F-450 rear end gears - Diesel Forum - TheDieselStop.com
post #1 of 7 (permalink) Old 02-08-2006, 12:23 PM Thread Starter
I have an F-450 (2003 7.3 2wd 6 speed)with the std 4.88 open rear end. My dealer tells me there are no optional gear sets available through Ford. The truck is rated to pull 16k lbs approx, I don't go over 10k, so the extra gear is hurting economy and not being utilized.
Does anyone know of options outside of Ford? Who manufactures these rear ends, Ford says they are specific for the F-450.
Thanks in advance for any help.
2003 F-450 7.3 2wd Supercab 6 speed manual. Converted to WVO
ohthree450 is offline
post #2 of 7 (permalink) Old 02-08-2006, 12:47 PM
Re: F-450 rear end gears
There is a complete rear end for an F350 on ebay right now for $850. You might email the seller and find out the ratio.
1999 Supercab Lariat longbed 2wd auto, Superchip, Sonnax.
2003 Homestead fifth wheel trailer.
2 Wonderful Boxers and 1 Fantastic wife.
1929 Model A Ford Sport Coupe (Sold it, gone to Wisconsin)
1946 Ford Sedan Flathead hotrod
1953 Ford Sedan Vintage A/C, mild hotrod.
1995 Damon Challenger Motorhome
Tobysdad is offline
post #3 of 7 (permalink) Old 02-08-2006, 01:22 PM
griffy71's Avatar
What size is the rear end. You might try Richmond Gear
Griffy71
Necessity is the mother of invention.
If it jams, force it. If it breaks it needed fixing anyway.
01 F-250 PSD 4x4 Extended Cab, Bully Dog Chip, Homemade Tymar, AIH delete, Fumoto Drain Valve, Wicked Wheel.
griffy71 is offline
post #4 of 7 (permalink) Old 02-08-2006, 02:01 PM
Well, the F450 is available from Ford with either the stock 4.88:1 or optional 4.30:1 gears so your dealer needs to look at the order sheets. Also, the axles are standard Dana 80's (unless something has changed recently) so you can go to pretty much any axle shop and swap in any gearset that'll fit. Going to a 4.10:1 or higher requires new carriers, but 4.30:1 will definitely fit in what you've got.
Alan Hepburn - F450 CC PSD 2WD 4R100 XLT+ RAM KILLER
Proud to be a Blue Star Family...Support our troops by supporting their mission.
Alan_Hepburn is offline
post #5 of 7 (permalink) Old 02-09-2006, 08:25 AM
SmokeyWren's Avatar
My Photos: (45)
That wasn't a dealer - that was an uninformed nincompoot. [img]/ubbthreads/images/graemlins/frown.gif[/img]
The 4.88 ratio was standard in a 2003 F-450, but a 4.30 ratio was optional. So your Ford dealer can definitely get you the parts to change it to 4.30.
Around 2003 Ford was experimenting with rear ends for the F-450. Before that and after that they have a heavy-duty Dana 80 rear end with a fancy diff cover. Similar to the Dana 80 diff in the F-350 DRW except for the diff cover. But right about then Ford put the new Dana Spicer-110 rear end in some F-450s. So yours might be either the Dana 80 or the Dana S-110. But in either case, 4.30 ratio was optional.
And BTW, a Dana 80 from a pickup won't work. If you can find one from an F-350 chassis cab, that will work. But a pickup frame is wider than a chassis cab frame, so you can't install a rear axle from a pickup without a lot of fabrication, skinned knuckles, and curse words. [img]/ubbthreads/images/graemlins/smokin.gif[/img]
SmokeyWren is offline
post #6 of 7 (permalink) Old 02-09-2006, 10:44 AM
As above, plus I have a '00 450 4x4 that came with 4.88s. To change to 4.30s, I had to change a (front I think) carrier to go with that ratio. Otherwise, IF you have the Dana80HD (don't know about the 110) there are a lot of gearsets available. Buying one from the dealer just means you will be getting the same thing for twice the price. I pull a 26k trailer, and find that I can walk off in OVERDRIVE (0.8555 x. 4.30 = 3.67 equivalent) and low gear with the 4.30s on level ground at idle, grossing 36k - so it tells you how ridiculous the 4.88s were in the first place. If you have a 2WD truck, I would look seriously at 4.10, 3.90 or even 3.73 (will need carriers).
Pat
2000 F450 Lariat 4x4 tractor, rebuild at 200k in '12, Air Dog, Reg Mod, HX & HP all in hard SS lines, bypass filter, Banks Power Elbow w/3.5 dp, no intake heat, CCV mod, AIS (w/extra hole), some big Alliant single shots, GP indicator LED, custom 4" exhaust, 4" USG exhaust brake, custom alum. rear diff cover extension (dipstick & temp), Detroit locker, ESPAR D5 aux. heat, custom alum tow deck and fuel tanks, Bushwacker 1 1/2" flares, 9k winch, gin poles, JWSpeaker 8900 LED headlamps in XL grille, Lightforce 240GT (still Halogen, but VERY bright), Hella Micro DE HID fogs, KW = vision plus (Isspro) instruments, more to come & lots of other diesels
Pat Dolan is offline
post #7 of 7 (permalink) Old 02-10-2006, 12:50 PM Thread Starter
Thanks for all the input guys.
