engine misses when turn on wipers & 4x4 - Diesel Forum - TheDieselStop.com
post #1 of 9 (permalink) Old 05-18-2011, 12:32 PM Thread Starter
I have a problem where my truck dies for a second when I turn on my wipers or 4x4. It happens intermittently. I suspect the massive amounts of rain are getting something electrical wet.
Any ideas?
Matt
MGolden is offline
post #2 of 9 (permalink) Old 05-18-2011, 01:02 PM
tattoocharlie's Avatar
My Photos: (5)
yup theres a gem module driverside below windshield,its common to have weird electrical issues when water gets in due to a bad windshield seal.
2002 f250 lariat 7.3 220k(motor has 190k)
original 4r100 tranny....220k and counting
knock on wood....
red elc good for 150k
4r100 1-2 2-3 3-4sonnax accumulator valves,.427 sonnax line pressure mod valve
4.125"yes thats 4 1/8" diy tymar intake(size matters...lol)
AIH delete,ccv delete,zoodad mod,
4" exhaust no muff
built my own leafs for 4.0 of lift!!!!!!
18" xd bronze revolvers with 325 nittos to wrap them
isspro pyro and boost guages on pillar mount....
tattoocharlie is offline
post #3 of 9 (permalink) Old 05-18-2011, 01:03 PM
My Photos: (5)
matt you should also fill out your sig so everyone knows what truck you have.good luck!!!!!!
knock on wood....
4" exhaust no muff
post #4 of 9 (permalink) Old 05-18-2011, 03:01 PM
jpciron's Avatar
I am having rain issues too. Which module is it and is there a fix other then a new windshield?
2003 7.3 F-350 XLT 2WD CC, 285,000K,4" Back~ 6" S.S. Miter Stack, International bellowed up pipes, K&N Intake W/Riffraff 6637 Filter,Ebpv delete,Garrett38r Turbo, Garrett high flow outlet, Stage 1 Injectors, PHP Hydra W/GearHead Tunes, Riffraff Plenum inserts, , Riffraff IC and plenum boots, Powder Coated Blue IC Tubes, Pricol Optix- Pyro,Boost,Trans , Hutch and Harpoon mod, Baldwin pre-filter,Rear Shackles,Custom box 12s behind rear,Kicker,Bluray,HDTV's
"The Constitution shall never be construed to prevent the people of the United States who are peaceable citizens from keeping their own arms."
jpciron is offline
post #5 of 9 (permalink) Old 05-18-2011, 03:11 PM
klhansen's Avatar
My Photos: (180)
The GEM module only exists on 99-01 trucks. It was replaced in '02 models by some other module (can't remember the name or exact location).
But the best thing to do is fix the windshield leak. If you don't it will probably take out any new module you install.
), AIS,
regulated return,
klhansen is offline
post #6 of 9 (permalink) Old 05-18-2011, 08:15 PM
F350_6's Avatar
An aftermarket CPS can cause the same symptoms, but it's the wipers not the rain.
Water getting in the CPS connection can do the same thing. It's worth taking a look.
They called it the VSM (vehicle security module) and stuck it behind and below the radio starting in 02.
Chris
2002 F350 6-speed 444 CID. XLT, Heated Seat, 500,000 & counting.
“Good judgment comes from experience, and a lot of that comes from bad judgment.” Will Rogers
F350_6 is offline
post #7 of 9 (permalink) Old 05-18-2011, 09:47 PM
HEY GUYS!!! I CHASED THIS FOR TWO SEASONS, ITS THE AFTER MARKET CPS!! The CPS reads RF signal and the wipers build a static charge & when they wipe, the charge goes off thus interfering with the CPS. I took the black one out & put a grey ford one in & no troubles since. What a headache this was but not now...
Tobin is offline
post #8 of 9 (permalink) Old 05-19-2011, 07:27 AM Thread Starter
SOB, I got stranded this winter with the CPS and put in a NAPA unit along side the road. Started having the trouble shortly after. Just using my wipers alot lately is prolly why I am noticing it with rain. I guess I will finally take it in for that recall........
2000 F250 SC LB 4x4.
6spd, 250k+ miles
MGolden is offline
post #9 of 9 (permalink) Old 05-19-2011, 08:53 PM
Yes, Mine died and I put a black Napa in & later that season in the rain it started, I pulled my hair out chasing this on my 99 F-250, finally an old ford guy told me to try the gray ford on, I changed it in the rain & bingo...gone.
Tobin is offline
