F350 Powerstroke Braking System Question - Diesel Forum - TheDieselStop.com
post #1 of 8 (permalink) Old 07-14-2007, 01:05 AM Thread Starter
members,
How long should your brakes (rotors/pads) last for a street driven, occassional towing (16' Open trailer) F350 7.3 PS Crew Cab last miles wise ? I seem to be going through pads/rotors pretty fast... What else can go wrong in the brake system that could be causing premature excessive wearing of the brakes ?
Plaes Help :-) Ceece
2000 F-350 7.3 PSD Crew Cab
Lariat 4x4 Gold/Black
Diablo Predator Tuner
Mac Cold Air Kit
Magna Flow Stainless Steel Exhaust
3.5" Down Pipe
4" Exhaust
JudgeDredd is offline
post #2 of 8 (permalink) Old 07-14-2007, 01:56 PM
Reg Reich's Avatar
Re: F350 Powerstroke Braking System Question
[img]/ubbthreads/images/graemlins/biggrin.gif[/img] I have 244,000kms (152,000 Miles)on my original rotors & am on my third set of pads. I tow a VERY large 5ver & have 100,000 kms (62,000 Miles)on its original brake lining. [img]/ubbthreads/images/graemlins/smirk.gif[/img] In answer to your question. Everyone will get different mileage on brakes because of EVERYONES different driving habits & technics. IMHO, the best way to ensure you can get as high mileage as possible is to ensure the caliper slide pins are kept free & lubricated. I have gotten in the habit of checking & lubricating my slide pins in the fall, before winter driving & again in the spring for my summer driving. I have done this on ALL my vehicles & have found this practice very helpful in getting max life on brake rotors & pads. [img]/ubbthreads/images/graemlins/shrug.gif[/img] My wifes PT Cruiser has 87,000kms (54,000 Miles)on it with original brake components.
I had my truck Safety Inspected this week & it was brought to my attention that the rotors had the vents rusted & plugged from metal delamination & rust buildup. I decided to leave the rotors on the truck & reamed out the vents & removed as much rust as I could & am running the rotors to see how the brakes re-act once they are hot again when pulling or hauling. I also haul a 10.5ft Lance Camper when not pulling the 5ver.
I know this answer is long but hope it will answer some of your question. [img]/ubbthreads/images/graemlins/warmsmile.gif[/img]
Reg
2010 Ram 3500 Dually Laramie. Austin Tan Pearlcoat/Light Greystone Pearlcoat. You Lost Out Ford.
Fulltiming. Gone Haulin. 38 ft 5ver.
Reg Reich is offline
post #3 of 8 (permalink) Old 07-14-2007, 01:59 PM
This is some of the simplest and best advice I've seen.
My stockers made it to 125k even the way I drive they were finally done in by rotted sliders. because I never greased them.
2 times a year minimum, also the ford factory rotors have done great for me, the aftermarket, are ok, but just don't seem to do as well, same for the pads my factory pads made it over 100k. aftermarket, not so much.
2011 F-350 ECSB 4x4 Lariat Sterling Gray Metallic. 51,000 mi
Mods: Silver Star Ultra bulbs, M&S Mini-Maxx, MBRP "Race" Exhaust
North East Mid-Atlantic Diesel Club:
#51
MrPlowJr_EZ_V is offline
post #4 of 8 (permalink) Old 07-14-2007, 02:23 PM Thread Starter
OK, for anybody following this thread, I went out and inspected the back two brake assemblies, I discovered the passenger side caliper was badly worn, the rubber boots were rotted (pistons) and only (1) piston would come up when the brakes were pumped. So it looks like that caliper was not dissengaging and riding the rotor essentially wearing the pad down to the metal. The driver side was fine, rotor and pads.
So a new rotor, caliper and pads for the passenger side was done. Hope this helps somebody out there :-) Ceece
Mac Cold Air Kit
3.5" Down Pipe
4" Exhaust
post #5 of 8 (permalink) Old 07-14-2007, 02:50 PM
Reg Reich's Avatar
[img]/ubbthreads/images/graemlins/warmsmile.gif[/img] Thank You.
BTW Judge, yes it is also VERY important, as you have found out, to ensure the caliper pistons are working free. [img]/ubbthreads/images/graemlins/laugh.gif[/img] I have found out this is usually a simple check when you have to move the pistons in the caliper to install new pads. Pushing them in to install thicker pads. Also the type of wear & wear pattern you see on the old pads can indicate to you what other problems may be in the braking system or components. I would also recommend a fluid change at each reline. I have found it works very well to suck the master cylinder dry, install fresh fluid & then bleed each wheel until I see fresh fluid in my collection bottle. If you are careful in how you press the brake pedal in the bleeding process you should not get ANY air in the system. At least I have been lucky enough to not get any when I bleed my brakes & I do it by myself. There is NO reason to press the pedal to the floor in the bleeding process. I made an adjustable tool to hold the brake pedal down, AFTER i have preesed it gown as far as I needed too & then close off the bleeder & start over again. I do ONE wheel at a time & start at the farthest wheel from the master cylinder. Works for me so far.
OBTW, I do not recommend doing just one wheel on your brake repair. ALL wheels should be equal or you COULD have uneven braking at the other locations & possib;y cause you some stability problems in an emergancy situation. I have done just the front brake pads or just the rear pads but would never do one side at a time.JMHO. [img]/ubbthreads/images/graemlins/warmsmile.gif[/img]
Reg
post #6 of 8 (permalink) Old 07-14-2007, 04:22 PM Thread Starter
Thanks for your reply, I bled the back two wheels and then moved the truck a few feet and upon stopping the pedal went to the floor. i then discovered after all that I had a leak just above the fuel tank, now I have to research that and fix it not sure what it is yet, hose, clamp etc.
I am going to have to pull the fuel tank and take a look at the brake line, ahhh the fun just keeps on coming. :-(
Mac Cold Air Kit
3.5" Down Pipe
4" Exhaust
post #7 of 8 (permalink) Old 07-19-2007, 09:33 PM Thread Starter
Well was able to remove the brake line, it was rusted. I bought new NAPA lines/fittings and bent the lines and bled all (4) brakes calipers and it again stops on a dime, thanks
Mac Cold Air Kit
3.5" Down Pipe
4" Exhaust
post #8 of 8 (permalink) Old 07-19-2007, 11:16 PM
I just go ahead and take the extra time when I rotate tires to grease the slide pins, you already have the wheels off and it only takes about an extra ten minutes per wheel.
When I do a fluid flush I just gravity bleed. Just open the passenger side bleeder and stick a piece of hose running into a container, grab a couple of quarts of fluid and a twelve pack. More if you have help. Take the top off the master cylinder and just watch the level go down (don't let it empty). Every once in a while (I keep the cooler by the wheel with the open bleeder) look at the hose. When it looks clean, change wheels (don't forget the beer cooler).
I have found this process takes about a quart of fluid for the first twelve pack and about two quarts for the second twelve pack. If you get to the fourth twelve pack you usually get to start all over tomorrow with all new fluid.
Andy
Early 99 5-98, F350 extended cab, DRW LB 245,000 miles and counting, Hood insulation delete (Soaked with fuel), Hutch mod, Harpoon mod. Otherwise, pure stock (for now)
You only need two tools: WD-40 and Duct Tape. If it doesn't move and should, use the WD-40. If it shouldn't move and does, use the duct tape.
arisley is offline
