thread Starter
been progressivly getting worse over time and thought it might be my old wore out tires...just put a new set of michelins on tonight and its still there and maybe a tad worse.....grabbed a hold of my driveshaft while the guy had it up on the lift tonight, and it had a pretty good amount of play in it....id say a quarter inch or so....is that normal ?? any ideas ?? thanks alot...
2000 f 350 dually crewcab....DP
80 hp performance flash....autometer z- series gauges ....walker BTM..... If it should move and doesn't, use WD-40. If it moves and it shouldn't, use Duct Tape.
nodoubt1 is offline
post #2 of 20 (permalink) Old 03-24-2006, 06:33 PM
Re: driveline roar in a dually....
i'd say no, you shouldn't be able to move your driveshaft at all. now figure out if the slop is from bad ujoints, bad bearings in either the tail shaft of the tranny or pinion bearing of the rear diff, the carrier bearing, or just a loose pinion nut on the rear diff.
2001 F250 7.3 Platinum Edition
/AIH Plug/Sonnax/5" Exhaust/DP-TUNER Chip/Stupid Power-hungry Grin
R_S_C is offline
post #3 of 20 (permalink) Old 03-24-2006, 07:46 PM
I have a 99 250 single rear and mine has the same roar about 65 and up, took it to the dealer and they said it was tire noise, but I know what my truck sounds like the last 60000 miles and it is not tire noise. I think it is pinion bearing but dealer said if they tear it down and dont find any thing it will not be covered by warranty. If you find out what it is let me know.
cookieman is offline
post #4 of 20 (permalink) Old 03-25-2006, 02:15 AM Thread Starter
anybody else?? how much play in the driveshaft
nodoubt1 is offline
post #5 of 20 (permalink) Old 03-25-2006, 07:03 AM
There should not be ANY front to back play in the driveshft at all. If you grab the driveshaft and pull it away from the rear diff and the pinion yoke moves that 1/4" you described, one (or both) of your pinion bearings is shot. I just had to replace mine to the tune of $1000.00 (after bearings,seals and labor)...
So, you have to determine WHAT is moving before we can help.
Jim
2000 F-350 7.3L 4X4 CC PSD LWB DRW, Diesel Innovations BD-4 Chip, BTS rebuilt Transmission, 5" Exhaust, TC Lock switch, Autometer A-Pillar Gauges, Detroit Locker in back,Air-Lift bags, Dual tranny coolers, Wix Prepump F/W separator, Fumoto Valve, Marinco Plug, Zoodad mod, APC billet grille.
jamming4jim is offline
post #6 of 20 (permalink) Old 03-25-2006, 07:24 AM Thread Starter
Jim
[/ QUOTE ]....no front to back play i could tell....looks like the play is coming from the tranny side of the driveshaft.... just a little chuk, chuk sound from there when i rolled the shaft and a quarter inch of play ......whats the deal with that end of it ??
nodoubt1 is offline
post #7 of 20 (permalink) Old 03-25-2006, 07:27 AM
Sounds like a u-joint to me. I'd pull the driveshaft and check ALL of them.
Jim
post #8 of 20 (permalink) Old 03-25-2006, 04:45 PM Thread Starter
Jim
[/ QUOTE ]...................any way to check em without pullin the shaft ???
nodoubt1 is offline
post #9 of 20 (permalink) Old 03-25-2006, 10:30 PM
Iv'e never had constant noise from U-Joints, even when they were shot and had alot of play in them. Worn U- joint noise is identified by a clunk when shifting from drive to reverse (or vice versa). The only constant noises Iv'e suffered in my trucks were: 1) bearing roar (bad news) or: 2) a clicking sound of a damaged rear end gear( really bad news). Noise usually (usually always) comes from bearings that have gone bad. Even so, check your U-Joints first ( they should have NO play no matter what type of force you put on them. Then check for ANY movement of the pinion shaft or trans output shaft. (also, NO play is acceptable). I check bearings with a mechanics stethoscope while on a lift for bearing 'roar' at low speed. This will indicate a bad bearing. Bearing noise will transmit up to the cabin at high speed while under way. This also applies to rear axle bearings (which will also transmit sound up to the cabin.) Hope this helps.
2000 F350 Crew Cab 4x4 Dually. All black-power everything - 265/75/16 Bridgestone REVO 2, 6.0 trans cooler. Fixed everything - brakes, steering wander, power windows, doorlocks, overhead display, turbo, trans, Yup - Character building 101
pursuthis is offline
post #10 of 20 (permalink) Old 03-26-2006, 07:37 PM
ok, you might wanna put a new midshaft bearing in that guy before it leaves you sitting on the side of the road like mine did to me!!! its a cheap part but youll either need a press or get crafty with a hammer and some exhaust pipe to put the new one on.
mine was so bad it actually came apart and the shaft was hanging there, in the middle of the road. i would remove the shaft and replace all the ujoints and the midshaft bearing. then you can check that pinion bearing play, i think youl find that the ujoints and midshaft bearing fixes your problems...
9/1998 f-550 wrecker all stock with around 200k
new swamps,fuelpump,lines,tank,filters,oil!!
031600 is offline
post #11 of 20 (permalink) Old 03-27-2006, 06:11 PM Thread Starter
[/ QUOTE ].........thanks 03....hope thats all it is ....where is the mid shaft bearing located...
nodoubt1 is offline
post #12 of 20 (permalink) Old 03-27-2006, 10:21 PM
Kind of late to this post - I had an 01 with vibration noise (couldn't feel it) starting at 65 mph - 80 mph then it smoothed out. Turned out to be needing new rear end. Problem was gone. Steadily got worse over time. Funny thing was, you couldn't hear it as bad from other positions other than the drivers seat...
Hope this helps,
Viper
05 F350 CC PSD Lariat, Black/Silver Birch, XM Roady
TGviper is offline
post #13 of 20 (permalink) Old 03-27-2006, 11:22 PM
You might check the four bolts holding the drive shaft to the back of the tranny. Mine loosened after a clutch change I did and made a roar and light vibration as they gradually loosened. Just something to check. Used a 12MM end wrench and tapped the wrench with a hammmer for final tightning.
Jim
2000 F-450 7.3L DI Powerstroke DOM 7-99 stock
fishnfool186 is offline
post #14 of 20 (permalink) Old 03-28-2006, 05:52 AM
Don't mean to hi-jack.
But I have a roar in my dually also.
At first I thought it was the front end but just last week when your at highway speeds and press in the clutch the roar goes away! I know its not a U-joint but what could it be? And I just put new tires all the way around.
1992 E350 7.3 IDI, 3.73 club van - 160K
1998 Quad cab 2500 12V Cummins, 4x4,auto, all stock with 145K miles
2000 F350,DRW converted to SRW with Vision 19.5" wheels,4x4,6 speed,Lariat,Napa 6642 airfilter,Edge Juice w/Attitude,Cody Cushon gooseneck, 175K, Prodigy, 3.73 gears
2002 TDI Jetta Manual 200K
2002 TDI Jetta Manual 230K
2003 TDI Jetta Maual 90K
1999 Polaris Diesel Quad
2004 Kubota BX 1500 599cc diesel
(yah I like the old mechanical diesels
Westro is offline
post #15 of 20 (permalink) Old 03-29-2006, 12:18 PM
I have a '99 Dually Crew Cab that has driveline noise between 65 and 72 mph............Pulled the rear shaft, checked carrier bearing and U-joints then checked the front shaft and axle U joints and found nothing...........I just don't drive between 65-72 anymore........... [img]/ubbthreads/images/graemlins/shrug.gif[/img] [img]/ubbthreads/images/graemlins/shrug.gif[/img] [img]/ubbthreads/images/graemlins/shrug.gif[/img]
1999 F-350 CC Dually PStroke, 1996 s-281SC SALEEN Vert #380, 2006 F-350 CC Amarillo Pkg. Located in HELL-The hottest part.
PAVER-1 is offline
