Ether - Diesel Forum - TheDieselStop.com
post #1 of 26 (permalink) Old 06-19-2011, 10:35 PM Thread Starter
Post Ether
I know this is the wrong time of the year, but, in an emergency could you use ether to start if you disabled the glow plugs? Would you have to pull more than one fuse to do it?
Jerry
2000 F250 Superduty 180K and counting 4X4 4R100 Glow Shift gauge - EGT - Boost - Tranny Temp Fuel Pressure on an A pillar mount Diesel Site boots Transgo shift kit K & N Stage II air filter 5" exhaust RiffRaff AIH to boost mod CCV mod DP-Tuner with W85 settings Amsoil Bypass oil filter 6.0 tranny cooler, W80, Cooling Mist water injection.
F250Truckin is offline
post #2 of 26 (permalink) Old 06-20-2011, 12:00 AM
I read that due to the high compression of diesel engines you should NEVER use ether or any other starting fluid. It could be damaging to pistons, rods, bearings, and crank. I would not do it.
2003 F-250 Lariat 7.3 PSD Auto 4X4, Stock with Banks Ram Air intake, IAH Delete, Amsoil fluids, Amsoil bypass filter system, Dieselsite coolant filter, 285/75R-16 BFG A/Ts, Autometer quad pod (boost, pyro, fuel psi, trans temp, GPR light), Marinco mod, Hutch mod, Harpoon mod.
7MAGMIKE is offline
post #3 of 26 (permalink) Old 06-20-2011, 02:03 AM Thread Starter
Post
I understand there are diesels with starting systems using ether. The glow plugs are a huge issue on our PSD because they cause ignition out of time and that is what can be so damaging. A cold weather start in an emergency could be very beneficial if it could be done safely.
Jerry
post #4 of 26 (permalink) Old 06-20-2011, 06:37 AM
tinman13kup's Avatar
It also comes down to timing. On a gas engine, the ignition is caused by a spark, which is timed according to engine position. On a diesel engine, the ignition is caused by injecting the fuel. The conditions are already met for combustion, so as soon as the fuel is injected it ignites. If you put the fuel source into the air, which is not timed, ignition can occur as soon as conditions are met for ether. This means the temp required may be reached before the piston gets to TDC. Not only are you playing with fire, you're throwing gas at it
Tom
99.5 PS CC 4x4 SRW ZF-6
- AKA "The Big White Truck"
______________________________________________
The first part to be thrown at these trucks should be a PSD compatible scanner
PM please. No Visitor Msg if you want a response anytime soon
tinman13kup is offline
post #5 of 26 (permalink) Old 06-20-2011, 07:32 AM
rammertide07's Avatar
Send a message via MSN to rammertide07
I have a 96 F250 with 650k on factory injectors. It has been ether dependant for a while with no damage done. Not saying its not a risk...
2001 F350 7.3 4x4 CC SRW/ Aeroforce Interceptor/ BD Thruster II/ Bellowed Up-Pipes/ 4" turbo back straight exhaust / CCV Mod /DIY 6637/ TS chip reburned with PHP tunes/160/stock FFD/PowerSlot rotors and green EBC pads/
/MM Hubs/Hood/HPx/FRx/
rammertide07 is offline
post #6 of 26 (permalink) Old 06-20-2011, 08:32 AM
drcampbell's Avatar
My Photos: (32)
If that logic were correct, then you'd be well advised never to inject Diesel fuel, either. Normal combustion pressures are much higher than ether is likely to produce.
Ether's just fine if it's metered and injected properly.
The first problem with spraying ether manually is that you're likely to detonate the air filter housing and/or set the engine compartment afire.
The second problem is that you're likely to inject too much. The problem with ignition occurring far before TDC (top dead center) isn't a problem if ether injection is limited to an amount which will produce less (anti-) torque than the starter motor. Integrated ether systems also refuse to inject unless the crank speed is between 100 & 300 rev/min and the engine's cold.
Even though ether-induced anti-torque isn't a good thing, raising the cylinder temperature is. That's the main benefit of ether.
KBi - Kold Ban International - Ether System and Capacitors
(this may or may not be the best product, but they do have the best visuals on their website)
But back to the OP: If you can't start your engine without ether in June, you need to return to Square One and do some basic diagnosis & maintenance.
Douglas Campbell, P.E.
1986 Isuzu P'up, 177,673.8 miles.
- Hella headlights (highly recommended)
- DOT C-2 back end (also recommended)
- R-12 air conditioner converted to R-406a. Saved ozone and money
- 4.1:1 final drive converted to 3.4:1. Quieter, better mileage but it's a good thing I live in the flat Midwest.
- 9/22/2007, age 21: Still running well when reluctantly sent away for reincarnation, due to body & frame rust.
- Never did get around to converting it to french-fry oil, which is why I originally stumbled upon this site.
drcampbell is offline
post #7 of 26 (permalink) Old 06-20-2011, 09:07 AM
jstrauss's Avatar
The reason you are not supposed to use ether on a diesel engine has nothing to do with the glow plugs or early ignition. As drcampbell points out, if igniting ether in a diesel engine was damaging, then the diesel fuel firing off would be just as bad or worse. The *real* reason you are not supposed to use ether in a diesel engine is there is no throttle to control engine speed. Engine speed is controlled by the amount of fuel introduced into the cylinders. If you use too much ether, an overspeed condition could result which would overrev your engine and then that might bend something.
Having said that, it is my opinion that you can safely start a PSD, and any other diesel, in a pinch using starting fluid if you spray the shortest little blast you can manage from the can while someone else is cranking the motor. If it doesn't start, you have other issues, more ether is not the answer so don't shoot again.
There are many on here who will scream that this is sacrilege - those folks have no idea how many diesels are started EVERY DAY on ether in this country.
1991 F150 SC 4x4 7.5L/ZF5
1991 SAE Bronco 7.3L IDI NA/ZF5
1974 F350 Tow Truck 360/T18
2005 Escape 2.3L/CD4E
jstrauss is offline
post #8 of 26 (permalink) Old 06-20-2011, 10:42 AM
I would just do a short burst of ether on the air filter. Ether evaporates like rubbing alcohol, so the engine isn't taking in 100% of what is sprayed.
post #9 of 26 (permalink) Old 06-20-2011, 10:45 AM
Also, an alternative method I've used on a 91 IDI is laying a gas soaked rag over the intake....fire extinguisher in hand of course.
post #10 of 26 (permalink) Old 06-20-2011, 10:55 AM
OK, so since most 7.3's we drive (probably 100% of us) do not have an elaborate injection system nor a calibrated spray finger and most people have the if a little is good a lot is better mentality ether is probably not a good idea. If my PSD can't start without a shot of ether it is time to do some troubleshooting. JMO guys.
7MAGMIKE is offline
post #11 of 26 (permalink) Old 06-20-2011, 12:58 PM
jstrauss's Avatar
I don't think any of us disagree with this, but the OP said "in an emergency".
jstrauss is offline
post #12 of 26 (permalink) Old 06-20-2011, 12:59 PM
jstrauss's Avatar
I have heard of this too but this sounds more risky to me than ether - the engine is very likely to suck the rag down into the intake. No throttle means max air intake at all times.
jstrauss is offline
post #13 of 26 (permalink) Old 06-20-2011, 05:51 PM Thread Starter
I'm not having trouble with the engine, far from it. I had just read an article on a diesel they start every day with ether but it does not even have glow plugs or other ignition sources. I was just wondering if you disabled the glow plugs and used a tiny amount of ether, would that be reasonable safe. Seems it is if your finger doesn't get heavy. Ether definitely is not bigger is better.
Jerry
post #14 of 26 (permalink) Old 06-20-2011, 06:44 PM
NCR
I'd say if you can disable the glowplugs it would be A LOT safer.
NCR is offline
post #15 of 26 (permalink) Old 06-20-2011, 11:59 PM
drcampbell's Avatar
My Photos: (32)
A) Would you like to bet your life on that?
B) Why would you ever disable the glow plugs if you were trying to start a Diesel engine? Seems dumb.
A small shot, while someone else is cranking the engine and it's turning at a reasonable speed, wearing goggles, a heavy winter coat, hat & gloves, is probably semi-safe with or without glow plugs. One way or another, ether WILL ignite. You need to assure there isn't enough of it to cause a catastrophe when it does.
