Error Codes P0732 and P0733 - Diesel Forum - TheDieselStop.com
Old 12-29-2008, 03:38 PM   #1 (permalink)
My programmer reads codes 732 and 733 (2nd and 3rd gear ratio errors).
Any ideas? THe tranny seems to shift and run fine. I was about a pint low on fluid but it was hard to tell since i had only driven it 3-4 miles and the fluid wasn't hot yet.
would the programmer have any affect on this by chance? Truck has 122k on it but everything seems fine. Thanks.
Clockwork is offline
Old 12-29-2008, 08:50 PM   #2 (permalink)
F350_6's Avatar
Sometimes codes show up for no apparent reason. Keep an eye on your tranny fluid, clear the codes, and see if they come back. If your programmer has done something to increase the line pressure, that may have set the codes. Have you installed a shift kit or modified valve body to run with your programmer?
Chris
2002 F350 6-speed 444 CID. XLT, Heated Seat, 393,000 & counting.
“Good judgment comes from experience, and a lot of that comes from bad judgment.” Will Rogers
F350_6 is offline
