engine codes no power at cold start - Diesel Forum - TheDieselStop.com
Old 02-25-2013, 02:07 PM   #1 (permalink)
swishcooter's Avatar
ok, i just bought my 2001 7.3 pds about 2 1/2 weeks ago. i got it home and it wouldnt start. fuel pump crapped out and i replaced that. now in the mornings or when not driven for sometime and the engine is dead cold it has NO power like it barely wants to move. i have 3 codes p1211, p1280 and p0541. i drove it to work today and while i was idleing it shut off. started right back up and drove fine. at heavy accelleration it seems like it doesnt have enough balls..........
swishcooter is offline   Reply With Quote
Old 02-25-2013, 02:12 PM   #2 (permalink)
also there is a puddle of fuel on top of the intake and cant find where its comming from. the passenger side valve cover appears to be leaking from back rear corner as well... i emptied out the oil into a bucket last night to make sure there was no coolant or fuel in the oil. didnt appear to be but the oil was kinda thin. so i put it back in... im lost im not a diesel mechanic at all. but have alot of experience in gas engines.
Old 02-25-2013, 06:42 PM   #3 (permalink)
Nobody? :/
Old 02-25-2013, 06:48 PM   #4 (permalink)
ReefBlue's Avatar
On the driver's side head, towards the front, there is a sensor called the ICP--injector control pressure sensor.
It is stuck into the head at a 45 degree angle. If you disconnect the electrical connector and there is oil in it, that sensor is bad and needs to be replaced.
That may be the P1280. The P1211 may be related, but check that sensor first.
Your fuel leak is most likely your hard lines from your fuel bowl, there are rubber fittings that hold them in place . . .they just leak eventually.
The P0541 is your manifold air heater either shorted or opened, that won't cause any problems driving as it is disabled unless you're in park.
Oh, and this too:
http://www.superdutypsd.com/codes.php
1999.5 F250 creeping up on 400k.
Phantom problem? Check this: Phantom electrical problems?
Keep everyone (and yourself) updated:7.3 mileage and repair thread
ReefBlue is online now   Reply With Quote
Old 02-25-2013, 07:37 PM   #5 (permalink)
OK I checked it when I got home and the icp connected and it does have oil in it.
Also while driving home it shut off about 4 time while commingle to a stop but always crinkled right back up. When I was at idle it started running really rough so I pressed the gas and it went away. So I continued home and it bucked one good time like it dropped down to 700 rpm then way up to 3000 instantly like I was using NOS.
Also before I started having these issues while driving it didn't really feel like I had full power I mean the not like a 7.3 should have. If I gunned it to the floor it would accelerate but not very well. And I get 9 miles to the gallon on the highway. Could all this be from the icp?
Old 02-25-2013, 07:40 PM   #6 (permalink)
ReefBlue's Avatar
Not sure. It produces an voltage response based on pressure, so if the sensor has intermittent issues, that voltage will jump around and the truck will react accordingly.
But, do the simple things first, replace that part.
Old 02-25-2013, 10:14 PM   #7 (permalink)
what are you using to get your codes? you really need to scan it with ae or something similar.
you definitely need to replace your icp as RB mentioned. Your fuel leak could be coming from the fuel bowl drain valve as well. Need to get in there and try to find the source of the leak.
I am not too sure about your issue atm. I am not sure if a bad cps would have anything to do with your stalls, idle, etc.
03 F350 7.3L Auto CC LB Dually 410's (LS Rear)
PHP/Beans tuned/250/100 FF inj's, BTS Tranny, Strictly Diesel complete fuel system with RR & FB delete, Pius LASB from Irate, Swamps HVHF IDM.
Autometer Nexus Guages, 4"MBRP, DieselSite Coolant filtration system/billet housing/HP X-Over line. Baldwin PA2818(6637) RR Boots/CBillet Plenums, ('06) 26 row Tranny & PS Cooler, LarryB's Genuine Denso Starter
INFRNL is offline   Reply With Quote
Old 02-27-2013, 07:32 AM   #8 (permalink)
Update- I changed the icon and it runs great! A lot more power and MPG went up by 2 now I'm at 11. Thanks guys. And I'm using and autel and I also have a Matco determinator scan tools. I saw a power increase of 45%!!!!! Thanks guys. Now I just have to tackle the oil and fuel leak. :-)
