Go Back   Diesel Forum - The Diesel Stop.com > 1999-2007 Super Duties > 7.3L Power Stroke Engine and Drivetrain
7.3L Power Stroke Engine and Drivetrain Discussion of the 7.3L Power Stroke diesel engine and drivetrain in the 1999-Up Super Duty trucks and Excursions. No gas engine discussion allowed except on transmissions and drivetrain that pertain to all models. Please confine discussion of topics in this forum to those items that are specific to the 7.3L Power Stroke engine.
Old 03-04-2007, 09:52 PM   #1 (permalink)
Erratic rpm behavior on 00 DRW F350 powerstroke.
Hello everyone, I am new to the site as my cousin just told me about it. I have already read and found out alot of things on here. Great diesel source.
Here is my problem,
While driving normal the rpm's will start going crazy up and down between 1500-2500rpm's for about 5-10 seconds with the SES light flashing then it will be fine after that and the SES light stays on. Also when it does this I can give it WOT or no throttle at all and it does not make a difference. The only thing I have done latley is unpluged my fuel pump heater since it keeps blowing fuses. (haven't got around to fixing it just yet) Has anyone else had this problem?
Thanks in advance,
Tony Moore
2000 F-350 DRW 7.3 power stroke
Mods: K&N Filter system, TS performance chip, Banks full exhaust, 1.00 A/R turbo upgrade, heavy duty torque converter, BD torq lock, BD X-moniter, Banks trans command, Pace Brake exhaust brake, amsoil dual filter bypass system.
Moorespeed is offline
Old 03-05-2007, 06:30 AM   #2 (permalink)
Re: Erratic rpm behavior on 00 DRW F350 powerstroke.
No one?
Old 03-05-2007, 07:52 AM   #3 (permalink)
[img]/ubbthreads/images/graemlins/confused.gif[/img] find out what that fuse feeds. & check the wiring on that circuit. you could also have a cps going out. thats a cam sensor on the frt. of the eng. down & just above the crank pulley on the pass. side. [img]/ubbthreads/images/graemlins/warmsmile.gif[/img]
certified ford dealer 7.3L,6.0L & 6.4L diesel tech & foreman
dvtech is offline
Old 03-05-2007, 09:11 AM   #4 (permalink)
If it is the CPS buy two on ebay for about $110 shipped. You should have one as a spare (With tools for replacement) for when it does go out.
Joe
2000 F350 4x4 Bright Red w/ Grey 40/20/40, DRW, CC, L.B., 7.3 w/ Auto, Ltd. Slip 4:10, Cmpr Pkg., Factory Aluminum Rims, T/S Mir. AM/FM Single CD and Cassette
http://www.realcountryonline.com/home.asp, Open Wheel Racing www.scrafan.com, Team Roping www.roperssportsnews.com, Observed Motorcycle Trials ( www.atatrials.com & www.trials.net) and Cycling
SprintCarCowboy is offline
Old 03-05-2007, 09:16 AM   #5 (permalink)
haul_n_horses2's Avatar
My Photos: (17)
If the SES light goes on, codes will be set and retained even if the light goes off. Pull the coldes. That will point you in the correct direction. I have not heard this problem before with a CPS so I doubt that is the problem. Pull the codes.
haul_n_horses2 is offline
Old 03-06-2007, 12:01 AM   #6 (permalink)
Im going to go do a search, but just in case I cant find the right answer how do I pull the code? Thanks guys,
Tony
Old 03-06-2007, 09:01 AM   #7 (permalink)
I haven't bought a code reader so when I really need the codes from my truck, I take it to Ford. Don't bother taking your truck to places like AutoZone, their code readers are not set up to read our trucks.
2k F250 XLT CC 6sp PSD, 3.73 LS axle, Superchip, W-D Turbo Brake, Memphis speakers & 5ch amp, WD-Pyro & Boost gauges, Rechargable MagLite, quick disconnect jumper cables, CAT batteries, ARE tonneau,
"unaable" on the tailgate!! New door actuators!!
T-304 Stainless exhaust turbo back, Southbend clutch
Tina is offline
» Sponsor Links
»Garage Storage and Cabinets
