Hi have 99 and alternator shows charging properly, but lights on dash and headlights when at a stop will dim a little get brighter and does this continually until you start to move and everything is fine until you slow down again, needle on alt. goes up and down slightly also, any ideas?
Alternators on diesel don't put out full power at idle. So some dimming can be expected but it's typically minimal enough to be barely noticeable if at all.
Check your alternator, charge and load test each battery individually. Check and clean ALL connections. Look for the tell tale water line on the firewall above inside fuse panel. Make sure ALL ground connections are clean and tight..
Let us know what you find.
put a meter on both batteries not running were both at 12.3 then after starting were 14.8 to 14.9 then put on high beams and jumped up 14.9 to 15.1 so alternator is working
You have to disconnect the batteries from each other when checking with a meter. Any difference between the two of .3 VDC or more, indicates the lower voltage battery could have a bad cell. The real way to check is for Hg, (specific gravity) in each cell. Not possible that way with maintenance free batteries tho.
Related Threads
The Diesel Stop
2.6M posts
210.8K members
Since 1999
