F350 front drive shaft same as F250?? - Diesel Forum - TheDieselStop.com
Old 04-25-2005, 03:16 PM   #1 (permalink)
My Photos: (14)
F350 front drive shaft same as F250?? 1999 & up
Thanks Jason
2000 Bombed out F-350...RIP
1996 F-350 4x4 Crew-cab,12V Cummins, NV4500
1992 F250 IDI 4x4 E4OD Hypermax kit
Friends dont let friends drive stock programs!
SPINPOSI is offline
Old 04-25-2005, 05:58 PM   #2 (permalink)
Bella PSD's Avatar
Re: F350 front drive shaft same as F250??
99.99% sure its the same. I would be very surprised if they were different. Everything is the same on SRW 250/350 98.5-2004 except rear blocks. I think early SD 250 might have taller blocks same as 350??
Louie
02 SuperDuty CC Lariat 4x4, 7.3 PSD, 6 speed w/LUK clutch & South Bend Kevlar PB, DP Tuner, 1.15 A/R Van Turbo W/ATS housing, Non-EBV Turbo Pedestal, CCV mod, 4" custom mid side exit straight pipe, Tymar intake, IH T 444E BADGES, 06 Grill, WARN bumpers, AIC, 06 TT mirrors, 37" BFG BAJA on HMMWV double bead lock wheels, Bushwacker cut out flares, Superlift 4" LIFT, Triple A-pillar Gauges, A.R.E. DCU Cap with barn doors and 4'x5'x6" Con Ferr Roof Rack, Rhino Lined, CB, Wet Okole's neoprene seat covers, 2 12" subs
FOKISD Charter Member
My truck
TDS Photos
Bella PSD is offline
Old 04-25-2005, 07:17 PM   #3 (permalink)
My Photos: (14)
I thought 1 Ton u-joints are bigger than 3/4 ton [img]/ubbthreads/images/graemlins/shrug.gif[/img]
SPINPOSI is offline
Old 04-25-2005, 08:06 PM   #4 (permalink)
96STROKE's Avatar
My Photos: (6)
Ford decided to only put a different tag on the fender and different weight rating on the sticker as a cost saving measure!!! [img]/ubbthreads/images/graemlins/shrug.gif[/img]
Remember that the F350 and F250 can pull the same amount of weight, so the U-joint that pulls the weight can be the same. Only difference is weight carrying (GVWR 8800 vs. 9900).
'01 F350 Lariat PSD 4X4 CC SWR LB auto
Superchip 60hp, 4" cat back, A-pillar w/auto meter gages, Firestone Air bags, Bilsteins, Radio Speed Volume Mod, XM Roady
Photos
96STROKE is offline
