Exhaust Back Pressure readings? - Diesel Forum - TheDieselStop.com
post #1 of 7 (permalink) Old 08-01-2011, 12:29 PM Thread Starter
What is 'normal' readings for EBP? Just curious. I have the ability to read them but don't have a clue what is normal.
Griz
02 F250, 4X4, 4R100, 3.73, B&M Transmission Pan, Edge CTS Digital Gage, Tymar 4" Exhaust, Tymar Intake & HPX & TS 6 Position Chip. IH Bellowed Up-Pipes, RiffRaff AIH delete plug, Riffraff FRx Kit. 6.0 Transmission Cooler. Dieselsite Coolant filter & Transmission filter & 203 Thermostat & WW2 & TurboMaster & inter-cooler boots. BD CCV filter. Driven Diesel Fuel Tank Mod & Pre-Pump Filter. John Wood's valve body.
Griz is offline
post #2 of 7 (permalink) Old 08-01-2011, 03:43 PM
klhansen's Avatar
My Photos: (180)
IIRC, EBP ranges from 0-34 psi normally. The 34 psi would be what the EBP system maintains for engine warm-up
I can't confirm that however, because my service CD doesn't run correctly in Win7
), AIS,
regulated return,
klhansen is offline
post #3 of 7 (permalink) Old 08-01-2011, 03:59 PM Thread Starter
At idle it is reading 14-15 psi.
Thanks,
Griz
Griz is offline
post #4 of 7 (permalink) Old 08-01-2011, 06:08 PM
Key on engine off should read 14 psi (ambient) Should read 14-18 psi at idle warm, 28 psi max at 3000 rpm warm.
Evel486 is offline
post #5 of 7 (permalink) Old 08-01-2011, 08:34 PM Thread Starter
Okay...Thanks
Griz
Griz is offline
post #6 of 7 (permalink) Old 09-01-2011, 11:45 PM
I had a bad ICP Sensor. While installing the new ICP Sensor, I decided to also install a new EBP Sensor even though I was not throwing a code. Changing the EBP Sensor, I noted the tube was showing fatigue and decided to replace it as well. After installing the new EBP Sensor and tube, I now have a P0470 code (Exhaust Back Pressure Circuit Failure). I was very careful with the plug and it looks great. My engine monitor shows a constant 43 psi of Back Pressure never fluctuating. Does anyone know if the PCM will reflect a 43 psi reading as a default if I indeed have a bad circuit? Thank you, Bob
Oil City Outlaw is offline
post #7 of 7 (permalink) Old 09-02-2011, 01:09 AM
My Photos: (35)
So with a normal load in the truck or van and running around 1700 rpms the back pressure should be around 18-20?
2000 E350 7.3PSD, Hellwig Stablizer bar, 1.5"spacers from old Correct track OR,140 Lightforce with covers, 5x7 LED's From Truck-lite, extras in the bumper. 4"Aero Turbin and 4" all the way back. 1705 program, Scangauge II,265/75/16E, My Photos
"FAILURE IS NOT AN OPTION"
It riles them to believe
that you perceive
the web they weave
And keep on thinking free
Alaskapsdvan is offline
