F-250 axle nut torque spec - Diesel Forum - TheDieselStop.com
post #1 of 5 (permalink) Old 09-17-2009, 02:23 PM Thread Starter
ok, so now that I botched the title...I need the torque spec for the ratcheting 'nut' that is on the end of the axle. The one that requires the special axle socket...I don't know its proper name.
It's for the rear axle on my 2000 F250
Any and all help is much appreciated!!
-Micah
'00 F250 7.3L, 4x4, 6-spd, SCT X3, ATTA 90 gallon tank/toolbox, Air Lift Loadlifter 5000 kit. WVO kit in the making...now if I could just finish getting the CANbus code written for that HE431VE.
'96 Impreza "WRX" coupe time attack car
Homemade WRX is offline
post #2 of 5 (permalink) Old 09-17-2009, 03:01 PM
-Micah
Answer varies on axle/rear end?
Two ideas when combined together will always make a third better idea!
I don't have to be wrong for you to be right.
Kent
@235K miles @ 071127
>202K miles @ 070828
2001 F350 7.3 PSD SD CC DRW Lariat, 4R100 (replaced at 41k w/rebuilt by dealer), 3.73, FX4 ESOF, Long Box - 3rd CPS. CPS in Glove Box MOD. K&N Filter. 6.0 OTA Cooler. Green to Red Coolant. Water filter. 203 T-stat. Fumoto Valve. Monroe Gasmatic Shocks.
techkdb is offline
post #3 of 5 (permalink) Old 09-17-2009, 04:40 PM Thread Starter
its the 10.25/10.5" standard single rear axle found on 4x4 f250 and f350's
post #4 of 5 (permalink) Old 09-17-2009, 08:59 PM
klhansen's Avatar
My Photos: (180)
Tighten to 60 ft-lb (the nut will ratchet as you tighten), then for new bearings, ratchet back (loosen) five teeth or notches (1/8 turn) on the hub nut. You have to be able to feel the five notches. For used bearings, turn back seven notches (1/6 turn), again making sure you feel the notches while turning.
), AIS,
regulated return,
klhansen is offline
post #5 of 5 (permalink) Old 09-21-2009, 05:25 PM Thread Starter
Awesome, that's exactly what I needed to hear
Thank you!
