Go Back   Diesel Forum - The Diesel Stop.com > 1999-2007 Super Duties > 7.3L Power Stroke Engine and Drivetrain
7.3L Power Stroke Engine and Drivetrain Discussion of the 7.3L Power Stroke diesel engine and drivetrain in the 1999-Up Super Duty trucks and Excursions. No gas engine discussion allowed except on transmissions and drivetrain that pertain to all models. Please confine discussion of topics in this forum to those items that are specific to the 7.3L Power Stroke engine.
Old 05-15-2008, 05:17 AM   #1 (permalink)
F250 7.3ltr Problems
Hi My Truck Runs Rough On Cold Start Up For Approx 10seconds And When I Touch The Accelerator Just Briefly It Instantly Runs Good, I Suspected Glow Plugs And With A Test Light Neither The Heater Or Glow Plugs Have Contact Across The Relays? Yet I Can Hear Them Click? Also I Have A Small Weap/ Leak Of Fuel From Around The Yellow Valve On The Fuel Filter! Is That Possible That Contributes To The Cold Start Problem? And Whats Involved To Replace The Seals In The Fuel Filter Unit? And Finally Do I Have To Panic Every Time I Tow Heavy Loads About My Transmission? As Nearly Every Bloke Here In Oz Is An Expert In F/trucks Yet Never Owned One, I Need To Know Are The Standard Trannys Capable Of Towing 4.5 Tonnes Of Boat 70 Klms Return Every Weekend Or Not? And Will The Auto Tranny Cope A Work Out In Soft Sand Without Towing? I Appreciate Any Help As My Truck Just Sits Awaiting My Guidence. Thanks Jim
captain rednut is offline
Old 05-15-2008, 03:27 PM   #2 (permalink)
F350_6's Avatar
Your glow plugs will only stay on for 0 - 120 seconds depending on temperature and conditions so if you're going to use a test light you need to do it quickly first thing in the morning.
If you have a cooler on the transmission I don't see any reason it won't handle that weight. I have a manual tranny so I can't speak from experience on that one though.
As for repairing the leak at the fuel bowl here are some instructions. Separator Valve Rebuild
Chris
2002 F350 6 spd 3.73LS XLT Heated Seats 255,000 & counting.
F350_6 is offline
Old 05-15-2008, 11:23 PM   #3 (permalink)
99250's Avatar
a trans temp guage will ease your mind a bit.mobil 1 synthetic oil will help to. its a bit expensive but its worth it.the o ring kit for the fuel drain is an easy repair. i towed a fith wheeler round aus ,took 12 months,it weighed 9.2 ton all up. admittedly i had a bts trans in it, (my old 99). im still towing a fiver with my new one and weighing in a bit hevier. im south at the moment, the cold weather dont worry mine. definately a trans temp is needed.
99250
early 1999 ,f250,psd,s/cab,7.3,3.73 ,4*4,short box
harvest gold, snug top cover,xle 4 ,ais filter, bts tranny,v 10 cooler ,
isspro pyro ,trans temp guages.autometer boost
bought new from spokane,wa ,and converted to rhd in australia. sold.
forrest river wildcat, 30rlbs. sold.
06 250, 7.3, bts valve body, tuned by cale at bts.firestone air bags on rear.
cougar , 5er model 309, fitted with full air brakes.
99250 is offline
Old 05-16-2008, 05:34 AM   #4 (permalink)
SmokeyWren's Avatar
My Photos: (33)
If by "Standard Tranny" you mean the ZF 6-speed manual transmission, then no problem. Keep a good clutch in it and go truckin'.
If by "Standard Tranny" you mean the 4R100 automatic tranny that came with the 7.3L diesel engines in the USA, but without any mods, then no problem there either. The only mod you need is a good aftermarket tranny temp gauge. Just never allow the tranny to get too hot and you're good to go. (Don't rely on the Ford tranny temp gauge that came with 2002-up diesels in the USA.)
You guys in Oz have different combos of SuperDuty powertrains than we do, and I'm not sure of which you have. If you have the 4R100 automatic tranny behind a 7.3L diesel engine, then the tranny will certainly cope with a hard workout, but you must have a good aftermarket tranny temp gauge and never allow more than 225ºF tranny temp. As a general rule, the only thing that will kill your tranny is too-high tranny temp, or lots of hard miles.
Playing in the sand can get the tranny fluid boiling in a hurry, so you must keep an eagle eye on the tranny temp gauge. If it ever gets over about 210º, then you need to be running synthetic ATF. If it ever gets up to 225º, then you need to replace the oil-to-air (OTA) tranny cooler with a bigger one, such as the OTA tranny cooler that comes on trucks with the 6.0L diesel engine in the USA.
The 4R100 doesn't require any mods to be a good workhorse and live for at least 100,000 miles or 160,000 klicks while working hard - provided you never let it get too hot. Mine lasted 112,000 mostly-towing miles before I took it to BTS and had them bulletproof it. When BTS tore it down, the only thing wrong with it was the torque converter needed replacing, and the tranny itself would have lasted another 100,000 miles. But during that first 112,000 miles I never saw over 205ºF and I ran with Mobil 1 synthetic ATF after the first 20,000 miles.
If your automatic is the 5R110 TorqShift that comes behind the 6.0L diesel engine in the USA, then I don't know much about them except the "never let it get too hot" rule still applies, and it requires special ATF not available everywhere.
Note that member 99250 who posted above is also from Oz, and he spent the big bucks to put a BTS tranny in his '99. Then when he bought a newer model, he installed the BTS valve body. So he's your resident expert on the 4R100 tranny. If I lived down there, I'd try to get to know him.
My Sierra Blanca is a '99.5 PSD CrewCab hot-rod Towing Machine! BTS tranny; TurboRamAir intake and 4" stainless turbo-back exhaust; DP-Tuner tunes flashed into an Edge Evolution tuner; ISSPRO EV gauges and TTM; AIC. I special-ordered it new and plan to drive it until it quits.
SmokeyWren is online now
Old 05-17-2008, 04:25 AM   #5 (permalink)
hi guys thank you for your help, i will take your advice and get a trans temp gauge for my 4r100 thanks again jim
