Engine serial # question (ELC coolent change) - Diesel Forum - TheDieselStop.com
Old 04-15-2009, 12:43 PM   #1 (permalink)
Hello.
It has reported that ELC coolent is OK for engines made after 2/2/99
and serial number 940614. My Y2K truck was made in Nov. 99, and the Int'l , sticker on the driver valve cover has number 1188039 with a date of Nov 5 1999.
After much wirebrushing on the block I still cannot read the engine serial number near the oil filter.
It seems my serial number is later than the "cutoff", but the number seems to be MUCH later. Did the format change? They could not have made that many engines in 1999!
Is my engine serial number OK for an ELC coolent changeover?
wms2 is offline
Old 04-15-2009, 09:15 PM   #2 (permalink)
dlblazer's Avatar
I also have a 2000 (Jan 00 build date). I never did find the engine serial number (where is it on the valve cover) - I was told that it was virtually impossible for a 2000 model year truck to have an engine that was not compatible with ELC. I changed over a few months ago and have had no issues.
New truck: 2002 PSD 4x4, CC, XLT, F350 dually. Air bags, 6.0 trans cooler, Fleetrite ELC, ISSPRO guages, DB HT starter (no more), Superchips 1705 tuner, Reese Titan, AIS, IPT pre-pump filter kit, in-tank mods, and much more to come.
Old truck: 2000 PSD 4x4, ext cab, XLT, F-350, auto, V-code springs, air bags, coolant filter, 203 thermostat, Fleetrite ELC, DB Alternator, DB high-torque starter, Tru-cool Max-cool trans cooler, B&M trans temp gauge, 47 gallon Titan tank, IPT pre-pump filter kit.
dlblazer is offline
Old 04-16-2009, 08:34 AM   #3 (permalink)
Thanks for the report dlblazer! Have 4 gallons of Rotela ELC concentrate, and am collecting distilled water (10 gallons so far!) Is Gooch still around? Maybe he will chime in?
wms2 is offline
Old 04-16-2009, 08:41 AM   #4 (permalink)
dlblazer's Avatar
When I flushed mine, I ended up using 28 gallons of distilled water. It was nice and clear on the last flush.
dlblazer is offline
