Engine flush - Diesel Forum - TheDieselStop.com
post #1 of 13 (permalink) Old 11-02-2010, 04:09 PM Thread Starter
Engine flush
I have a 2000 7.3 with 137,000 miles. I change my oil every 5000 miles. I was thinking about flushing my engine out on the next oil change. Is that a good or bad idea? If i should, what should i use?
fastracing77 is offline
post #2 of 13 (permalink) Old 11-02-2010, 04:18 PM
RT
RT's Avatar
If you have been good about changing your oil every 5K, then don't do it. With detergent oils it really isn't necessary. It was an ok idea in the days before oil filters and modern oils - we used to use kerosene - but I wouldn't do that to my 7.3 if you paid me..
RT is offline
post #3 of 13 (permalink) Old 11-02-2010, 04:47 PM
claw444's Avatar
useing any kind of engine flush is like running the engine with out oil in my opinion. even though you cant run a powerstroke 7.3 with no oil. just stating an example. those engine flush things in my opinion can cause premature bearing wear and other problems.
2002 F-250: CREW CAB: SHORT BED: 4X4
IESEL: 6SPD MANUAL: ALUMINUM AIR INTAKE: 4" BANKS DOWN PIPE: CUSTOM MADE 5" DUAL EXHAUST IN FRONT OF REAR WHEELS: TS PERFORMANCE 6POSITION 140HP: AUTOMETER GAUGES ON PILLAR AND ON INSTRUMENT CLUSTER: DUAL FRONT SHOCKS: DUAL STEERING STABILIZER: KYB MONOTUBE SHOCKS AND STEERING STABILIZER: LIFTED 2INCHES: TOYO OPEN COUNTRY AT TIRES LT285/75/17 LOAD RANGE E: 17" AMERICAN RACING WHEELS: CUSTOM MADE WHEEL SPACERS: WARN HUBS: POWER SLOT FRONT BRAKE ROTORS: HAWK SD BRAKE PADS UP FRONT: SMOKED CAB LIGHTS: SMOKED TAIL LIGHTS: POLK AUDIO 10" SUBS IN HOMEMADE BOXES: SONY HEAD UNIT AND SPEAKERS: KENWOOD AMP
claw444 is offline
post #4 of 13 (permalink) Old 11-02-2010, 07:57 PM
DJM0525's Avatar
I used the amsoil engine flush and noticed a difference in idle and how it started up that was about a year ago I'm gona do it here again this weekend.
2001 CC
DP F6 60eco,80tow,80eco,120
6" lift 37" toyos
AFE Big Boost
4" Exhaust
RiffRaff FRX
EV2 Guages
F650 Dash
DJM0525 is offline
post #5 of 13 (permalink) Old 11-02-2010, 08:25 PM
lance1955's Avatar
Personally I would not bother. I think your asking for trouble. But thats me. The only engine flush I use and that would be on a gasser would be a quart of tranny fluid, but not in a diesel. Guess im old school
2002 Excursion 7.3L 200K+, After market tranny cooler, diesel site transmission filter kit, coolant filter kit and complete boot kit, bilstein shocks. Original transmission with mobile syn ATF
lance1955 is offline
post #6 of 13 (permalink) Old 11-02-2010, 11:55 PM
I wouldn't do it, either. The only method of "flushing" I do to my diesels are very short oil change intervals. If I think the truck needs a flushing I will change the oil every 1k miles a couple of times and then resume normal OCI's. In all honesty, I'm not even sure that is necessary with regular oil and filter changes and modern oils.
JasonL is offline
post #7 of 13 (permalink) Old 11-03-2010, 11:48 PM
KLo
I think one of the reasons some people are reluctant to do an engine flush is the fact that most are solvent based.
AMSOIL's Engine Flush is a safe, detergent based formula that is safe on seals and gaskets. It is designed to be run with your oil, before you do a change.
Here is some more info, and before and after photos.
Kirk Olson
AMSOIL Direct Jobber & Forum Site Rep
(303) 404-2145
(303) 588-6125 - Cell
KLo is offline
post #8 of 13 (permalink) Old 11-04-2010, 06:17 AM
DJM0525's Avatar
KLo I used it like said before and it did make a difference I plan on doing it about once a year after I did it the first time the truck started like right now no cranking and it ran smoother but all that went away after about 5 or so oil changes. I would say it's doin something.
2001 CC
6" lift 37" toyos
AFE Big Boost
4" Exhaust
RiffRaff FRX
EV2 Guages
F650 Dash
DJM0525 is offline
post #9 of 13 (permalink) Old 11-05-2010, 12:08 AM
KLo
Thanks, DJM. Good luck. You said you used it about a year ago. More than likely that was the older formula. The new 100% detergent based formula was released earlier this year in April 2010.
Please let me know if I can help you with anything.
Kirk Olson
(303) 404-2145
KLo is offline
post #10 of 13 (permalink) Old 11-05-2010, 05:46 AM
DJM0525's Avatar
I still got some left that I'm gona use up when I change the oil in the morning how much is the engine flush going for now anyways?
2001 CC
6" lift 37" toyos
AFE Big Boost
4" Exhaust
RiffRaff FRX
EV2 Guages
F650 Dash
DJM0525 is offline
post #11 of 13 (permalink) Old 11-06-2010, 12:48 AM
KLo
PM Sent.
Kirk Olson
(303) 404-2145
KLo is offline
post #12 of 13 (permalink) Old 11-06-2010, 03:35 AM
Bill1013's Avatar
Auto-RX for me, a little expensive but worth it. Used the first cleaning at 156K miles, am on the second now. After the first one the oil is really clean still at 3500 miles on it. Engine seems to start and run better.
99.5 F350 XLT Lariat 4X4 4R100 4.10 DW CC LB Centurion conversion, 183K miles Garret Turbo, Radio SD &Tape, SP Performance 40-60-80 chip, 100 Gal.Transfer Flow W/Trimax Control Aux. fuel tank. ScanGaugeII, Boost, EGT, Trans. Temp. Oil Temp. Build date 03/99
92 F350 2WD 7.3 IDIT E4OD CC LB dually Banks turbo US Gear O/U, 79K on the engine. 129K body.
Have AutoEnginuity W/Ford enhanced. Lima OH area.
My mind works lightening fast. One Flash and it's gone forever.
Bill1013 is offline
post #13 of 13 (permalink) Old 12-04-2012, 10:41 AM
Are you still using Auto-RX? If so, what are your thoughts after using it for so long and would you still recommend it. I just purchased a F-250 with a 7.3 and it has 146,000 miles on it. Was thinking about doing this cleaning to start things off the way I'd like to down the road after it's clean.
iowahogfan is offline
