Engine Quit Running While Driving Down the Road - Diesel Forum - TheDieselStop.com
Old 03-01-2006, 06:39 PM   #1 (permalink)
Yesterday and today the engine just quit running while driving down the road.
Yeasterday I pulled the batter cables and drained the fuel bowl (thinking maybe water in fuel) Truck started and a ran about 100miles.
Today on the way home just stopped running at 55mph.
Pulled over pulled the computer removed chip re-seated chip connect battery cable started right up.
Any ideas.
The truck runs normal and then it just dies.
I have been running this chip since May 05.
I have not done anything in months accept change the oil, put fuel in it a add a coolant filter about 1 month ago.
The truck has 76,000 miles on it.
Thanks,
Don
2002 F250 CC 4x4 SRW, 203 Deg F Thermostat, Sonnax Valve, Tricumulator, Amsoil 15-W40, DiProcal 3-gauge pillar, Aluminized DPPI 3-1/2 Down Pipe to 4" Exhaust, AFE Stage I PG7 Intake, Jody Tipton 4 Bank Chip Stock, Tow, Economy & 100, Amsoil Dual Remote Bypass, GTP38R BB Turbo, DieselSite Coolant Filter
DLW2002 is offline   Reply With Quote
Old 03-01-2006, 06:50 PM   #2 (permalink)
Re: Engine Quit Running While Driving Down the Road
Did you change the cps? look at the thread most important lesson... Truck has 76k on it only wouldn't refire. Every other cps that went bad on me would allow the truck to restart. I'd start with that.
Good luck
Dave
'95 PSD 4x4 ext.cab stock but not for long cooper discovery st's 215 on the ticker and counting daily
'00 PSD CC DRW 4x4 76k My favorite,but she's a slugg
djwc is offline   Reply With Quote
Old 03-01-2006, 06:52 PM   #3 (permalink)
It sounds like the CPS to me also.
2001 F-350 CC DRW, 4X4, Auto trans, Pyro, Boost, Trans temp gauges, DPTuner F-5 chip,4" turbo back exhaust, ATS Turbo housing, SPDiesel overboost eliminator, AIH delete,manual T/Clockup, Sonnax/tricumulator kit,TruCool Max trans cooler,Home made tymer intake, Firestone Riderite airbags, B&W turnover ball
duallycruzer is offline   Reply With Quote
Old 03-01-2006, 06:52 PM   #4 (permalink)
I bought one yesterday but have not put it in.
The only thing the concerns me is that it re-started.
Don
Old 03-01-2006, 06:53 PM   #5 (permalink)
Thanks,
I will go change it.
Don
Old 03-01-2006, 06:54 PM   #6 (permalink)
They will do that some times before it just goes totally out.
Old 03-01-2006, 08:42 PM   #7 (permalink)
CSIPSD's Avatar
My Photos: (52)
CPS.
05/01 F-250 PSD,200k,AFE2 ,Modded H2e, 6.0 IC,Water Injection, AIH delete, Swamp tuned, GTS Hybrid injectors, ITP Fuel system, Studs, 910 valve springs, Suncoast 4r100,MBRP Duals, 6" tips, 17 Isspro Performax gauge's, 100g fuel tank, 05 mirrors with recon lens, 4" Revtek lift 37-13.50-17 Toyo MT's
CSIPSD is offline   Reply With Quote
Old 03-01-2006, 08:57 PM   #8 (permalink)
I have had a couple CPSs fail like that in the past. [img]/ubbthreads/images/graemlins/frown.gif[/img]
2004 F-350 Lariat, Supercab 4X4 FX4, DRW
Dark Toreador Red/Silver, 6.0L, Torqueshift Auto, ESOF, 4.10 LS, Camper Package, Dual Alternators. Build Date 6-8-04, Eng 5-28-04, Lance 9.5 Ft Camper.
Past 2002 F-350 Lariat, Supercab 4X4, Toreador
Red, 7.3L, Auto, DRW, Fully Loaded.
Past 94.5 F-250 Lariat, Supercab 4X4, 5 spd 7.3L PSD.
DRJ48 is offline   Reply With Quote
Old 03-01-2006, 09:39 PM   #9 (permalink)
My Photos: (18)
DLW2002
Her are some CPS issues:
Problems are intermittent and variable
Malfunctioning CPS will often quit or stumble on accelerating but not always
Malfunctioning CPS will often quit and come to dead stop but not always
Malfunctioning CPS will often set a code but not always
Malfunctioning CPS will often set SES light but not always
Malfunctioning CPS will often act up when cold (or cool) but not always
Malfunctioning CPS will often start right back up after quitting but not always
Malfunctioning CPS will often last for weeks after first quitting but not always
garyT
2002 250SD,4x4,XLT crew,6Spd.,4"ATS exhaust,ATS housing,SP Intake,,Edge Evo, Southbend CLutch CON OFE,BD short shifter, ITP Boost Regulator, Warn Preminm Manual Hubs.
DYNO: 325 hp 728 ft lbs
garyt is offline   Reply With Quote
Old 03-02-2006, 08:39 AM   #10 (permalink)
Thanks for all of the input.
I changed the CPS this morining.
It was quite simple.
Not inexpensive but simple.
The nice thing is since I have been reading this site for about 4 years. I kind of thought I knew what the problems was.
Time will tell.
Thanks,
Don
Old 03-02-2006, 01:04 PM   #11 (permalink)
What is the CPS? Anything like an ECU (Engine control unit)?
NoleAnimal is offline   Reply With Quote
Old 03-02-2006, 02:52 PM   #12 (permalink)
Cam Position Sensor..it tells the PCM the location of the camshaft's movement so the PCM can time the injections. It's basically a big magnet...or pain in the ass if it quits on you.
1997 F-350 XLT Regular Cab. 4x4. 7.3 Powerstroke. Auto. All Stock.
2001 F-350 XLT Regular Cab. 4x4. 7.3L Powerstroke. Auto. 3.73 gears. Tymar. 10k mod. DR 2" Leveling Kit. 285/75 Bridgestone Dueler Revo AT's. Powerslot Cryo'd/LTS brakes. Custom Salt And Sand Paintjob Thanks To Winter
ChrisC is offline   Reply With Quote
