Engine imbalance at about 1100 RPM... - Diesel Forum - TheDieselStop.com
Old 09-19-2007, 02:15 PM   #1 (permalink)
Hey guys, I read somewhere that a good way to see if there are any injector problems is in neutral, rev the engine to about 1100 RPM. If there is something wrong with one or more of the injectors, you'll feel it.
Well, I tried it after a 3 hour highway drive. At 1000 revs, smooth as silk. At 1000 revs, there is definitely an imbalance feeling. At 1200 revs and higher, smooth as can be.
Is this a sign that there is something wrong? Or is that just a normal harmonic balance issue.
Thanks,
Steve
Early 99 7.3 F250 Extended cab 4x4 6-speed 200,000 miles DIY intake, MBRP 4" single exit, Isspro EGT and boost, DP Tuner 80 econo flash, South Bend clutch Carbotech Bobcat front brake pads, Door seal and Snowman mods...
Steve91T is offline
Old 09-21-2007, 11:32 AM   #2 (permalink)
Re: Engine imbalance at about 1100 RPM...
I'm sure somebody knows...
Steve91T is offline
Old 09-21-2007, 03:32 PM   #3 (permalink)
lone_star_dsl's Avatar
Mine does it. I am quite confidant that I dont have any injector issues. I think it is a harmonic balancer issue because mine does it slightly worse during freezing weather.
2002 F-350 SRW
Lariat, Crew Cab
Long Bed, 4X4
Auto Trans, Tymar Intake
Wicked Wheel, Zoodad Mod
Intercooler Wrap Removal
4" Straight Pipe Exhaust
Recon Smoked Cab Lights
05+ Harley Headlights
6" Upper and Lower Windshield Brows
ISSPRO Gauges, Edge Insight CTS
Acetone Badges
XM Radio, Cobra CB
315 Pro Comp AT's
2010 Elite 20' Dovetail Gooseneck GVW 14,000 lbs
2001 Thor Wanderer 24RK Fifth Wheel
180,000 mostly trouble free miles and counting!
lone_star_dsl is offline
Old 09-21-2007, 03:59 PM   #4 (permalink)
Mine does too, but only intermittantly. Sometimes smooth as silk, other times shakes like it has the palsy.
If anybody figures it out, please share!
FS
'01 X 7.3 to tow my racecar...
AIS w/ sleeve
Old School Stealth twin pumps!!
4" MBRP
FPR shim
TransGo shift kit (BTS coming soon)
Hellwig rear bar
Landyot's Radius Rods
DP Tuner-80E, Hi Idle, 60 tow
EGT, Trans temp, boost gauges,
...drags my 24' Shadow GT around like it's not even there
'07 Sprinter 3500. The new(er) snake oil wagon
'91 Spec Miata
All vehicles full of BG Synthetic Fluids
fastersteve is offline
Old 09-21-2007, 04:28 PM   #5 (permalink)
Sometimes when I have my AIC set to charge protect I can feel it but I can speed up 100 rpms and it goes away, if it is an injector issue, then I have had injector problems for 7 years. I would not worry about it.
Y2K,F-250 Lariat, PSD,Auto 4X2, NVK4, S.Cab,White, Banks T.O.P. and Muffler, Isspro Gauges, TTM, Sonnax & Tricumulator, Rancho 9000s, AIC, Silverstar Bulbs,SUVLIGHTS Harness,Homebrew "Britebox",Homebrew LED "Strobes", N-fab nerf steps, Heater Core mod
Dash mount digital trans. temp... Slimline LED'S Strobed Video
Tparker is offline
Old 09-21-2007, 07:03 PM   #6 (permalink)
Kanman's Avatar
IMO I don't think that is a reliable test what so ever. I would think you're going to feel the torque converter / fly wheel mass, harmonic balancer more than anything else.
Are you seeing any white smoke heading down the road?
Kanman is offline
Old 09-21-2007, 10:51 PM   #7 (permalink)
Thanks guys...I figured it was OK. I just saw this test somewhere and tried it...thought maybe something was wrong.
I get no white smoke, only a little black smoke when I really get on it.
Truck runs great...but that's only what I know. I've only had this truck for a year and have no idea what "normal" is.
Thanks again.
Steve
Steve91T is offline
